Steve;
Can u share your code for climate card (Living Room Heating)? Like the look and how temp is shown.
Steve;
Sure, here you go. The part from ui-lovelace.yaml
- type: custom:button-card
entity: media_player.sony_bravia_tv
lock:
enabled: true
state_display: >
if (states['media_player.sony_xr_55a84j'].state === 'playing') {
return states['media_player.sony_xr_55a84j'].attributes.app_name;
custom_fields:
c1: >
[[[ return states['media_player.sony_xr_55a84j'].attributes.app_name === 'Netflix' ? `<ha-icon icon='mdi:netflix'></ha-icon>` : ' '; ]]]
styles:
custom_fields:
c1:
- position: absolute
- left: 60%
- bottom: 50%
- margin-right: 15px
hold_action:
!include popup/kamer_tv.yaml
template:
- base
- icon_tv
- loader
And add this to base
template in button_card_templates.yaml
custom_fields:
c1:
- font-family: Sf Display, Roboto
- font-size: 80%
- text-align: justify
- left: 10%
- bottom: 36%
- color: >
return variables.consider_on ?
'rgba(0, 0, 0, 0.6)' :
'rgba(255, 255, 255, 0.3)';
Some additional info:
state_info
that’s why you see the status in the upper right cornder.ui-lovelace.yaml
for the Sony TV entity.Can you please share your garagedoor icon and camera icon ? Please
@Mattias_Persson I tried integrating your recent footer changes into my fork of your config. As far as I see, I transfered all changes from themes.yaml, ui-lovelace.yaml, button_card_templates.yaml but on my Tablet the footer is cut of and you need to scroll down to see the entire button.
Is this expected or did I miss something? Thanks
Hey I think your panel is very clever, is there any way you could share the code of your cards? ^^
Julien
Hey, I know it’s not really related to the topic but someone could help me solve my problem,
So my problem is that I tried to call various services from my camera, problem, when I run it, it tells me that it needs an entity_id, area_id and other… but I tried but I don’t know how to include it knowing that I found that it works on a classic button and not on the custom button. More precisely I want to make like for the switch a button that makes both switch on and switch off the switch
- type: horizontal-stack
cards:
icon: mdi:motion-sensor
tap_action:
action: call-service
service: switch.motion_detection
entity_id: switch.motion_detection
template: icon_only
entity: camera.garage
icon: mdi:flashlight
tap_action:
service: switch.garage.light
entity_id: switch.garage.light
template: icon_only
icon: mdi:eye
tap_action:
service: switch.garage.night_vision
entity_id: switch.garage.night_vision
template: icon_only
Can anyone tell me how to do this? Thank you in advance ^^
Julien
Yep, I’ve noticed this too.
I added an extra line to the grid config sothe buttons are sitting on the bottom, but it still doesn’t fit on the screen.
We can adjust the grid spacing to try and fit it all in though.
Thanks, worked like a charm!
I think about putting the config on GitHub at some point. If there is anything specific you like, just ask and I’m happy to provide the config
I’d like to adapt this to my own setup. It’s not quite as complex as what you’ve done with it and since I’m completely new to anything Javascript more complex than “if this then that”, I’m a bit lost.
Basically, I’m trying to have the following returned if the text is longer than the container:
return `<marquee scrolldelay='200'>${states['media_player.bubble'].attributes['media_artist']} - ${states['media_player.bubble'].attributes['media_title']}</marquee>`;
and this if the text fits within the container:
return states['media_player.bubble'].attributes['media_artist'] + ' - ' + states['media_player.bubble'].attributes['media_title'];
This part of the code works, but I’m struggling with the “if text is wider than the container, show 1 else show 2” part. I’ve tried several combinations, here’s the latest that doesn’t work, based on what I’m trying to grasp from this code by Mattias:
label: >
[[[ var element = this.shadowRoot
var state = element.getElementById("state")
var container = element.getElementById("container")
if (state.width >= container.width) return `<marquee scrolldelay='200'>${states['media_player.bubble'].attributes['media_artist']} - ${states['media_player.bubble'].attributes['media_title']}</marquee>`;
return states['media_player.bubble'].attributes['media_artist'] + ' - ' + states['media_player.bubble'].attributes['media_title']; ]]]
If anyone has any pointers, I’d much appreciate it.
Hi, kan jij wellicht jouw ui-lovelace.yaml delen?
Hi All,
Just wondered if anyone knows how to allow titles of custome:button_cards to go over two lines?
All of the worlds i use to describe the entity are too long.
Any help would be really appreciated.
This does exactly that
You might be missing the extra styles class and animation “marquee”
I might have an odd resolution idk 16:10 (1920x1200)
Here’s the theme variables for what @wjbeckett said about grid spacing
custom-layout-card-padding
grid-card-gap
and maybe “GRID CARD HEADINGS h1 font-size/ padding”
Yep. That’s the ones.
I adjusted the custom-layout-card-padding which helped. Don’t over do it though, otherwise the view becomes cluttered and messy. Same goes for grid-card-gap. Adjust with caution
@Mattias_Persson What tablet are you using? Still the Galaxy Tab A 10.1? I thought the screen was 1920x1080 on those?
Yeah still that tablet, I don’t recommend it though. From what I can find it’s 1920x1200
Oh you don’t? Have you had issues with it?
Is yours the one with the capacitive buttons?
I’ve been searching around for a new tablet so keen to know your challenges with this one.
I don’t believe there’s any capacitive buttons.
It works fine but if I open a popup with loads of cards it takes over 1 sec to actually pop up and the animations are sometimes below 30fps. But I’m comparing a ~$200 device to iphone/imac which are not $200…
