A different take on designing a Lovelace UI
Issue resolved.
i have followed the guide. Cant find it.
It works on lights but how do i setup for doors och windows?
Does anybody have icon for a switch for turning on/off electricity.
My setup is not done yeat
Hey All!
Anyone have any clue how to go about creating the following effect?:
I want to split the lower-right grid quadrant into 2 buttons essentially (my smart home is outgrowing my screen real estate and I hate the swipe card solution). When I do this in the lovelace.yaml alone by adding a nested grid card it definitely doesn’t like it so I’m assuming I need some new CSS in a new button card template (probably “base” and “extra styles”?) but I am not quite sure where to start modifying.
Any help is appreciated :slight_smile:
Thanks a million!
Can you post the code for the whether in the sidebar and also for the people. Looks amazing.
Do you have a floorplan as a background or is it a pic ?
If i have a smart light i can write the following
- type: custom:button-card
  entity: light.office_group_1
  template:
    - light
    - icon_hue
And I get
But in some cases, I have smart light and a smart relay behind the switch. And I want the button press to toggle the relay. but more info dialog should bring smart lights (brightness, color etc). I tried using variables like below.
  entity: switch.eh_kitchen_sw_switch
  variables:
    real_light_entity: "light.diningroom"
  template:
    - light_switch
    - icon_hue
this works fine to toggle. but light_switch template is the problem. how can I access the variables inside the template? like in the highlighted part
Thanks for this.
how can i set this up for one of the users and not affect the others?
i want my main user to stay on the original theme and another user that will use your theme.
thanks
mor
I have an old iPad Air (ios12.5.7). When I used it to display this dashboard, I found that only the title could be displayed and the button-card could not be displayed. It was the same through Home Assistant APP or Safari or Chrome.
But working on a Win11 laptop or Android tablet is fine.
Does anyone else have this problem?
Can anyone help me?
I tested that the 2022.8 configuration works fine on the iPad, but the 2022.9 and later configurations do not. @Mattias_Persson Can you help me find out what’s causing it and fix it?
I’m running 2022.9 on iPad Air without any problems.
@VietNgoc Could you share your camera setup? How did you square image of camera stream live when camera has ratio 16:9?
camera:
  template:
    - base
    - circle
    - icon_spot_cam
  variables:
    camera_on: >
      [[[ return !entity || ['streaming'].indexOf(entity.state) !== -1; ]]]
    camera_off: >
      [[[ return !entity || ['off', 'standby', 'unknown', 'unavailable', 'idle'].indexOf(entity.state) !== -1; ]]]
    is_bellow_horrizon: >
        if (states['sun.sun'].state == 'below_horizon') {
            return true;
    battery: ''
  tap_action:
    action: call-service
    service: automation.trigger
    service_data:
      entity_id: automation.camera_snapshot
  tooltip: >
      return states[variables.battery].state+' %';
  double_tap_action:
    action: fire-dom-event
    browser_mod:
      service: browser_mod.popup
        title: ' '
        style: |
          --popup-border-width: 0;
          --tablet-popup-header-color: rgba(0, 0, 0, 0);
          --popup-background-color: rgba(0, 0, 0, 0);
          --popup-max-width: 600px;
        card_mod:
          style:
              @media screen and (min-width: 800px) {
                ha-dialog>ha-dialog-header {
                  display: none !important;
              @media (max-width: 450px), (max-height: 500px) {
                ha-dialog {
                  --mdc-dialog-min-width: 100vw !important;
                  --mdc-dialog-min-height: 100vh !important;
                  --popup-border-radius: 0 !important;
        content:
          type: picture-entity
          entity: >
            [[[ return variables.entity_id;]]]
          image: >
                return `/local/tmp/${variables.entity_id}-latest.jpg`;
          show_info: true
          show_state: true
          show_name: false
          camera_view: auto
          tap_action:
            service: >
                return variables.state == 'idle'
                  ? 'camera.turn_on'
                  : 'camera.turn_off';
            service_data:
              entity_id: >
                  return entity.entity_id;
          card_mod:
            style: |
              ha-card {
                border-radius: 16px !important;
  styles:
    card:
      - padding: 8%
      - background-color: none
      - background-size: cover
      # - background-position: center
      - background-repeat: no-repeat
      - background-image: >
              return `linear-gradient(0deg, rgba(0,0,0,.3) 0%, rgba(0,0,0,0) 100%), url(${variables.entity_picture})`;
    #   return `linear-gradient(0deg, rgba(0,0,0,.5) 0%, rgba(0,0,0,0) 100%), url(/local/tmp/${variables.entity_id}-latest.jpg)`;
    custom_fields:
      circle:
        - width: 50%
  custom_fields:
    circle: >
        if (entity.state === 'streaming' || entity.state === 'idle') {
          let time = c => {
              let s = (c/1e3),
                  m = (c/6e4),
                  h = (c/36e5),
                  d = (c/864e5);
              return s < 60
                  ? parseInt(s) + 's'
                  : m < 60 ? parseInt(m) + 'm'
                  : h < 24 ? parseInt(h) + 'h'
                  : parseInt(d) + 'd';
            let last_changed = time(Date.now() - Date.parse(entity.last_changed)),
              stroke = variables.state === 'streaming' || variables.state === 'on'  ? '#000000' : 'rgba(255,255,255,0.1)',
              fill = variables.is_bellow_horrizon && variables.state === 'idle' || variables.state === 'off' ? 'rgba(255,255,255,0.1)' : '#efefef95',
              text = variables.is_bellow_horrizon && variables.state === 'idle' || variables.state === 'off' ? '#8d8e90' : '#000000';
        if (entity) {
        return `
          <svg viewBox="0 0 50 50">
            <circle cx="25" cy="25" r="20.5" stroke="${stroke}" stroke-width="2.5" fill="${fill}" />
            <text x="50%" y="54%" fill="${text}" font-size="14" text-anchor="middle" alignment-baseline="middle" dominant-baseline="middle">${last_changed}</text>
          </svg>
    entity: camera.kids_room
    hold_action: !include ../popup/cameras.yaml
    template:
      - camera
      - loader
    variables:
      battery: 'sensor.doorway_battery_percentage'
    styles:
      card:
Did anyone manage to make the “tilt 3D parallax effect” work on the swipe cards? This snippet from Matt’s dashboard has a nice effect when changing from the last active device to the other casting options, but I can’t get it to behave the same.
media
Is it related to different versions of HA?
My HA version:
Home Assistant 2023.8.4
Front-end version: 20230802.1 - latest
since few days the border in the popup appears again. Anyone knows what might be the issue?
browser_mod:
    title: Updates
    content:
      type: custom:mod-card
      card_mod:
        style:
          hui-grid-card:
              //button-card:nth-child(2) {
              //  margin: 0.6em 0 2.1em 0.8em;
              //button-card:nth-child(4) {
              //  margin: 0.6em 0 0.5em 0.8em;
              #root {
                grid-gap: 0 !important;
                padding: var(--tablet-popup-content-padding);
      card:
        type: grid
        columns: 1
        square: false
        cards:
            entity: sensor.template_current_version
            template:
              - updates_hass
              # - hacs_iframe
            variables:
              available: sensor.template_updates
              latest: sensor.template_latest_version
              hass_core: update.home_assistant_core_update
              hass_supervisor: update.home_assistant_supervisor_update
              hass_operating_system: update.home_assistant_operating_system_update
            variables:
              updates: sensor.template_updates
              other_updates: sensor.template_other_updates
              hacs_installed: sensor.hacs_installed
            template:
              - updates
              # - hacs_iframe
Do you have “effect” in your ui-lovelace.yaml for the Media Swipe section?
        #                   MEDIA SWIPE                 #
          - type: custom:swipe-card
            parameters:
              effect: 'coverflow'
              speed: 550
              spaceBetween: 40
              threshold: 5
            cards:
Thanks for the input, but yeah, I do. And oddly enough the tilt.js is loaded as expected and I can call it through the console if I mess around with the HTML on Inspector.
I have created a dumb page for testing and there the effect works as expected, so it has to be something with my dashboard (or the whole HASS setup).
Anyways, I’ll recreate the dashboard first to see it does the trick, then recreate the whole HASS instance if needed. I’ll share any progress with you guys ASAP.
Ok, managed to solve the problem – looks like my browser was keeping the JS from running some graphics. Not sure how that ended up being the problem, but enabling hardware acceleration and cleaning cache did the trick.
However it seems I got a new problem, as now the pop ups are no longer transparent (attached mine vs Matt’s for reference). Not sure if this relates back to the problem above, maybe not.
Any thoughts?
Has anyone had any luck on styling the title using card_mod (or other) in the browser_mod.popup? I think I've tried every CSS element I could think of without success.
use vertical stack card in button :smiley:
#                    DEVICES                    #
- type: grid
  title: Devices
  view_layout:
    grid-area: devices
  columns: 2
  cards:
    - type: vertical-stack
      cards:
          primary: Hello
          secondary: How are you?
          icon: mdi:home
          card_mod:
            style: |
              ha-card {
                background: #008b8b;
                margin-block: 5px;
          primary: Hello
          icon: mdi:home
          card_mod:
            style: |
              ha-card {
                background: #a9a9a9;
                margin-block: 5px;
Cool. What I would improve is to reduce the rounding of the corners to the same as the larger cards. :blush:
