A different take on designing a Lovelace UI
Thx, the icon is working now! i changed the code of circle input back to yourse, i toughd in this way it always show the current temp, now it shows the SET temp when heating.
wich line do i need to remove or edit that it always show the current temp?
Under state_display, does it know al the variabels ? Can I set them to auto, heat, off ?
    circle_input: >
        return Math.round(entity.attributes.current_temperature).toString();
Thank you so much, finally I it worked for me. One more question though the button seems to be square and not circular in the edges like my other cards or cards by other people on this sub. Any idea why?
CSS question. I have a pop-up for controlling my heat pump, and the functions are in place, but the headings are differently formated.
Why does Preset mode and Swinging mode font differ from the Fan mode? Here is the pop-up code:
action: fire-dom-event
browser_mod:
  service: browser_mod.popup
    title: Temperatur och Värmepumpen
    card_mod:
      style:
        #popup header
          div.content {
            margin-top: -24px !important;
    content:
      type: vertical-stack
      cards:
        - type: entities
          card_mod:
            class: content
            style:
                #states {
                  padding-top: 1.2em;
                  padding-bottom: 0em;
              hui-horizontal-stack-card$: |
                h1 {
                  font-size: 15px !important;
                  font-weight: 600 !important;
                  padding: 5px 0 4px 9px !important;
                  letter-spacing: 0.01em !important;
                :host {
                  --climate-margin: 6.5px;
                #root {
                  padding: 2px 0px 10px 8px !important;
                #root > *:nth-child(1) {
                  margin-right: var(--climate-margin) !important;
                #root > *:nth-child(2),
                #root > *:nth-child(3) {
                  margin: 0px var(--climate-margin) !important;
                #root > *:nth-child(4) {
                  margin-left: var(--climate-margin) !important;
                  margin-right: -1px !important;
          entities:
            - type: custom:mushroom-climate-card
              entity: climate.varmepumpen
              icon: mdi:home-thermometer
              hvac_modes:
                - 'off'
                - heat
                - cool
                - heat_cool
                - dry
                - fan_only
              primary_info: name
              secondary_info: state
              show_temperature_control: false
              card_mod:
                style: |
                  mushroom-card {
                    margin: -5px -13px 0 -4px;
              icon_type: none
              secondary_info: none
              primary_info: none
              show_temperature_control: true
              card_mod:
                style: |
                  mushroom-card {
                    margin: -18px -13px -8px -4px
            - type: custom:hui-horizontal-stack-card
              title: Fan mode
              cards:
                - type: custom:button-card
                  variables:
                    fan_mode: Low
                  template:
                    - climate_fan_mode
                  variables:
                    fan_mode: LowMid
                  template:
                    - climate_fan_mode
                  variables:
                    fan_mode: Mid
                  template:
                    - climate_fan_mode
                  variables:
                    fan_mode: HighMid
                  template:
                    - climate_fan_mode
                  variables:
                    fan_mode: High
                  template:
                    - climate_fan_mode
              title: Preset mode
              cards:
                  variables:
                    preset_mode: 'none'
                  template:
                    - climate_preset_mode
                  variables:
                    preset_mode: 'boost'
                  template:
                  variables:
                    preset_mode: eco
                  template:
               title: Swinging mode
               cards:
                  variables:
                    swing_mode: Auto
                  template:
                    - climate_swing_mode
                  variables:
                    swing_mode: Up
                  template:
                  variables:
                    swing_mode: UpMid
                  template:
                  variables:
                    swing_mode: Mid
                  template:
                  variables:
                    swing_mode: DownMid
                  template:
                  variables:
                    swing_mode: Down
                  template:
                  variables:
                    swing_mode: All
                  template:
            # SPACER
              color_type: blank-card
            # SENSORS
            - entity: sensor.snitt_temperatur
you have css styles for h1 horizontal stack.
Whenever I add - light template all the formatting goes off and it shows like a normal button card. any idea why this is happening?
Nice!
Have you tried to update the “tablet.yaml” file. Its under “Theme” folder.
The easiest way is to upload or copy the whole code from there. It worked for me
A different take on designing a Lovelace UI - #5453 by VietNgoc
oh thank you! but unfortunately I am using UI Lovelace minimalist so can’t move the theme to tablet :frowning:
one more question if you dont mind, whenever I use template light, all the styling and icon goes away. Any idea why?
