A different take on designing a Lovelace UI
I had font problems on some devices. Specifically I was using amazon Fore OS Fire 7" which internally uses a really old browser engine. I had to wipe the device and install LineageOS which comes with a much more modern browser engine.
Another example of problems with the amazon Fire OS Fire 7" was the spinning round fan icons in this repo. It was not able to render those. LineageOS no problem.
I’m not sure if this will resolve your issue but it might explain why it works on some devices and not on others.
Hi all,
There’s been some great work shown here on the forum.
Thanks for all of that!
I was wondering if anyone could help me with a strange issue I am encountering:
I have the below code for the picture there after.
popup_cards:
  light.tv_light:
    title: Light Control
    style:
      position: fixed
      z-index: 999
      top: 0
      left: 0
      height: 100%
      width: 100%
      display: block
      align-items: center
      justify-content: center
      background: 'rgba(0, 0, 0, 0.8)'
      flex-direction: column
      margin: 0
      '--iron-icon-fill-color': '#FFF'
    card:
      type: 'custom:light-popup-card'
      entity: light.tv_light
      icon: 'mdi:lightbulb-on-outline'
      actionsInARow: 2
      brightnessWidth: 150px
      brightnessHeight: 400px
      switchWidth: 150px
      switchHeight: 400px
      actions:
        - service: light.turn_on
          service_data:
            entity_id: light.tv_light
            color_temp: 153
          color: "#d8d9e1"
          service_data:
            color_temp: 326
          color: "#d5b08d"
          service_data:
            color_temp: 500
          color: "#ce944b"
        - service: browser_mod.popup
          service_data:
            title: Stäng
            deviceID: this
            style:
              --ha-card-border-radius: 1em
              --more-info-header-color: rgba(255,255,255,0.6)
              background: none
              box-shadow: none
            card:
              type: entities
              title: Färginställningar
              style: # *popup_style
              show_header_toggle: false
              entities:
                - entity: light.tv_light
                  secondary_info: last-changed
                - type: custom:light-entity-card
                  style:
                      ha-card {
                        background: none; box-shadow: none; margin: -0.5em -1em -0.5em -0.7em; }
                      ha-card > div.light-entity-card-sliders.ha-slider-full-width {
                        margin-bottom: 0.75em; }
                      ha-card > div.light-entity-card-sliders.ha-slider-full-width > div > ha-icon {
                        margin: auto; width: 34px; height: 34px; cursor: default;
                        padding-right: 0.49em; color: var(--paper-item-icon-color);}
                      ha-card > div.light-entity-card-sliders.ha-slider-full-width > div > div {
                        margin: auto; padding: 0 1.4em 0 1em; max-width: 1em; cursor: default;}
                    'ha-card > div.light-entity-card-sliders.ha-slider-full-width > div > ha-slider':
                        #sliderContainer {
                          --calculated-paper-slider-height: var(--paper-slider-height, 5px); }
                  brightness: false
                  color_temp: true
                  full_width_sliders: true
                  header: false
                  show_slider_percent: true
                  smooth_color_wheel: true
Now in the script you will find
When I uncomment this line I get the following error:
As you can see in the first picture, If I comment this line my entire screen gets blurred. I am still able to exit it by clicking on the outskirts of the screen.
What am I doing wrong?
Cheers!
Thank you, maybe that could be the case, but my PC is running Win10 with the latest updates. I can’t imagine that that is the problem in my case.
I tried to figure it out, but no succes. I can’t find the right place where it determines the width and the height for the screen. Also, on my tablet the size of the light popup is to big, when I want to slide the brightness down, it also scrolls down (a little).
Hello, I’m the same. I have tried to modify the button size but this happens. Ignore the other buttons on the card and it is positioned in the upper left. It is the same with everyone when I modify them. The template code is the same as that of your configuration. The buttons are adapted in terms of size depending on the buttons you have in that row of the letter and depending on the size of the screen where you see it but I can not set it as you want.
