.92 configuration test results in this. Where do I begin
I decided to check my config against the newest version while I was at work to see if I was going to have to put some significant time fixing anything before upgrading. I have not tested the full upgrade on my test pi yet, but figured I would get a head start by asking about the results of the test, and see where I should look first to resolve any issues. This is what it spits out after the test.
Looks to me that the new version does not like something about my scripts for my broadlink, does not like something with the TPlink setup, sun, discovery and updater? All of the ‘?’ were added by the test cofiguration addon, they are not in my config file.
Any ideas before bashing my head in the wall tonight? lol. I will run the update on my test pi to see what it actually breaks before updating anything on my “production” pi. Just figured I would get a leg up and see where I should start to look first.
I am currently running 90.1
Thanks!!!
Log
    aquarium_red_up: ?
      alias: Aquarium Red Up
      sequence: ?
        - data: [source /tmp/config/scripts.yaml:180]
            packet: [source /tmp/config/scripts.yaml:181]
              - JgBQAAABKpQSExMSFBESFBISFBETExMRFTYSNxI4FDYTNxI4FDYTNhMTEhIUNxMRFDYTEhQREhQSNxI4FBESNxUREjcUNxM2EgAFHAABKUsTAA0FAAAAAAAAAAA=
          service: switch.broadlink_send_packet_192_168_1_38
    aquarium_teal: ?
      alias: Aquarium Teal
      sequence: ?
        - data: [source /tmp/config/scripts.yaml:147]
            packet: [source /tmp/config/scripts.yaml:148]
              - JgBQAAABKZMTEhQRExISEhUREhMTERQREzcUNhI4EjcUNhQ2EjcVNhM2EhMTNxI3FTYSEhQREhQSEhQ2FBEUERITEzcSNxQ2EwAFGwABKUkUAA0FAAAAAAAAAAA
    aquarium_white: ?
      alias: Aquarium White
      sequence: ?
        - data: [source /tmp/config/scripts.yaml:99]
            packet: [source /tmp/config/scripts.yaml:100]
              - JgBQAAABK5EVERITExEUEhITExEUERIUEjcSOBM3EzYSOBQ2EzcSNxQRExMTNhITFBEUERI4FBESOBQ2ExEUNxM2EjgUERI4FAAFGAABK0kTAA0FAAAAAAAAAAA=
    aquarium_yellow: ?
      alias: Aquarium Yellow
      sequence: ?
        - data: [source /tmp/config/scripts.yaml:139]
            packet: [source /tmp/config/scripts.yaml:140]
              - JgBQAAABK5IUERIUEhITEhIUExEUERIUEzYSOBQ2EzcSNxQ2EzcSOBQREhMTERQ3EzYSFBMRExISOBQ2EzcSExISFDYTNxI4EwAFGwABKUoSAA0FAAAAAAAAAAA=
    change_input: ?
      alias: TV Input
      sequence: ?
        - data: [source /tmp/config/scripts.yaml:25]
            packet: [source /tmp/config/scripts.yaml:26]
              - JgBQAAABKZQUERQREzcUERMTExIUERMSEzcTNxQSEzcTNxQ2FDYUNhQ2FDYTNxQ2FBETOBMSFBEUERMSFBITEhQ2ExIUNhQ2EwAFDwABKkkUAA0FAAAAAAAAAAA=
    tv_aux_input: ?
      alias: AUX input
      sequence: ?
        - data: [source /tmp/config/scripts.yaml:46]
            packet: [source /tmp/config/scripts.yaml:47]
              - JgCQAAABJpQTNxI3FBISExISExISExI4EjcUEhE4FBESExMSEjgSEhQREjgUERI4EhMSExMRExISOBQREjgSExI3EzcTNxI4EwAFZwABJ5MTNxI3FBESExITExISExM3EjcTEhI4ExISExISEzgTERMSEjgTEhI3ExISFBISExISOBMSEjcTEhI4FDYTNxI3EwANBQAAAAAAAAAA
    tv_mute: ?
      alias: tv mute
      sequence: ?
        - data: [source /tmp/config/scripts.yaml:18]
            packet: [source /tmp/config/scripts.yaml:19]
              - JgDYAAABJpQSOBQ2EhMTEhITExEUERI4FDYTERQ3EhIUERITEjgSExI4EjcTEhITEhMTEhI3FBESFBISEzcSOBI3FDcSEhQ2EgAFaAABJpQSOBM3ExEUEhEUEhITEhI4EjgSEhM4EhITEhITEjgSExI3EjgTEhITEhMSExI3FBESExITEzcSOBI3FDYSExM3EwAFZgABJ5QSOBI4EhIUERITExITEhI3FDcSEhM3EhMTEhITEjgSExI3EjgTEhITEhITExE4FBESExITEzcSNxI4EzcSExM3EgANBQ==
    tv_power: ?
      alias: TV Power
      sequence: ?
        - data: [source /tmp/config/scripts.yaml:32]
            packet: [source /tmp/config/scripts.yaml:33]
              - JgBQAAABKZQUERMSFDYUEhMSFBEUERMSFDYUNxMSFDYTNxQ2FDYUNhMSExMTEhQ2FBEUERQSExITNxM3EzcUERM3FDYTNxM3EwAFEAABKUoUAA0FAAAAAAAAAAA=
    tv_video_input_2: ?
      alias: TV Video input 2
      sequence: ?
        - data: [source /tmp/config/scripts.yaml:39]
            packet: [source /tmp/config/scripts.yaml:40]
              - JgCQAAABKJIUNxI3EhMSExMSEhMSEhM4EjcSExI4EhMTERMSEjgTEhITEjgSExI3EjgTEhI3FBIROBMSEjgTEhITEzYSFBI3EgAFZwABKZIUNhM3EhMSEhMSEhQSEhQ2EjgSExI3EhQSEhQREjgTEhITEjcSFBI3EjgTEhI3ExISOBMSEjcTExITEjcSExI4EgANBQAAAAAAAAAA
    tv_volume_down: ?
      alias: tv volume down
      sequence: ?
        - data: [source /tmp/config/scripts.yaml:11]
            packet: [source /tmp/config/scripts.yaml:12]
              - JgBIAAABJ5MTNxQ2ExITEhITEhITEhI4EzcTEhI4EhITEhIUEjcSExM3EjcUERI4FBESExM3EhMSEhMSEjgTEhI3EzgTERM3EwANBQ==
    tv_volume_up: ?
      alias: tv volume up
      sequence: ?
        - data: [source /tmp/config/scripts.yaml:4]
            packet: [source /tmp/config/scripts.yaml:5]
              - JgDYAAABJ5MUNxI3EhMTEhITEhMSEhM3EzcSExM3EhMSEhQREjgTEhI3EzgTNhITExITEhI3FBESFBISExISOBM3EzYSFBI3EgAFZwABKJMUNhM3EhMSEhMSEhQSEhM3EjgSExI3EhMTEhMSEjgTEhI3EzcSOBITExEUEhE4ExISExITEhMSNxM4EjcSExI4EgAFZwABKJMTNxM2EhQSEhMSEhMSExM3EzYSFBI3EhMSExITEjcTEhI4EzcTNxITEhITEhI4ExISExMRExMROBM3EjgSExI3EgANBQ==
  sun: ?
  system_health: ?
  tplink: [source /tmp/config/configuration.yaml:177]
    discovery: True
    switch: [source /tmp/config/configuration.yaml:179]
      - host: 192.168.1.254
      - host: 192.168.1.206
  updater: ?
    include_used_components: False
    reporting: True
Successful config (partial)
  tts:
    - platform: amazon_polly
      aws_access_key_id: ######
      aws_secret_access_key: ######
      cache: True
      cache_dir: tts
      output_format: mp3
      region_name: us-east-1
      text_type: text
      time_memory: 300
      voice: Brian
This might help:
