A different take on designing a Lovelace UI
Ended perfect. style it with “max-height: 1px” and it only expands downwards.
@Mattias_Persson updated his repo to include the fix for the popups. Slightly changed the way styles was being handled they get loaded from the theme via classes and lovelace reference those classes. Check it out ran through the changes and got it going and popups look the way they did before.
Markdown does not render full html and I don’t think what you’re trying to do is possible. Your styles are also off. You end with a , instead of ;
If you want to style a specific tag you can target that from the top level picture elements and dig through shadow roots.
- type: picture-elements
  image: /local/background.png
  style:
    "#root > hui-markdown-card":
        "ha-card > ha-markdown":
            ha-markdown-element > p > span {
              font-size: 5vw;
  elements:
    - type: custom:hui-markdown-card
      style:
        top: 9%
        left: 11.1%
      content: >
        <span>Clock</span>
        other
Super, thanks a lot, got it working!!
Great
Do you mind sharing it? Mine is giving me some problems…
Thank you for updating your theme! It works very good with version 0.113.1. After integrating your style changes into my configuration, I noticed that no all my popups do have close icon in front of the popup title. If I open a hue popup, there is a close icon in front of the title but if I open the vacuum popup, the close icon is missing. Did I miss something to integrate or do you also have that phenomenon :)?
Try adding kiosk as a query var to your Lovelace address, e.g. http://IP:8123/lovelace/default_view?kiosk. This will hide the Home Assistant sidebar (specified in the first lines of the ui-lovelace.yaml file).
// Edit: Saw you updated your screenshot :-). Probably my solution approach will not fix your problem.
Getting closer, but not really loving it, so hope @Jason_hill, might have a great look for it.
And I wanna get in more that 3-4 events…
It’s intentional. I’ve set hide_header: true on popups with more than one card, otherwise the header spans all cards.
Oh it’s late in Germany… that was obvious, thank you :-). As I’m using the S5 Max, which is not supported by valetudo, I cannot use the map feature. Now it’s fine :-).
We’re in the same time zone then :innocent:
Great!
@Martin_Pejstrup
What are you trying to achieve with your calendar? Which calendar card do you use?
This template already counts the lights for you so adding a sensor that counts lights into that template doesn’t make sense. I’ve set it up to only count switches and lights.
Icons here /www/custom_icons.js. These are normal icons like mdi: that you put in lets say an entities card. All other icons are in ui-lovelace.yaml in each button card and are not listed.
Update browser_mod
Hi Mattias
Thanks for taking your time to answer me questions.
I’m using “github.com/ljmerza/calendar-card”, but tinkering with it I have gotten something I like.
Okay, so like this?Shouldn’t I be able to do this with media_player? They are not appearing…
    sidebar_active:
      value_template: >-
        {% set lights = [
          states.light.bad_1,
          states.light.bad_2,
          states.light.bryggers,
          states.light.carport,
          states.light.gang,
          states.light.have,
          states.light.kontor,
          states.light.kokken,
          states.light.lounge,
          states.light.sovevaerelse,
          states.light.spisestue,
          states.light.stue,
          states.light.terrasse,
          states.light.udendors,
          states.light.viktualierum,
          states.ight.vaerelse_nord,
          states.light.vaerelse_syd,
          states.light.walk_in,
        {% set lights_on = lights | selectattr('state','eq','on') | list %}
        {% set lights_name = lights | selectattr('state','eq','on') | map(attribute='name') | join(', ') %}
        {% set media_players = [
          states.media_player.stue,
          states.media_player.alrum,
          states.media_player.badevaerelse_1,
          states.media_player.bedroom_apple_tv,
          states.media_player.terrasse,
        {% set media_players_on = media_players | selectattr('state','eq','on') | list %}
        {% set media_players_name = media_players | selectattr('state','eq','on') | map(attribute='name') | join(', ') %}
        {% if (lights_on | length ==0 ) and (media_players_on | length > 0) %}
        {{ media_players_name | regex_replace(',([^,]*)$',' og\\1') }} er tændt
        {% elif (lights_on | length ==1) and (media_players_on | length == 1) %}
        {{ lights_name }} og {{media_players_name }} er tændt
        {% elif (lights_on | length ==1) and (media_players_on | length > 1) %}
        {{ lights_name }}, {{ media_players_name | regex_replace(',([^,]*)$',' og\\1') }} er tændt
        {% elif (lights_on | length > 1) and (media_players_on | length == 1) %}
        {{ lights_on | length }} lamper og {{ media_players_name }} er tændt
        {% elif (lights_on | length > 1 ) and (media_players_on | length > 1) %}
        {{ lights_on | length }} lamper, {{ media_players_name | regex_replace(',([^,]*)$',' og\\1') }} er tændt
        {% elif (lights_on | length ==1) and (media_players_on | length ==0) %}
        {{ lights_name }} er tændt
        {% elif (lights_on | length >1 ) and (media_players_on | length ==0) %}
        {{ lights_on | length}} lamper er tændt
        {% else %}
        <font color='#6a7377'>Alt er slukket</font>
        {% endif %}
Okay, thanks. I need to get started on learning how to do that :slight_smile:
Updated browser_mod. Not working, it feels like it’s because the swipe- card thinks I want to swipe when I’m holding??
Now that I have you… I have asked this in another tread:
Can someone help me change this button, so that it either:
  • Becomes depressed for xx secs
  • Is just a tap-button, meaning no depress animation? I just want to toogle a boolean for a automation
    I’m lost when it comes to styling.
          - type: custom:button-card
            entity: input_boolean.godnat
            style:
              top: 82.1%
              left: 91.05%
              width: 10%
            tap_action:
              action: toggle
            hold_action:
              action: none
            custom_fields:
              icon_home: >
                [[[ const state = entity.state === 'on' ? 'animate' : null;
                return `<svg viewBox="0 0 50 50"> <style>@keyframes animate{from, 20%, 40%, 60%, 80%, to{animation-timing-function: cubic-bezier(0.215, 0.61, 0.355, 1);}0%{transform: scale(0.3);}20%{transform: scale(1.1);}40%{transform: scale(0.9);}60%{transform: scale(1.03);}80%{transform: scale(0.97);}to{transform: scale(1);}}.animate{animation: animate 1s; transform-origin: center;}</style>
                <path class="${state}" d="M42.2 28.3c0-.8-.2-1-.2-1L26 12.1s-.5-.4-1-.4-1 .3-1 .3L8.2 27.1c-.4.5-.4.9-.4.9v18.3c0 1.1.9 2 1.9 2h8.2a1.47 1.47 0 0 0 1.5-1.5v-14a1.47 1.47 0 0 1 1.5-1.5h8.4a1.47 1.47 0 0 1 1.5 1.5v14a1.47 1.47 0 0 0 1.5 1.5h8.2c1.1 0 2-.9 2-1.9 0-.2-.3-18.1-.3-18.1zM7.3 25l-1.6 1.5s-.3.3-.5.3-.5 0-.8-.2c-.2-.2-2-2.8-2-2.8s-.1-.4-.1-.7c.1-.3.2-.7.3-.8.4-.1 21.5-20.1 21.5-20.1s.4-.3.9-.3c.4 0 .8.1.9.2s.5.4.5.4l8.9 8.5V6s.1-.4.2-.7c.1-.2.3-.3.4-.3s.3-.1.3-.1h3s.3.1.4.3a1.08 1.08 0 0 1 .3.7v9.8l7.2 6.9s.2.3.3.4c.1.2.1.7.1.7 0 .1-.1.4-.2.5s-1.6 2.5-1.6 2.5-.1.3-.3.3c-.2.1-.4.1-.7 0-.2-.1-.5-.4-.5-.4L26.4 9.4s-.3-.3-.5-.4-.4-.2-.8-.2-.5.1-.8.1c-.1.1-.4.3-.7.5C23.3 9.8 7.3 25 7.3 25z"/></svg>`; ]]]
            styles:
              card: [transition: all 0.3s ease-out]
              custom_fields:
                icon_home:
                  [top: 10.5%, left: 10.1%, width: 2.9vw, position: absolute,
                  fill: "[[[ return entity.state === 'on' ? '#c7983e' : '#9da0a2'; ]]]"]
            template: switch
Secondly and not so important, can I get a timer on the card that counts down from xx secs, after being pressed? Should be instead of the “Til”.
2020-07-26_22h26_31
Thanks in advance
(I should mention that I have used the great work of Mattias Persson)
There’s a good chance your media_player state isn’t on, but equal to playing. Like I said my template is only lights and switches so now you’ll have to add media to the logic…
{% set media = [states.media_player.stue, states.media_player.alrum] %}
{% set media_name = media | selectattr('state','eq','playing') | map(attribute='name') | join(', ') %}
{{ media_name }} är på
I don’t know then, it works here.
If you have a script as an entity in button-card the button will be on for as long the script is running. Have the script toggle input_boolean.godnat. Add a delay to the end of the script to set how long the button should be on.
You can override the state styles from the button_card_templates:
  state:
    - value: 'on'
      styles:
        card: [background-color: 'rgba(115, 115, 115, 0.2)']
        name: [color: 'rgba(255, 255, 255, 0.3)']
        state: [color: 'rgba(255, 255, 255, 0.3)']
I mean sure it’s possible but you may have to research how to do it in javascript or maybe use a timer. I’m using a timer for my laundry button-card.
Hi Mattias
Thanks for the help again :slight_smile:
Blockquote
Worked like a charm :slight_smile:
Blockquote
Holding won’t work in Chrome. Will try on the tablet later.
Blockquote
If you have a script as an entity in button-card the button will be on for as long the script is running. Have the script toggle input_boolean.godnat . Add a delay to the end of the script to set how long the button should be on.
Could be a nice solution with your second idea…
Tried your config, no result…
            state:
              - value: 'on'
                styles:
            style:
              top: 82.1%
              left: 91.05%
              width: 10%
            tap_action:
              action: toggle
            hold_action:
              action: none
            custom_fields:
              icon_home: >
            styles:
              custom_fields:
                icon_home:
            template: switch
Right?
What I really would like it to do is:
  1. Push to toggle the input_boolean
  2. Either be depressed (on) shortly as long as the automation takes or be on until ex. a light is turned on / lock is unlocked or for a defined time.
How would you go about that?
Thanks again :slight_smile:
But what you want is how it’s in my repo, forget input_boolean. Let a script do all the good night stuff and the button will be on while the script is executing
#button
  entity: script.godnat
  state_display: Auto
  style:
    top: 82.1%
    left: 91.05%
    width: 10%
#script
godnat:
  sequence:
    - service: light.turn_off
      entity_id: light.alla_lampor_utom_hall
    - delay:
        seconds: 4
All right, it was because the whole “Godnat” automation is done in Node-Red.
Can I do this below or would you suggest to do the whole thing in yaml?
I have been thinking about quitting Node-Red, but it’s sooooo easy to have the overview :slight_smile:
#script
godnat:
  sequence:
      entity_id: input_boolean.godnat
    - delay:
        seconds: 4
Hej Martin. Også dansker her :slight_smile: Do you wanna take it up in the danish forum on facebook.
Hi Jason
Actually I’ve gotten some way :slight_smile:
But since we are working on similar things let’s connect in there, I would like to see your weather integration.
I’m trying to figure out why you’ve created the popup in the way that you did. For example this config:
hold_action:
  action: call-service
  service: browser_mod.popup
  service_data:
    card:
      type: vertical-stack
      cards:
        - type: entities
          entities:
            - type: custom:light-popup-card
              entity: '[[[ return entity.entity_id ]]]'
Why the popup inside entities card inside vertical-stack. I know it works because I copied it and also have it working. When I try to take one of them out, it breaks. That’s what I don’t understand.
Second question, while I’m here. I’ve been following this thread almost since it began and browsing your repo every now and then. I see you made a change 2 days ago removing the animation on the popup entities card. I imagine you still want animation. I looked and could not see where it landed. Somewhere in the themes.yaml is my guess, but I didn’t spot it?
Thanks for sharing your hard work! Like so many others on this thread I’ve copied many of your ideas! :heart:,