styles:
  card:
    - width: 7vw
    - height: 7vw
imagen
custom_fields:
  icon_fan: >
    [[[ const path = '<circle cx="25" cy="25" r="6.6"/> <path d="M31.9
    30.4c-.5.6-1.1 1.1-1.7 1.5-1.4 1.1-3.2 1.7-5.2 1.7-2.3 0-4.5-.9-6-2.4-.9
    1.1-1.6 2.3-2.3 3.2l-4.9 5.4c-1.8 2.7.3 5.6 2.5 7 3.9 2.4 9.8 3.1 14.1 1.9
    4.6-1.3 7.9-4.7 7.4-9.7-.2-3.4-1.9-6-3.9-8.6zM17
    28.3c-.4-1-.6-2.1-.6-3.3a8.7 8.7 0 0 1 6.4-8.4l-1.6-3.5L19
    6.2c-1.5-2.8-5-2.5-7.3-1.2-4 2.2-7.5 6.9-8.7 11.3-1.2 4.6.2 9.2 4.7 11.3 3.1
    1.3 6.1 1.2 9.3.7zm26.9-17.6c-3.3-3.4-8-4.6-12.1-1.8-2.8 1.8-4.2 4.6-5.5 7.5
    4.2.6 7.4 4.2 7.4 8.6 0 .9-.1 1.7-.4 2.5 1.3.2 2.8.3 3.8.4 2.3.4 4.7 1.3 7.1
    1.7 3.2.3 4.7-3 4.8-5.6.3-4.6-1.9-10.1-5.1-13.3z"/>';
     const style = '<svg viewBox="0 0 50 50"> <style>@keyframes rotate{0%{visibility: visible; transform: rotate(0deg);}100%{transform: rotate(1080deg);}}.start{animation: rotate 2.8s ease-in; transform-origin: center; fill: #5daeea; visibility: hidden;}.on{animation: rotate 1.8s linear infinite; transform-origin: center; fill: #5daeea; animation-delay: 2.8s; visibility: hidden;}.end{animation: rotate 2.8s; transform-origin: center; fill: #9ca2a5; animation-timing-function: cubic-bezier(0.61, 1, 0.88, 1);}</style>';
     if (entity.state === 'on') { return `${style}<g class="start">${path}</g><g class="on">${path}</g></svg>`; }
     else { return `${style}<g class="end">${path}</g></svg>`; } ]]]
entity: switch.velocidad_baja
style:
  left: 80.05%
  top: 37.9%
  width: 10%
styles:
  card:
    - width: 7vw
    - height: 7vw
  custom_fields:
    icon_fan:
      - top: 9%
      - left: 10%
      - width: 3vw
      - position: absolute
tap_action:
  action: toggle
template: switch
type: 'custom:button-card'
The card config:
  - cards:
      - custom_fields:
          icon_fan: >
            0-4.5-.9-6-2.4-.9 1.1-1.6 2.3-2.3 3.2l-4.9 5.4c-1.8 2.7.3 5.6 2.5 7
            3.9 2.4 9.8 3.1 14.1 1.9 4.6-1.3 7.9-4.7
            7.4-9.7-.2-3.4-1.9-6-3.9-8.6zM17 28.3c-.4-1-.6-2.1-.6-3.3a8.7 8.7 0
            0 1 6.4-8.4l-1.6-3.5L19 6.2c-1.5-2.8-5-2.5-7.3-1.2-4 2.2-7.5 6.9-8.7
            11.3-1.2 4.6.2 9.2 4.7 11.3 3.1 1.3 6.1 1.2
            1.3 7.1 1.7 3.2.3 4.7-3 4.8-5.6.3-4.6-1.9-10.1-5.1-13.3z"/>';
        style:
          left: 80.05%
          top: 37.9%
          width: 10%
        styles:
          card:
            - width: 7vw
            - height: 7vw
          custom_fields:
            icon_fan:
              - top: 9%
              - left: 10%
              - width: 3vw
        tap_action:
          action: toggle
        template: switch
      - custom_fields:
          icon_fan: >
        entity: switch.velocidad_media
        style:
          left: 80.05%
          top: 37.9%
          width: 10%
        styles:
          custom_fields:
            icon_fan:
              - top: 9%
              - left: 10%
              - width: 3vw
        tap_action:
          action: toggle
        template: switch
      - custom_fields:
          icon_fan: >
        entity: switch.velocidad_alta
        style:
          left: 80.05%
          top: 37.9%
          width: 10%
        styles:
          custom_fields:
            icon_fan:
              - top: 9%
              - left: 10%
              - width: 3vw
        tap_action:
          action: toggle
        template: switch
    type: horizontal-stack
  - cards:
      - custom_fields:
          icon_hue: >
            [[[ const state = entity.state === 'on' ? 'animate' : null; return
            `<svg viewBox="0 0 50 50"><style>@keyframes animate{0%{transform:
            scale(0.85);}20%{transform: scale(1.1);}40%{transform:
            scale(0.95);}60%{transform: scale(1.03);}80%{transform:
            scale(0.97);}100%{transform: scale(1);}}.animate{animation: animate
            0.8s; transform-origin: center;}</style> <path fill="#9da0a2"
            d="M27.4 47.3h-4.9s-.7.1-.7.8.4.9.7.9h4.9c.3 0
            .7-.1.7-.9s-.7-.8-.7-.8zm3.3-2.9H19.3s-.8 0-.8.8.6.9.8.9h11.5c.2 0
            .8-.1.8-.9-.1-.8-.9-.8-.9-.8zm0-3H19.3s-.8 0-.8.8.6.9.8.9h11.5c.2 0
            .8-.1.8-.9-.1-.8-.9-.8-.9-.8zm0-2.9H19.3s-.8 0-.8.8.6.9.8.9h11.5c.2
            0 .8-.1.8-.9s-.9-.8-.9-.8zm5.2-23.2c-3.3-5.3-7-5.6-10.9-5.6-3.8
            0-8.4.4-10.9 5.6-.1.1-.1.3.1.7.4.8 3.3 7.2 3.2 18.8 0 1.1-.1 1.6 0
            1.7 0 .1 0 .7 1.1.7h13c1 0 1-.5 1.1-.7v-1.7c-.1-11.6 2.8-18
            3.2-18.8.1-.4.1-.5.1-.7"/> <path class="${state}"
            fill="var(--button-card-light-color-no-temperature)" d="M14.1
            15.3c3.4-.3 7-.4 10.9-.4 3.8 0 7.5.2 10.9.4.4-.4.7-.8.9-1.1C39 8.5
            38.9 6.5 38.9 6c-.2-4.4-8.4-5-12.1-5h0-3.4c-3.7 0-12 .5-12.1 5 0
            .5-.1 2.5 2.1 8.2 0 .3.3.8.7 1.1z"/></svg>`; ]]]
        entity: switch.on_off_luz
        style:
          left: 30.31%
          top: 20.35%
          width: 10%
        styles:
          custom_fields:
            icon_hue:
              - top: 11%
              - left: 4.5%
              - width: 3.05vw
        template: light
      - custom_fields:
          icon_fan: >
            <svg viewBox="0 0 1150 1150"><path d="M316.54 164.3c-48.85
            20.66-92.713 50.232-130.373 87.893s-67.23 81.524-87.893
            130.375c-21.4 50.592-32.25 104.313-32.25 159.675s10.85 109.083 32.25
            159.675c20.66 48.85 50.232 92.713 87.893 130.373s81.524 67.23
            130.373 87.893c50.592 21.398 104.314 32.248 159.675
            32.248s109.083-10.85 159.675-32.25c48.85-20.66 92.713-50.23
            130.373-87.893s67.23-81.524 87.893-130.373c21.398-50.592
            32.25-104.314
            32.25-159.675s-10.852-109.083-32.25-159.676c-20.66-48.85-50.232-92.713-87.893-130.374l-1.328-1.297
            18.656-19.75 34.818 29.54 44-51.854-118.792-100.783-43.992 51.854
            32.05 27.2-18.875
            19.982c-23.94-16.935-49.645-31.244-76.9-42.773a407.64 407.64 0 0
            0-61.477-20.432V68h54.727V0H323.3v68h54.727v75.868c-20.92
            5.147-41.445 11.96-61.476 20.432zm501.864 377.94c0 91.4-35.594
            177.333-100.225 241.965S567.617 884.43 476.215 884.43 298.882
            848.837 234.25 784.206 134.025 633.644 134.025 542.24 169.62 364.907
            234.25 300.276c40.77-40.77 90.02-69.97 143.766-85.985 22.003-6.557
            44.76-10.9 68-12.9 9.986-.867 20.057-1.33 30.2-1.33a349.06 349.06 0
            0 1 30.199 1.331c23.24 2.02 45.998 6.353 68 12.9 53.748 16.016
            102.996 45.216 143.766 85.985 64.63 64.63 100.224 150.563 100.224
            241.965zM446.016 70.112h60.398v63.03a418.36 418.36 0 0
            0-30.2-1.09c-10.126 0-20.193.367-30.2 1.1v-63.03zm30.2
            167.67v68c7.832 0 15.603.38 23.298 1.128 54.36 5.282 104.78 29.005
            143.902 68.13 44.662 44.662 69.258 104.042 69.258 167.202 0
            11.352-.805 22.576-2.375 33.645L574.2
            535.7c-3.373-51.114-46.023-91.67-97.976-91.67-54.147 0-98.2
            44.052-98.2 98.2s44.052 98.197 98.2 98.197c32.167 0 60.77-15.547
            78.693-39.52l199.73 58.954 2.096.887c15.887-37.556 23.94-77.432
            23.94-118.52
