slofii
(Michael)
December 7, 2021, 10:19am
2135
My Popup Card for the camera looks like this:
action: fire-dom-event
browser_mod:
command: popup
title: Kamera
style:
hui-grid-card:
$hui-entities-card$: |
#states {
padding-bottom: 0 !important;
$hui-history-graph-card$ : |
.content {
padding: 1.8em 2em 1.8em 2em !important;
$hui-glance-card$ : |
.entities.no-header {
padding-top: 0 !important;
button-card {
justify-self: center;
margin: 0.8em 0 2.5em 0;
width: 100%;
#root {
grid-gap: 0 !important;
hui-map-card {
height: 99.5% !important;
card:
type: grid
columns: 1
square: false
cards:
- type: picture-entity
entity: camera.blink_miccam1
show_name: false
show_state: false
- type: entities
show_header_toggle: false
entities:
- entity: script.camera_stream
icon: mdi:cast
Did this help?
slofii
(Michael)
December 7, 2021, 10:26am
2136
I cant change the color of my lights anymore. Have anybody an idea why?
imne
(Imne)
December 8, 2021, 12:12am
2137
can you please share your yaml for this ui
maverik80
(Maverik80)
December 8, 2021, 3:13am
2138
thank you very much, it was a beginner mistake
chezpaul2
(Paul B.)
December 8, 2021, 5:44am
2139
Hey @Mattias_Persson ,
I’ve tried to update my person automation as you did in your last update.
But you have only 2 people in your house. I have four. Did I do this right here?
- id: '8423590985012'
alias: Person Home
initial_state: true
- platform: state
entity_id:
- person.paul
- person.nathalie
- person.juliette
- person.julien
- home
- away
to:
- home
- away
- choose:
- conditions: >
{{ trigger.entity_id == 'person.paul' }}
sequence:
- service: mqtt.publish
topic: homeassistant/persistence/paul
payload_template: >
{{ now() }}
retain: true
topic: homeassistant/persistence/juliette
payload_template: >
{{ now() }}
retain: true
topic: homeassistant/persistence/julien
payload_template: >
{{ now() }}
retain: true
default:
topic: homeassistant/persistence/nathalie
payload_template: >
{{ now() }}
retain: true
I don’t understand the default:
thing going on.
The way I did it, I don’t have the time in the button anymore. I did change everything else accordingly.
odiv
(Duta Ovidiu)
December 8, 2021, 5:02pm
2141
Hello @Se7enair ! How did you manage to add cameras on your setup?
soylant
(Birger Jensen)
December 8, 2021, 7:20pm
2142
Hi
I am trying to make a sensor for my udm_unifios I have the sensor template in place also changed the secret file to match my UDM and testet that the user and password I am using is working, but still I am not able to get the sensor working keep saying unknown, did you do anything on UDM to make this work??
antyamok
(antyamok)
December 8, 2021, 8:24pm
2143
@Mattias_Persson
I’m looking to get a count of open doors like what was done for the lights in the Sidebar.
How can I do it?
I’ve added “append” so you can add your door list there
{%- set media_players = [
states.media_player.sony_bravia_tv
{%- set lights_on = lights | selectattr('state','eq','on') | list %}
{%- set lights_name = lights | selectattr('state','eq','on') | map(attribute='name') | join(', ') %}
{%- set switches_on = switches | selectattr('state','eq','on') | list %}
{%- set media_players_playing = media_players | selectattr('state','eq','playing') | list %}
{%- set append = switches_on + media_players_playing %}
{%- set switches_name = append | map(attribute='name') | join(', ') %}
{%- if (lights_on | length == 0) and (switches_on | length > 0) -%}
{{ switches_name | regex_replace(',([^,]*)$',' och\\1') }} är på
{%- elif (lights_on | length == 1) and (switches_on | length == 1) -%}
{{ lights_name }} och {{switches_name }} är på
{%- elif (lights_on | length == 1) and (switches_on | length > 1) -%}
{{ lights_name }}, {{ switches_name | regex_replace(',([^,]*)$',' och\\1') }} är på
Nope, try curl command in terminal first and make note of any errors
@Vsider
I spent the weekend scratching my head over this. I didn’t want any scripts with dependencies or cli utilities, I just wanted to access the damn api
I came up with this (cookie in variable )
data='{"username":"user","password":"pass"}'; ip='https://192.168.1.1:443'; c=$(curl -H 'Content-Type: application/json' -d $data -ksc - $ip/api/auth/login -o /dev/null); echo "${c}" | curl -ksb - $ip/proxy/network/api/s/default/stat/device/
BUT because of the limitations of Command line Sensor , …
No, away
is wrong and you need trigger.entity_id
for each person
https://www.home-assistant.io/docs/scripts/#choose-a-group-of-actions
It just means “else” and it’s optional
Are you going to share your secrets.yaml? It’s done manually
is its own card and is not a valid for type: entities
. You can however use the “internal” name type: custom:hui-picture-entity-card
[source ] (or hui-element )
I’d skip entities
altogether and if you need other cards group them in a vertical-stack
chezpaul2
(Paul B.)
December 8, 2021, 11:00pm
2150
Mattias_Persson:
No, away
is wrong
I did change all instances of your “not_home” to “away” so it should work, right?
chezpaul2
(Paul B.)
December 8, 2021, 11:04pm
2152
You have trigger identity for 2 people. I just made it 4. Does that not work?
That part is correct but the action you’ve posted is “if person.paul changes state update timestamp of paul, juliette and julien”
moritzlang
(Moritz)
December 9, 2021, 12:00am
2154
I saw that some guys here were using the thermostat-popup-card by DBuit.
There are some issues with it and because the repo is not well maintained I added two pull request to the original repository.
Additionally I adjusted some styles. If you want your thermostat popup to look like the screenshot below, feel free to use the URL of my fork when installing via HACS:
https://github.com/moritzlang/thermostat-popup-card
