which one do you mean?
from the watched state in upper right or the under the title?
I mean the button-card made for the blur-overlay
I saw you had the same problem like me with the blur over the text
yeah correct, i added “- z-index: 1” all labels and icons get the z-index, only the blur get nothing. and then it works, its the priority of the layers.
what is the state of sensor.easee_einfahrt_wallbox_power ?
the green circle is there because you define it,
[[[ if (states['sensor.easee_einfahrt_wallbox_power'].state >= '0.1')
return '<img src="/local/loader.svg" width="100%">' ;
when the state is 0.1 or above, he shows the green circle.
The green circle is always there.
via an If statement I managed that the “loader” is only displayed when the car is loaded.
But i am not so good in javascript, how can i create an if statement that the green circle is NOT shown when the car is loaded?
circle: >
if (Math.round(states['sensor.e208_battery_level'].state) > 0 && states['sensor.easee_einfahrt_wallbox_power'].state >= '0.1') {
const input = Math.round(states['sensor.e208_battery_level'].state);
const radius = 21.5;
const circumference = radius * 2 * Math.PI;
i added a second condition behind the first
test it please
thank you, now it works as i expected it to.
I did not know that I can link two conditions with &&.
You can link how much you want. It gives a || (or) too.
does anyone else have there sensor.plex_recently_added just showing state online. so it get an error in the UI?
thats an intresting take on an issue i had, i solved this with input selects. this is the result.
this is the code for the button:
- type: custom:button-card
entity: input_select.climate_kids
hold_action:
!include ../popup/climate/kids_climate.yaml
template:
- base
- icon_fan2
- state_select
state_select template is in button card template:
state_select:
variables:
state_on: >
[[[ return entity === undefined ? false : entity.state !== 'off' ]]]
tap_action:
action: call-service
service: input_select.select_next
service_data:
entity_id: >
[[[ return entity.entity_id]]]
double_tap_action:
service: input_select.select_option
service_data:
option: 'off'
entity_id: >
I have a few automation in place. One set the fan speed of the zone when the state of the input select updates, one that sets the input select when the fanspeed updates, and one that sets all the zones to medium if all are off and the aircon is turned on and sets the input selects all to off when the aircon is toggled off
I also use the state_select template to set lighting scenes on rooms that have more than one common lighting mode
I get this error when my plex API is down, restarting plex fixes is. looks like sometimes the plex API brakes, the plex app still works but any 3ed party app will have issues.
Good afternoon. I have the same problem, did you succeed in solving this problem?
did you copy the themes.yaml to your root directory?
Yes, thank you. Sidebar appeared, there was an error in the folder name. But it appeared empty. In which file to look for sidebar settings?
Hello guys,
I don’t use Plex at the moment and I don’t see any use for it so far.
Nevertheless, I find the idea of upcoming movies or new episodes of favorite series on Netflix interesting.
Is there a way to show them in the “Media” card?
I currently use the following streaming providers: Neflix, Prime, Disney+.
When someone makes a integration of course.
You can parse the website and save the infos and fill the sensors.
But I don’t know a integration
Hi, maybe you need this - Upcoming Media Card
Hi Mattias, this looks great, thank you very much for sharing it.
I am trying to adopt it to my setup and I am bit new to HA.
Can you help me find out how I can change the language in the sidebar ?
I also have a Unifi Dream Machine but for some reason the Unifi Network Integration is not creating the memory, cpu entities for it. any pointers would be really great
you need to adjust your template.yaml