            0-81.323-31.668-157.78-89.174-215.285-33.518-33.518-73.48-58.238-117.084-73.046-31.207-10.594-64.276-16.125-98.2-16.125zm0
            334.657a30.15 30.15 0 0
            1-8.547-1.238c-12.5-3.696-21.652-15.276-21.652-28.96 0-16.652
            13.547-30.2 30.2-30.2a30.14 30.14 0 0 1 8.548 1.239c12.5 3.695 21.65
            15.275 21.65 28.96.001 16.65-13.546 30.197-30.198 30.197z"/></svg>
        entity: switch.temp_2h
            if (states["timer.temp2h"].state == 'idle') return "TIEMPO 2H";
            else return states["timer.temp2h"].state
        show_state: false
        style:
          left: 80.05%
          top: 37.9%
          width: 10%
        styles:
          custom_fields:
            icon_fan:
              - top: 13%
              - left: 10%
              - width: 3.5vw
        tap_action:
          action: toggle
        template: switch
      - custom_fields:
          icon_fan: >
            32.25-104.314
            32.05 27.2-18.875
            23.94-118.52
        entity: switch.temp_4h
            if (states["timer.temp4h"].state == 'idle') return "TIEMPO 4H";
            else return "Quedan:"
        show_state: false
        style:
          left: 80.05%
          top: 37.9%
          width: 10%
        styles:
          custom_fields:
            icon_fan:
              - top: 13%
              - left: 10%
              - width: 3.5vw
        tap_action:
          action: toggle
        template: switch
      - custom_fields:
          icon_fan: >
            32.25-104.314
            32.05 27.2-18.875
            23.94-118.52
        entity: switch.temp_8h
            if (states["timer.temp8h"].state == 'idle') return "TIEMPO 8H";
        show_state: false
        style:
          left: 80.05%
          top: 37.9%
          width: 10%
        styles:
          custom_fields:
            icon_fan:
              - top: 13%
              - left: 10%
              - width: 3.5vw
        tap_action:
          action: toggle
        template: switch
type: vertical-stack
I’m trying to add some battery information to one of my panels. I have it working but it looks terrible.
It is using
  • type: custom:battery-state-card
Should I be trying to embed this card into a button card like everything else (if this is possible) or style the card manually to match the others in this repo.
Here is what I have added (I’m using most of the configuration from this repo)
I would like to have this with rounded corners, the light grey color in the rest of this repo.
Need guidance on how to get this integrated, Thanks!
          - type: custom:battery-state-card
            title: "Battery Status"
            secondary_info: last_updated
            filter:
              include:
                - name: entity_id
                  value: "*_battery_level"
                - name: attributes.device_class
                  value: battery
              exclude:
                - name: entity_id
                  value: "*ipad*"
                - name: entity_id
                  value: "*iphone*"
            bulk_rename:
                to: "sensor"
                to: " temp. "
            sort_by_level: "asc"
            collapse: 4
            color_gradient:
              - "#ff0000" # red
              - "#ffff00" # yellow
              - "#00ff00" # green
            style:
              top: 35%
              left: 42%
Hi, I have made this animated svg icon of a running timer but i dont know how to enter it into the code. I cannot reduce the code with SVG Editor. I have tried but I can’t find the key. Can you help me?
imagen
<?xml version='1.0' encoding='UTF-8' standalone='no'?>
<!DOCTYPE svg PUBLIC '-//W3C//DTD SVG 1.1//EN' 'http://www.w3.org/Graphics/SVG/1.1/DTD/svg11.dtd'>
<!-- Animated using aniGen version 0.8.1 Quality of Life - http://anigen.org -->
<svg width="48px" height="48px" fill="black" version="1.1" viewBox="0 0 24 24" xmlns="http://www.w3.org/2000/svg" xmlns:cc="http://creativecommons.org/ns#" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#" id="svg7732" preserveAspectRatio="xMidYMid" xmlns:svg="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd" xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape" xmlns:anigen="http://www.anigen.org/namespace" anigen:version="0.8.1">
 <defs id="defs3350"></defs><sodipodi:namedview id="base" bordercolor="#666666" borderopacity="1" inkscape:cx="18.445267433524364" inkscape:cy="-8.97624006544654" inkscape:zoom="16.000000000000004"></sodipodi:namedview><metadata id="metadata1742">
  <rdf:rdf id="rdf:rdf6886">
   <cc:work rdf:about="" id="cc:work9873">
    <dc:format id="dc:format114">image/svg+xml</dc:format>
    <dc:type rdf:resource="http://purl.org/dc/dcmitype/StillImage" id="dc:type1365"></dc:type>
    <dc:title id="dc:title195"></dc:title>
   </cc:work>
  </rdf:rdf>
 </metadata>
 <path d="M0 0h24v24H0z" fill="none" id="path1185"></path>
 <path transform="scale(.5)" d="m18 2v4h12v-4zm6 6c-9.94 0-18 8.06-18 18s8.04 18 18 18 18-8.06 18-18c0-4.24-1.4795-8.1407-3.9395-11.221l2.8398-2.8398c-0.86-1.02-1.8003-1.9803-2.8203-2.8203l-2.8398 2.8418c-3.1-2.48-7.0002-3.9609-11.24-3.9609zm0 4c7.74 0 14 6.26 14 14s-6.26 14-14 14-14-6.26-14-14 6.26-14 14-14zm0.52148 5.5879c-0.0063 0.0054-0.01322 0.01018-0.01953 0.01563 0.0039 8.24e-4 0.0079 7.18e-4 0.01172 2e-3 0.0031-0.0058 0.0047-0.01178 0.0078-0.01758zm0.12695 6.7109c-0.0026 2.37e-4 -0.0052 0.0017-0.0078 2e-3 6.84e-4 0.0039 0.0012 0.0078 2e-3 0.01172 0.0018-0.0046 4e-3 -0.0091 0.0059-0.01367z" stroke-width="2" id="path9266"></path>
 <rect x="11" y="8" width="2" height="6" fill="#000" fill-rule="evenodd" stroke-width=".5" inkscape:transform-center-x="-0.12658317441930933" inkscape:transform-center-y="1.6503689031462212" id="rect4289"><animateTransform attributeName="transform" attributeType="auto" type="rotate" values="1.1614052573951312 12.082738110421964 12.604827265860937;1.1614052573951312 12.082738110421964 12.604827265860937" calcMode="spline" keyTimes="0;1" keySplines="0 0 1 1" dur="10s" begin="0s" repeatCount="1" additive="sum" accumulate="none" fill="freeze" id="animateTransform7802"></animateTransform><animateTransform attributeName="transform" attributeType="auto" type="rotate" values="358.79 11.994349762773645 12.56063309203678;358.79 11.994349762773645 12.56063309203678" calcMode="spline" keyTimes="0;1" keySplines="0 0 1 1" dur="5s" begin="0s" repeatCount="indefinite" additive="sum" accumulate="none" fill="freeze" style="" id="animateTransform6441"><animateTransform attributeName="transform" attributeType="auto" type="rotate" values="0 11.994349762773645 12.753875785289079;365 11.994349762773645 12.753875785289079" calcMode="spline" keyTimes="0;1" keySplines="0 0 1 1" dur="5s" begin="0s" repeatCount="indefinite" additive="sum" accumulate="none" fill="freeze" id="animateTransform1546"></animateTransform></animateTransform><animateTransform attributeName="transform" attributeType="auto" type="rotate" values="0 11.950155588949485 12.6212932638166;360 11.950155588949485 12.6212932638166" calcMode="spline" keyTimes="0;1" keySplines="0 0 1 1" dur="10s" begin=";1s" repeatCount="1" additive="sum" accumulate="none" fill="freeze" id="animateTransform9188"></animateTransform><animateTransform attributeName="transform" attributeType="auto" type="rotate" values="0 12.007767433524364 12.788740065446536;90 12.007767433524364 12.788740065446536;180 12.007767433524364 12.788740065446536;260 12.007767433524364 12.788740065446536;320 12.007767433524364 12.788740065446536;360 12.007767433524364 12.788740065446536" calcMode="spline" keyTimes="0;0.2;0.4;0.6;0.8;1" keySplines="0 0 1 1;0 0 1 1;0 0 1 1;0 0 1 1;0 0 1 1" dur="10s" begin="0s" repeatCount="indefinite" additive="sum" accumulate="none" fill="freeze" id="animateTransform3242"></animateTransform><animateTransform attributeName="transform" attributeType="auto" type="rotate" values="0 11.945267433524364 12.976240065446536;180 11.945267433524364 12.976240065446536;360 11.945267433524364 12.976240065446536" calcMode="spline" keyTimes="0;0.5;1" keySplines="0 0 1 1;0 0 1 1" dur="10s" begin="0s" repeatCount="indefinite" additive="sum" accumulate="none" fill="freeze" id="animateTransform2547"></animateTransform></rect>
</svg>
Hi Frank,
Would you mind sharing your code for the below pop-up?
It looks very slick.
In addition, I was wondering if you know it to be possible to place this kind of slider on the home page, (So not in a pop-up)
Looking forward to hear from you.
@Mattias_Persson how can i resize the icon? If i put my iPhone in horizontal mode the icon is bigger but not in vertical mode.
Skärmavbild 2020-06-28 kl. 18.46.46
Hi, i have it from Lukevinks Repo, but atm i dont use it.
You find it here: hass-config-lajv/www/js/light-slider-card-lajv.js at 2543d441fa2b5a448d794a83d58d348b5acf9421 · lukevink/hass-config-lajv · GitHub
I fail when i try to put it in a Template :frowning:
Thanks! I will try to see if I can find some succes in implementing it!
Hey all, looking for some guidance here…
Some time back the top left Time in my test config based on this code, lost its formatting. It seem like the span formatting gets ignored. I think I did some updates and not sure where to go from here.
I have used the latest config from the github under the picture-element style, which does not seem to do anything for it either.
Has anyone else experienced this ? I did see some mention of changes for the card-mod maybe affecting this.
Thanks!
I had real trouble with the markdown section and I just couldn’t get it to work reliably for me. I don’t use it now. For the time in the top left I have added two sections to the original code,
  ⚓4: &heading-style
    #color: '#bcbebf'
    color: '#ffffff'
    font-family: DB Sans Cond
    font-size: 4vw
    font-weight: bold
    font-style: normal
    max-width: 1px
    cursor: default
(change to your own font)
and then on each view add the following element
  - title: Main
    panel: true
    path: main
    cards:
      - type: picture-elements
        image: /local/images/background/uibg.png
        style:
            /* Global */
            #root > hui-icon-element {color: rgba(255, 255, 255, 0.1) !important; transition: 0.4s;}
            #root > hui-icon-element:hover {color: rgba(255, 255, 255, 0.25) !important; transition: none;}
            #root > hui-icon-element:active {color: rgba(255, 255, 255, 0.35) !important; transition: none;}
          "#root > hui-element > hui-markdown-card":
              ha-card > ha-markdown {padding: 0 !important;}
              ha-card > ha-markdown > p > font > ha-icon {margin-bottom: 0.15%; opacity: 0.6;}
              ha-card > ha-markdown > p > span {font-family: DB Sans Comp; font-size: 5vw;
              font-weight: 200; margin-left: -0.3vw; letter-spacing: -0.05vw;}
          "#root > hui-state-label-element":
              div {padding: 0 !important;}
        elements:
          - entity: sensor.time
            tap_action:
              action: none
            hold_action:
              action: none
            type: state-label
            style:
              top: 9%
              left: 3%
              <<: *heading-style
I also put the temperature in the same way with
          - entity: sensor.home_temp
            tap_action:
              action: none
            hold_action:
              action: none
            type: state-label
            style:
              top: 16%
              left: 3%
              z-index: 999
              <<: *heading-style
and the text ends up looking like this
So I actually just split the date out to a mardown card on its own, above the rest. That worked wonderful.
