remove retain variable
Thank you so much Mattias!! that file was missing…
Thank you Mattias… now it works!
Thanks for that, had the time to give this a go over the last few days.
getting SSH working without needing a password on sinology DSM 6.0 was not fun, but I managed to get it all working, the command-line sensors you provided worked like a charm.
and after I installed multiple-entity-row the front end worked well, im a crazy that after 3 days setting this up I want to try and align amount and usage
@Mattias_Persson I updated the notify code for the Router / Network footer button, so its a little more generic and can be easily expanded with more unify products,
you still need to pass the binary_sensor.template_udm_internet in at the end but it no longer has any hard coded limits
- type: custom:button-card
<ha-icon icon="mdi:router-wireless"></ha-icon> Network
tap_action:
!include ../popup/footer/router.yaml
triggers_update:
- update.udmpro
- update.usl16p
- update.master_bedroom
- update.living_room
- binary_sensor.template_udm_internet
variables:
notify: >
let id = this._config.triggers_update;
if (states[id.pop()].state === 'off')
return true
return id.filter(e => states[e].state === 'on').length
template: footer
hi @henkkeumus, this could be unrelated, but I was making a change to my themes.yaml today and ended up with the missing background bug.
Turns out I had a missing bracket, after fixing that, and refreshing the frontend themes, BAM working background.
if you still have not fixed your issue, try replacing all of themes.yaml with a fresh copy from the GitHub.
Did you find a fix for this yet? I am having the same issue.
Hey guys. After updating home assistant to 2022.11.0, I got these thin gray borders around every card. Its most annoying on the sidebar, as well as on popups, but I wish I could remove it from every card. Tried changing button-card styles to border: none; but no success. Any help is very much appreciated, thanks!
It shouldn’t be misaligned, but you can edit it
#themes.yaml
card-mod-more-info-yaml: |
ha-icon-button$mwc-icon-button$button: |
mwc-ripple {
top: 5px;
left: 5px;
Thanks, that does help. But once its clicked, before the actual popup closes, i can see the circle bouncing around for like 0.2-0.3 seconds. If I remove the code you suggested, the circle is missaligned, but then in those 0.2-0.3 seconds it bounces into the correct place. Anyway, it is a very minor thing, so no worries. Thank you so much for your help!
Sorry for the delay. I use the Home Assistant app on my android, witch send to HA a lot of sensors, like: wifi i’m connected, the bluetooh connected, location, battery loading, and may others.
Is there a way to hide a section on certain devices? For example, I want the media section to show up on a large screen but not show up on on a phone screen. I tried to just not add the block but it made the layout all funky.
Yes it should be possible. Look at this section of the layout-card documentation.
update to 2022.11 borders, this doesn’t remove borders in other sections of ha
