Thanks a lot, that was my missing piece.
Hi all,
any suggestion how I can add an if else function in the button_card_templates.yaml ?
I do want to change the color of the circle for the person card in dependence of the teams presence status and the original state home <-> not home.
So far it’s working pretty well:
(Red Circle for in a call)
But when not at home and not in a call the circle is not like in the original design from Matthias:
This is obivously because of my moddification in the template file as I don’t know how to implent the if else function:
stroke = states[variables.teams].state == 'Am Telefon' || states[variables.teams].state == 'In einer Besprechung'
? 'red'
: '#b2b2b2',
E.g. if stroke = states[variables.teams].state == ‘Work’ then ‘none’
Furthermore I try to let the circle (just the circle) blink when I’m in a call. I don’t get it, how to select just the circle himself? With the following modification, the hole SVG (so circle and text) start to blink. Any suggestion how to achieve that, just the circle blinks?
circle:
- animation: >
if (entity) {
return states[variables.teams].state == 'Am Telefon'
? 'blink 2s ease infinite'
: 'none';
Yeah, doing it that way styles the whole div. You can add a new custom_field to set the styles with js
person:
custom_fields:
blink: >
setTimeout(() => {
let elt = this.shadowRoot,
circle_stroke = elt.getElementById('circle_stroke');
if (
states[variables.teams]?.state == 'Am Telefon' ||
states[variables.teams]?.state == 'In einer Besprechung'
circle_stroke.style.animation = 'blink 2s ease infinite';
circle_stroke.style.stroke = 'red';
} else {
circle_stroke.removeAttribute('style');
}, 0);
Hi @Mattias_Persson, apologies if this was asked and answered, i might be late to the party on this.
I am trying to updated form the old command_line for udm_unifios that was stored in the secrets file (see old command below) to the new python3 implementation, but the script is not running, i just get an error in the logs “Command failed (with return code 1):” followed by the script (see full error message below), i think i am missing a step but with the move of the file i cant find the commit where this was added.
oh and in this commit, use update entities · matt8707/hass-config@1408d40 · GitHub you forgot to remove the use of udm_upgradable
on line 586 in ui-lovelace.yaml
Error Message
Command failed (with return code 1): python3 << EOF import json, yaml, requests from datetime import datetime from urllib3 import disable_warnings disable_warnings() SECRETS_FILE = "/config/secrets.yaml" def get_secret(secret): try: with open(SECRETS_FILE, "r", encoding="utf8") as file: secrets = yaml.full_load(file) for key, value in secrets.items(): if key == secret: return value except FileNotFoundError: print("secrets.yaml not found") exit() IP = get_secret("unifi_host") PORT = get_secret("unifi_port") USER = get_secret("unifi_username") PASS = get_secret("unifi_password") URL = f"https://{IP}:{PORT}" login = requests.request("POST", f"{URL}/api/auth/login", \ headers={"Content-Type": "application/json"}, \ data=json.dumps({"username": USER, "password": PASS}), verify=False) response = requests.request("GET", f"{URL}/proxy/network/api/s/default/stat/device/", \ cookies=login.cookies, verify=False) data = response.json()["data"][0] print(json.dumps({ "cpu": data["system-stats"]["cpu"], "cpu_temp": round(data["temperatures"][1]["value"], 1), "mem": data["system-stats"]["mem"], "disk": round(data["storage"][1]["used"] / data["storage"][1]["size"] * 100, 1), "internet": data["internet"], "uptime": datetime.fromtimestamp(data["startup_timestamp"]).isoformat(), "version": data["displayable_version"] })) EOF
Note: i did update the keys in the script to match what i have in my secrets
unifi_host is just the IP that i use to connect to my UDM
unifi_port is 433 that was the port used in the old script.
Old Command
platform: command_line
command: !secret udm_unifios
value_template: |-
{% set json = value_json.data[0] %}
{{ json["system-stats"].cpu }}|
{{ json.temperatures[1].value | round(1) }}|
{{ json["system-stats"].mem }}|
{{ ((json.storage[1].used / json.storage[1].size) * 100) | round(1) }}|
{{ json.internet }}|
{{ json.startup_timestamp | timestamp_local }}|
{{ json.displayable_version }}|
{{ json.upgradable }}
scan_interval: 120
Thanks for this great dashboard! I’m currently trying to create a template for a climate (radiator) card, code shown below. The base template is referenced from the original.
climate:
template:
- base
double_tap_action:
action: fire-dom-event
browser_mod:
command: popup
title: >
return !entity || entity.attributes.friendly_name;
style:
hui-entities-card:
#states {
padding-top: 0.8em;
card:
type: entities
entities: >
if (entity) {
let climate = [],
id = Boolean(entity.attributes.entity_id)
? [entity.entity_id].concat(entity.attributes.entity_id)
: [entity.entity_id];
for (let i = 0; i < id.length; i++) {
climate.push({
"type": "custom:mushroom-climate-card",
"entity": id[i],
"fill_container": false,
"primary_info": "name",
"secondary_info": "state",
"icon_type": "icon",
"show_temperature_control": true,
"hvac_modes": ["off","auto","heat"],
"collapsible_controls": true
return climate;
variables:
circle_current_temp_input: >
const current_temperature = entity.attributes.current_temperature;
return current_temperature;
circle_current_temp_unit: "°"
circle_set_temp_input: >
const set_temperature = entity.attributes.temperature;
return set_temperature;
circle_set_temp_unit: "°"
custom_fields:
circle_current_temp: >
if (entity) {
let r = 22.1,
c = r * 2 * Math.PI,
tspan = '<tspan dx=".2" dy="-.4">',
domain = entity.entity_id.split('.')[0],
state = variables.state,
input = variables.circle_current_temp_input || ' ',
unit = variables.circle_current_temp_unit || ' ';
* CIRCLE *
let circle = (state, input, unit) => {
return `
<svg viewBox="0 0 50 50">
<style>
circle {
transform: rotate(-90deg);
transform-origin: 50% 50%;
stroke-dasharray: ${c};
stroke-width: var(--c-stroke-width);
stroke: ${state ? 'var(--c-stroke-color-on-current)' : 'var(--c-stroke-color-off-current)'};
fill: ${state ? 'var(--c-fill-color-off-current)' : 'var(--c-fill-color-on-current)'};
text {
font-size: var(--c-font-size);
font-weight: var(--c-font-weight);
letter-spacing: var(--c-letter-spacing);
fill: ${state ? 'var(--c-font-color-off)' : 'var(--c-fill-color-on)'};
tspan {
font-size: var(--c-unit-font-size);
#circle_value, tspan {
text-anchor: middle;
dominant-baseline: central;
</style>
<circle id="circle_stroke" cx="25" cy="25" r="${r}"/>
<text id="circle_value" x="50%" y="52%">${input}${tspan}${unit}</tspan></text>
</svg>
if (domain === 'climate') {
return circle(state, input, unit);
circle_target_temp: >
if (entity.state === "heat") {
let r = 22.1,
input = variables.circle_set_temp_input || ' ',
unit = variables.circle_set_temp_unit || ' ',
valve_pos = variables.valve,
valve_pos_num = valve_pos.slice(0, -1);
* CIRCLE *
return `
<style>
circle {
stroke-dashoffset: ${c - valve_pos_num / 100 * c};
stroke: ${state ? 'var(--c-stroke-color-on-target)' : 'var(--c-stroke-color-off-target)'};
fill: ${state ? 'var(--c-fill-color-on-target)' : 'var(--c-fill-color-off-target)'};
text {
fill: var(--c-font-color);
tspan {
</style>
</svg>
styles:
card:
- --c-stroke-color-on-target: "#b0b0b0"
- --c-stroke-color-off-target: none
- --c-stroke-color-on-current: none
- --c-stroke-color-off-current: none
- --c-fill-color-on-target: none
- --c-fill-color-off-target: rgba(255,255,255,0.04)
- --c-fill-color-on-current: rgba(78,198,110,0.6)
- --c-fill-color-off-current: rgba(255,255,255,0.04)
- --c-stroke-width: 2.3
- --c-stroke-width-current: 0
- --c-stroke-width-dragging: 4
- --c-font-color: "#97989c"
- --c-font-color-off: "#97989c"
- --c-font-color-on: white
- --c-font-size: 14px
- --c-unit-font-size: 10.5px
- --c-font-weight: 700
- --c-letter-spacing: -0.02rem
custom_fields:
circle_target_temp:
- display: initial
- width: 88%
- margin: -3% 2% 0 0
- justify-self: end
- opacity: 1
- display: initial
- width: 88%
- margin: -3% 14% 0 0
- justify-self: end
- opacity: 1
grid:
- grid-template-areas: |
"circle_current_temp circle_target_temp"
"n n"
"s s"
- grid-template-columns: repeat(2, 1fr)
- grid-template-rows: auto repeat(2, min-content)
- gap: 1.3%
- align-items: start
This is what i get when the climate entity state is off, no problems. Current temperature is shown in the top left corner:
When the climate enitity state is heat, this is what i get, but this is not the way i intended:
What i expected is this, with a green fill-color for the circle and the target temperature in the top right corner:
If someone could point me in the rigtht direction, it would be much appriciated!
Yeah, that error doesn’t tell much. Test the most basic form locally then if that works add the json paths and lastly the secrets function.
disable_warnings()
IP = " "
PORT = " "
USER = " "
PASS = " "
print(response.json())
Thanks! 95c6a1f
Hello There
I have a problem with the footer and I have no idea what it can be. The size of the buttons does not adjust automatically. If I change the with from “fit-content” to 100px in footer.yaml, the buttons scale.
#button_card_templates: !include button_card_templates.yaml
!include_dir_merge_named button_card_templates
- type: custom:grid-layout
path: 0
layout:
#default
margin: 0
grid-gap: var(--custom-layout-card-padding)
grid-template-columns: repeat(4, 1fr) 0
grid-template-rows: 0 repeat(2, fit-content(100%)) 0fr
"sidebar . . . ."
"sidebar wohnzimmer flur schlafzimmer ."
"sidebar media sonos home ."
"sidebar footer footer footer ."
mediaquery:
#phone
"(max-width: 800px)":
grid-gap: calc(var(--custom-layout-card-padding) * 1.7)
grid-template-columns: 0 repeat(2, 1fr) 0
grid-template-rows: 0 repeat(5, fit-content(100%)) 0fr
". sidebar sidebar ."
". wohnzimmer schlafzimmer ."
". flur home ."
". media sonos ."
". footer footer ."
#portrait
"(max-width: 1200px)":
grid-template-columns: repeat(3, 1fr) 0
grid-template-rows: 0 repeat(3, fit-content(100%)) 0fr
"sidebar . . ."
"sidebar wohnzimmer schlafzimmer ."
"sidebar flur home ."
"sidebar media sonos ."
"sidebar footer footer ."
cards:
- type: custom:button-card #extra_styles fix
styles: {card: [display: none]}
# SIDEBAR #
- type: vertical-stack
view_layout:
grid-area: sidebar
cards:
entity: sensor.template_sidebar
template: sidebar
# Wohnzimmer #
- type: grid
title: Wohnzimmer
view_layout:
grid-area: wohnzimmer
columns: 2
cards:
entity: light.new_york
template:
- light
- icon_hue
entity: light.schnapstrue
template:
- light
- icon_hue
entity: sensor.weather_station_temperature
tap_action:
action: more-info
custom_fields:
graph:
card:
entities:
- sensor.weather_station_temperature
template:
- temperature
- icon_temp
variables:
popup_name: Temperatur
entity: light.salzstein
template:
- light
- icon_hue
# Schlafzimmer #
- type: grid
title: Schlafzimmmer
view_layout:
grid-area: schlafzimmer
columns: 2
cards:
entity: light.schlafzimmer
template:
- light
- icon_lamp
entity: fan.luftibert
hold_action:
!include popup/schlafzimmer_fan.yaml
tap_action:
action: more-info
template:
- base
- icon_fan
entity: media_player.hauptschlafzimmer
hold_action:
!include popup/sonos.yaml
template:
- base
- icon_sonos
- loader
entity: sensor.luftibert_temperature
tap_action:
action: more-info
custom_fields:
graph:
card:
entities:
- sensor.luftibert_temperature
template:
- temperature
- icon_temp
variables:
# MEDIA #
- type: grid
title: Media
view_layout:
grid-area: media
columns: 1
cards:
- type: custom:swipe-card
start_card: 1
parameters:
roundLengths: true
effect: coverflow
speed: 650
spaceBetween: 20
threshold: 7
coverflowEffect:
rotate: 80
depth: 300
cards:
- type: custom:spotify-card
account: default
spotify_entity: media_player.spotify_jan_stager
playlist_type: discover-weekly
grid_covers_per_row: '2'
limit: 4
country_code: DE
default_device: Küche
display_style: grid
known_connect_devices:
- id: d4757ab523224358f9c9052ee4de85ba324c41fa
entity_id: media_player.kuche
- type: custom:mini-media-player
entity: media_player.kuche
hide:
power: true
volume: true
controls: true
source: true
speaker_group:
platform: sonos
show_group_count: true
entities:
- entity_id: media_player.kuche
- entity_id: media_player.badezimmer
name: Sonos Badezimmer
- entity_id: media_player.buro
- entity_id: media_player.hauptschlafzimmer
name: Sonos Schlafzimmer
- entity_id: media_player.balkon
entities:
entity: media_player.multiroom_player
group: true
source: icon
artwork: cover
info: scroll
hide:
volume: true
power_state: true
group: true
hide:
controls: true
entity: media_player.badezimmer
group: true
hide:
controls: true
entity: media_player.buro
group: true
hide:
controls: true
group: true
hide:
controls: true
entity: media_player.balkon
group: true
hide:
controls: true
# Sonos #
- type: grid
title: Sonos
view_layout:
grid-area: sonos
columns: 1
cards:
- type: entities
entities:
group: true
hide:
controls: true
power: true
icon: true
info: true
source: true
progress: true
group: true
hide:
controls: true
power: true
icon: true
info: true
source: true
progress: true
group: true
hide:
controls: true
power: true
icon: true
info: true
source: true
progress: true
group: true
hide:
controls: true
power: true
icon: true
info: true
source: true
progress: true
group: true
hide:
controls: true
power: true
icon: true
info: true
source: true
progress: true
# Flur #
- type: grid
title: Flur
view_layout:
grid-area: flur
columns: 2
cards:
entity: light.group_hall
template:
- light
- icon_spot
# Home #
- type: grid
title: Home
view_layout:
grid-area: home
columns: 2
cards:
entity: script.home_leave
hold_action:
action: none
template:
- base
- icon_away
entity: script.home_arrive
hold_action:
action: none
template:
- base
- icon_home
entity: script.good_night
hold_action:
action: none
template:
- base
- icon_good_night
entity: script.music
hold_action:
action: none
template:
- base
- icon_music
# FOOTER #
- type: horizontal-stack
view_layout:
grid-area: footer
cards:
<ha-icon icon="mdi:nas"></ha-icon> NAS
tap_action:
!include popup/footer_nas.yaml
triggers_update:
- binary_sensor.jan_home_update_available
- sensor.jan_home_status
- binary_sensor.jan_home_security_status
- sensor.disk_use_percent
variables:
notify: >
let id = this._config.triggers_update;
if (id.every(e => states[e]))
return states[id[0]].state === 'on'