@Mattias_Persson i want to use this on more than 1 tablet so i want the same feature with sound, restart app etc so what is the best option, create a group for all my tablets?
First, @Mattias_Persson - THANK YOU for sharing you’re entire package. I won’t lie, as a newbie, I opened everything a few weeks ago, set it up and gave up because I didn’t think I could figure out how to set it up with my home. But, here we are a few weeks later and taking on this little project of reverse engineering your coding, I’ve got a very nice set up of my own that works! What I love even more, is that this set up adapts easily between different size tablets and I don’t end up with extra space on bigger tablets.
Everything is set up for the most part. I do have two question so far that’s come up. What or where do I change the size of cards within browser_mod for the pop-ups? I’m using the same pop up light card functionality for my hue lights on a hold action with a light entity card for color picking. But as you can see
, on my 8" tablets, the pop up light card and the color wheel aren’t in full view and I have to scroll down. (It works fine on my 10" tablets though!). I’m also getting the same issue with my sidebar vacuum pop up, where I have to scroll down to view everything in the pop up. Not sure if this is a setting in the individual cards within the pop up or if theres a general setting in the browser_mod card. I have tried changing values in CSS styles and within the .js files for the past 2 days and I can’t seem to figure it out.
My next question is with the sidebar: Where do i change the width of the sidebar? I tried changing the width % below, but when i decrease the size, it distorts the sidebar image and makes it shorter too.
- type: image
  image: local/sidebar.png
  tap_action:
     action: none
  hold_action:
     action: none
  style:
 {top: 50%, left: 10.6%, width: 21.5%, pointer-events: none, border-right: '1.5px solid rgba(58,69,73,0.2)'}
Bonus: Is there a website or video tutorial that you recommend for learning:
  • the CSS style coding you used in your files? When researching CSS styles in general, there’s a lot of information but it varies on the different types of coding it’s used in.
  • How you animated icons? I’ve downloaded illustrator and after effects and I think I’ve got a basic understanding of changing the icons using your current animations based on the posts earlier in this thread, but I’d like to learn more about creating my own animations if ever needed and uploaded to HA.
Popup
As you said using relative lengths like vw and % throughout the ui scales it well between different screen sizes. But I use the ui on both my 10" tablet display as well on my 27" computer and there my popups became ridiculously huge. So I settled on only using em units inside popups and I try to fit popups on the tablet first, then it'll look good on the computer too.
An entities card entity is fixed in size, I believe it's 14px font size. You'd have to use relative lengths (not em) or
it'll not scale well if you try to fit that into the bigger screen first. It's just the way it is.
I recently answered a similar "issue" in my repository:
I think the easiest solution is to reduce size/zoom in the browser itself.
The popup is sized after the content so your options are:
  • Remove entities, obviously..
  • Use a horizontal stack card to utilize the whole screen
  • Scale the whole card with transform
service_data:
  card:
    type: entities
    style: |
      ha-card {
        transform: scale(0.7);
Sidebar
Yup, changing the width scales it both x and y. The easiest way would be to push it out of view with like left: 6%. You can use an image with correct ratio or use css transform: scale property instead of width to actually distort the image.
Animation
After effects (gifs) is the old way but I switched over to svg's and there is unfortunately no comparable software for pure css animation. You have to do it by hand which is actually quite hard to get right/smooth. To help with easing animations I used easings.net for cubic-beziers. Another resource to see how to do different animations is Animatopy. I've also installed simonsiefke.svg-preview extension in VS Code to get a live preview when coding an animation.
is there a way to close a popup window after some time automatically?
  - alias: close_popups_on_tablet
    initial_state: true
      - platform: state
        entity_id: switch.fullykiosk_screensaver
        to: 'on'
        for:
          minutes: 15
      - service: browser_mod.close_popup
          deviceID: tablet
a stupid question, how to install this theme or all components the easiest way? has anyone found the best way?
:slight_smile:
