I have an SLZB-06 as my Zigbee coordinator, and HA and my Zigbee network are working fine. There are just a couple of things I’m curious about.
The SLZB-06 is running firmware 2.5.6 and I can see it with the SLZB-06 integration, as well as via its web interface. HA is up to date.
First, when I look at the web interface, the Mode selection looks like this:
Now, it’s working as the Coordinator, so why does it not show that turned on? Is it the case that since its default role is Coordinator, I didn’t need to turn it on here? Would it hurt anything if I did?
Second, in the integrations Configuration section, it shows the Zigbee firmware as unknown:
Is that normal? Would it appear if I turned the Coordinator switch on?
Again, everything is working so I don’t need to do anything, and I hesitate to make a change just to see what happens, as I don’t want to mess something up.
If anyone can enlighten me I’d appreciate it.
