chezpaul2
(Paul B.)
December 19, 2021, 4:05am
2215
I would dare say it’s because you left all the junk in there?
Try this maybe:
<svg viewBox="0 0 33.2 33.13">
<path d="M26.44 3.24C18.11-2.73 7.13-0.24 1.92 8.86c-5.35 10.36 1.04 22.56 12.6 24.16 c7.46 1.03 14.7-3.29 17.58-10.49C34.8 15.72 32.4 7.51 26.44 3.24z M23.44 20.48c-0.05 3.75-3 6.75-6.66 6.8 c-3.85 0.06-6.91-2.81-7.06-6.64c-0.02-0.58 0-1.16-0.01-1.74c-0.01-0.65 0.19-1.21 0.93-1.21c0.8 0 0.99 0.58 0.97 1.29 c-0.02 0.58-0.02 1.16 0 1.74c0.13 2.58 2.24 4.63 4.81 4.69c2.64 0.07 4.82-1.76 5.06-4.38c0.13-1.4 0.05-2.82 0.06-4.23 c0-0.64-0.27-1.04-1.06-1.06c-3.19 0-6.27-0.03-9.36 0.02c-1.04 0.01-1.39-0.39-1.43-1.4c-0.1-2.51 0.26-4.82 2.22-6.66 c3.44-3.22 9.19-2 10.98 2.35c0.26 0.64 0.51 1.31-0.31 1.67c-0.84 0.37-1.12-0.28-1.41-0.92c-1.05-2.28-3.3-3.46-5.58-2.96 c-2.38 0.52-3.94 2.41-4.02 4.75c-0.03 0.98 0.33 1.39 1.32 1.38c3.01-0.03 6.03-0.02 9.04-0.01c1.34 0 1.48 0.16 1.49 1.51 C23.45 17.15 23.47 18.82 23.44 20.48z"/>
</svg>
Appart from the color of course if you want it blue.
Also you should maybe make the size 0 0 50 50, you have it smaller.
But I’m not a pro. Sorry
chezpaul2
(Paul B.)
December 19, 2021, 4:10am
2216
@Mattias_Persson
How do I know if I should use conditional_media_atv2_fix and conditional_media_atv1_fix?
I’m using one Gallery, one spotify account, one Sonos and one AppTV in the conditionals but I can’t get it to work. I always see the Gallery. I can’t figure out where my problem is. Does it matter what the media_players actually are? I’m not using any TV’s
For you what are: media_player.vardagsrum, media_player.sovrum and media_player.kok?
Apple TV’s?
PS: I’m almost done…
chezpaul2
(Paul B.)
December 19, 2021, 4:38am
2217
Also, @Mattias_Persson if you ever get bored, you should put the name of the artist and title of song on the spotify button.
Just an idea…
Hi Paul!
Thanks for your reply.
I have already tried stripping all the junk and resizing the viewBox, but I left it in my post so that I wasn’t hiding anything that could be used to identify what’s wrong with the SVG.
With or without the junk or viewBox change, Safari/iOS displays the card and the SVG, but not the other browsers. When I open the Inspector, it’s just not there, no div, nothing.
Sadly, I’m no expert either.
Cheers.
RabbitRedBeard:
Initially I thought it was all working fine as the SVGs I created appear fine in Safari, but in Chrome, Edge, or Firefox the entire button-card disappears if I use any SVG other than your own.
I’ve read through the linked design principles for the mdi’s and also used the linked template from that site, but still, I am unable to get them to display.
Your card is not rendering because you’re missing a space in width:78%
The linked design principles is for creating custom “mdi” (for entities card etc)
For the button-card icons check out this post A different take on designing a Lovelace UI - #264 by Mattias_Persson
I don’t remember… I think it’s a fix for the horrendous youtube app on apple tv. It’s so convoluted at this point I might redo it. The basic idea is in conditional_media_playing
automation.
media_player.vardagsrum = appletv
media_player.sovrum = appletv
media_player.kok = google nest mini
There is on the big one, not the small because the text doesn’t fit
Aw, man…
Thank you for the spot, it’s working fine now.
Again, great work on putting all this together, and thank you for having a look into my post.
Also, thank you for the linked post too, much better!
chezpaul2
(Paul B.)
December 19, 2021, 8:33pm
2223
I’m down to just 2 conditions and it still doesn’t work… Argh…
It just stays on the gallery card at all times.
I feel bad but @Mattias_Persson if you ever have some time to look at this, I would greatly appreciate.
I’m done after this, promise.
input.yaml
input_select:
conditional_media:
initial: gallery
options:
- gallery
- spotify
automation.yaml
- id: '7426848686945'
alias: Homeassistant_start
initial_state: true
- platform: homeassistant
event: start
- service: browser_mod.close_popup
- delay:
seconds: 1
- service: frontend.reload_themes
- delay:
seconds: 10
- choose:
- conditions:
- condition: state
entity_id:
- media_player.spotify_cheznath
state: 'off'
sequence:
- service: input_select.select_option
entity_id: input_select.conditional_media
option: gallery
- delay:
seconds: 10
- service: fullykiosk.load_start_url
entity_id: media_player.galaxy_tab_a_media_player
- id: '5557842567134'
alias: conditional_media_playing
initial_state: true
mode: restart
- platform: state
entity_id:
to: playing
option: >
spotify
- id: '3603627624707'
alias: conditional_media_paused_idle
initial_state: true
mode: restart
- platform: state
entity_id:
to:
- 'off'
- idle
- standby
- platform: state
entity_id:
to: paused
for:
minutes: 5
option: >
{% set media_players = [states.media_player.spotify_cheznath] %}
{% if media_players | selectattr('state','eq','playing') | list | count == 0 %}
{% if media_players | selectattr('state','eq','paused') | list | count == 0 %}
gallery
{% else %}
{{ media_players | selectattr('state','eq','paused') | map(attribute='name') | max }}
{% endif %}
{% else %}
{{ media_players | selectattr('state','eq','playing') | map(attribute='name') | max }}
{% endif %}
- id: '6882931899148'
alias: conditional_media_all_off
initial_state: true
value_template: >
{{ is_state('media_player.spotify_cheznath', 'idle') }}
option: gallery
ui-lovelace.yaml
cards:
- type: horizontal-stack
cards:
- type: conditional
conditions:
- entity: input_select.conditional_media
state: gallery
card:
type: custom:gallery-card
entities:
- sensor.gallery_images
menu_alignment: hidden
slideshow_timer: 120
maximum_files: 30
file_name_format: '%YYY_%m_%d_%H_%M_%S'
caption_format: ' '
card_mod:
style: |
ha-card {
border-radius: calc(var(--custom-button-card-border-radius) / 2); /* card - rounded corners */
aspect-ratio: 1/1; /* card - square */
figure {
margin: 0px !important; /* remove card margins to line up with rest of dashboard */
figcaption {
display: none; /* hide image caption */
img {
object-fit: cover !important; /* fill the whole card */
aspect-ratio: 1/1; /* needed for object-fit */
.btn {
top: 50% !important; /* center buttons */
.modal-content {
aspect-ratio: unset; /* undo image aspect-ratio when clicked */
- type: conditional
conditions:
state: spotify
card:
type: custom:button-card
entity: media_player.spotify.cheznath
template:
- conditional_media
- icon_spotify
Hello. Is anyone having this problem?
This should load when we add the car mod integration?
Thacks
Custom element doesn't exist custom:hui-horizontal-stack
Hi @Mattias_Persson
I am trying to change the theme of a button-card. The problem is that I don’t know how to identify each property of the theme you created. Is there any reference to how the botton is composed to know how to apply the colors you want?
Thanks a lot
denisj
(Denis Joshua)
December 21, 2021, 6:18am
2226
Hi there,
I just begin to setup this wonderful theme, but at the first start I have an error:
Can someone tell me how to solve this please ?
Thanks a lot
Denis
weemaba999
(Bart Weemaels)
December 21, 2021, 9:48am
2227
Hi Giblet,
I’ve been trying to implement the Curtains SVG, but I can’t help the fact that it returns like this in my dashboard:
Do you have any idea what I’m doing wrong ?
Kr,
Bart
Code:
entity: cover.gordijnen
icon_curtains_combined:
styles:
custom_fields:
icon:
- width: 70%
- stroke: >
[[[ return variables.state === ‘closed’ ? ‘#3181b7 ’ : ‘#9da0a2 ’; ]]]
custom_fields:
icon: >
[[[ if (entity.state === ‘open’) return ’
else return ’ ‘; ]]]
Tolrac
(David Gillet)
December 21, 2021, 11:15am
2228
I love your dashboard template. I wanted to know if it is possible to have the code of your ui-lovelace.yaml and your button_card_templates.yaml to combine 1/1 and 4/1 ratio tiles as in the screenshot
kaaspad
(Kaaspad)
December 21, 2021, 11:35am
2229
Hi I have two unrelated questions…
I’m having an issue with the sidebar template, I’ve implemented two versions of the sidebar for two different languages which are two different dashboards.
I essentially copied the sensor with unique ID “sidebar” again and changed the language - so now I have in template.yaml:
- unique_id: sidebar
state: template
and below that:
- unique_id: sidebarheb
state: template
then in my custom_lovelace files, I tried for english version:
- type: vertical-stack
view_layout:
grid-area: sidebar
cards:
- type: custom:button-card
entity: sensor.template_sidebar
template: sidebar_template
and for hebrew version:
view_layout:
grid-area: sidebar
cards:
entity: sensor.template_sidebarheb
but still getting them both in english, when I tried completely renaming the sidebar one, I get nothing on both. Any help on this would be greatly appreciated.
Second question - is there a way to change the language of home assistant by clicking on a button (by calling some service)? Currently I only see a way to do this manually by going to profile and changing language - the use case is when I switch between my different dashboards I want to change the language as well.
Thanks!!!
denisj
(Denis Joshua)
December 21, 2021, 11:49am
2230
I don’t know how… but I have solved
The problem now is that I have bad colors/css/etc…
Someone know why please ?
Thanks all
Denis
Have you checked your yaml indentation and logs? Your example “and below that:” is wrong.
Have a look in dev tools to see if your templates return something
I don’t think so Home Assistant frontend - Home Assistant
Check input_select.conditional_media
in dev-tools to see if the automation actually changes the state
https://www.home-assistant.io/docs/automation/troubleshooting/