? 1
: states[id[1]].state === 'background_scrubbing' ||
states[id[2]].state === 'on' ||
parseFloat(states[id[3]].state) >= 85;
template: footer
<ha-icon icon="mdi:arrow-up-bold-circle-outline"></ha-icon> Updates
tap_action:
!include popup/footer_updates.yaml
triggers_update:
- sensor.hacs
- sensor.docker_hub_beta
- sensor.docker_hub
variables:
notify: >
if (id.every(e => states[e])) {
let hacs = parseInt(states[id[0]].state),
installed = hass.config.version,
latest = installed.includes('b')
? states[id[1]].state
: states[id[2]].state;
if (latest.includes('.') && Number.isInteger(hacs))
return hacs + (installed !== latest ? 1 : 0);
return 0;
template: footer
<ha-icon icon="custom:roborock-vacuum"></ha-icon> Buddy
tap_action:
!include popup/footer_vacuum.yaml
triggers_update:
- sensor.date
variables:
notify: >
let id = states['sensor.morty_last_clean_end'];
if (id) return (Date.now() - Date.parse(id.state)) > 6048e5;
template: footer
<ha-icon icon="mdi:chart-line-variant"></ha-icon> Statistik
tap_action:
!include popup/footer_history.yaml
template: footer
<ha-icon icon="custom:cupra"></ha-icon> Cupra
tap_action:
!include popup/footer_cupra.yaml
template: footer
I am grateful for every hint
Hi @Mattias_Persson , first thank you for your setup and help. I did everything as listed in Github Installation Instructions. First I got error:
secret Youtube_token not defined
but I fixed it by commenting it in media.yaml.
But now I get the error:
Secret apexcharts_tibber not defined
I dont know how to fix and I already searched this post but didnt find any solution. I already installed the apexcharts repo via hacs.
Can you please give me a solution?
Thank you!
That’s outdated instructions, there’s no secrets anymore. You’ll have to copy the files from my repo again https://github.com/matt8707/hass-config/blob/00de2dd3ce0f3145e20ae0de5adda518b37b0194/INSTALL.md
Okay thank you so much I will try it!
Hi so I´m sure this was asked a lot, but can somebody please tell me which files I need to look at for changing text, language, adding my own entities?
Thank you
but where can I do like the living room etc? Because in Lovelace ui it messes up everything when I change?
Mattias,
Or really anyone with the knowledge.
I have the Unifi UDM-Pro but I’m really struggling trying to get the footer to populate. Everything pops-up as should but shows “unknown” for values.
I’ve made the appropriate changes in !secrets and looked over "router_unifi.yaml to see where i may need some changes.
This instance of Unifi controller is not hosted anywhere other than on the UDM-pro.
I’ve tried doing the ssh into UDM without success.
Does something need to be enabled that I’m missing?
I do have the Unifi addon working, and have tried the same user and pass as that and still no go.
Hey buddy great work, would you mind sharing your Plex popup. Is this collected off of another computer or server (docker)?
I’m attempting to make an auto-populating card for switch groups, based of the code for the new light popup… however I am was scratching my head as to what format is needed for:
tap_action:
action: toggle
I eventually figured it out.
Here is the button card template:
switch:
template:
- base
#- circle
- loader
double_tap_action:
browser_mod:
command: popup
title: >
style:
hui-entities-card:
#states {
padding-top: 0.8em;
card:
type: entities
entities: >
if (entity) {
let switches = [],
switches.push({
"type": "custom:mushroom-entity-card",
"entity": id[i],
"secondary_info": "last-changed",
"icon_color": "light-green",
"tap_action": { action: 'toggle' }
return switches;
I’m still yet two wrap my head around how to set up the circle info to display “x/y” (where x is number of switches in the on state and y is the total of switches), then all that’s left is to fill the circle line out as a percentage of that.
I got it working, it was a combination of issues,
I had port 433 not 443 in my secretes but when I tested the code I used 443
and my HA user role didn’t have access to UniFiOS.
Thanks for the help, would not have been as much of an issue if the errors was more understandable but that’s a HA issue.
Love your config for the second screen. Could you share the Yaml?