I also changed the rounded by playing on the border function
Yes, but I stil don’t get it. Isn’t that supposed to be declared once for all the horizontal-stack cards? All the fan controll buttons are based on horizontal stacks aren’t they?
just delete…
                h1 {
But If I want to keep the H1 format from fan mode for Swing mode and Preset mode headings?
browser_mod:
    card_mod:
      style:
        #popup header
          #states {
            padding-top: 1.2em;
        hui-vertical-stack-card$hui-horizontal-stack-card:
            h1 {
              font-size: 16px !important;
            :host {
            #root {
    content:
      cards:
        - type: entities
          entities:
              hvac_modes:
                - 'off'
                - heat
                - cool
                - heat_cool
                - dry
                - fan_only
              primary_info: name
              card_mod:
                style: |
                  mushroom-card {
              icon_type: none
              primary_info: none
              card_mod:
                style: |
                  mushroom-card {
          title: Fan mode
          cards:
              variables:
                fan_mode: Low
              template:
                - climate_fan_mode
              variables:
                fan_mode: LowMid
              template:
                - climate_fan_mode
              variables:
                fan_mode: Mid
              template:
                - climate_fan_mode
              variables:
                fan_mode: HighMid
              template:
                - climate_fan_mode
              variables:
                fan_mode: High
              template:
                - climate_fan_mode
          title: Preset mode
          cards:
              variables:
                preset_mode: 'none'
              template:
              variables:
              template:
              variables:
                preset_mode: eco
              template:
          cards:
              variables:
                swing_mode: Auto
              template:
              variables:
                swing_mode: Up
              template:
              variables:
                swing_mode: UpMid
              template:
              variables:
                swing_mode: Mid
              template:
              variables:
                swing_mode: DownMid
              template:
              variables:
                swing_mode: Down
              template:
              variables:
                swing_mode: All
              template:
Thanks for the assistance! I got it working ALMOST the way I want it now! I made a seperate template for my clima unit based on the circle template.
The challenge left is that when I move out of the specific lovelace view and come back it looks like this second image. I guess that is the base template that loads. In order to get the button to display as I want it, I need to chnge the state of it by turning it off - and then of course back on. Slightly inconvenient and not according to plan. Do you have any suggestions for workaround?
screen2
screen1
post here all your code, the problem is probably somewhere there
After aditional testing, it changes after approximately 30 seconds. The color change is set in the icon.yaml through my icon_ac and not in the circle_climate.yaml as I wrongfully said initially.
icon_ac:
  styles:
    card:
      - --c-fill-color-on: >
            let d = entity.entity_id.split('.')[0];
            return (d == 'climate')
              ? '#64191e'
              : 'none';
      - --c-stroke-color-on: >
              ? '#663313'
              : 'none';
    custom_fields:
      icon:
        - width: 90%
        - margin-top: '-5%'
  custom_fields:
    icon: |
        let style = `
          <style>
            @keyframes bottom-flap {
              0% {
                  transform: rotateX(100deg);
              100% {
                  transform: rotateX(0deg);
            .bottom-flap{
              animation: bottom-flap 4s ease-in-out;
              transform-origin: top;
              transform-box: fill-box;
            @keyframes flow-control {
              0% {
              50% {
                  transform: rotateX(90deg);
              100% {
            .flow-control{
              animation: flow-control 5s ease-in-out;
          </style>
          path = `
            <path fill="url(#aircon_paint2_linear_1_2)" id="aircon-unit" d="M1.21287 15.9548C0.98527 15.9548 0.801849 16.1382 0.801849 16.3658V31.8749C0.801849 32.1025 0.98527 32.2859 1.21287 32.2859H42.9177V32.5189C42.9177 32.6006 43.0462 32.6648 43.2055 32.6648H46.0787C46.062 32.7554 46.0539 32.8473 46.0546 32.9393V33.6502C46.0546 33.8685 46.0907 34.0452 46.1362 34.0452H47.3961C47.4416 34.0452 47.4778 33.8685 47.4778 33.6502V32.9393C47.4784 32.8473 47.4703 32.7554 47.4537 32.6648H47.6491C47.8085 32.6648 47.937 32.6006 47.937 32.5189V32.2859H48.7872C49.0148 32.2859 49.1982 32.1025 49.1982 31.8749V16.3658C49.1982 16.1382 49.0148 15.9548 48.7872 15.9548H1.21287ZM2.72978 23.7576H47.3613C47.4001 23.7576 47.4322 23.7897 47.4322 23.8312V24.4404C47.4322 24.4819 47.4001 24.5167 47.3613 24.5167H2.72844C2.68961 24.5167 2.65748 24.4819 2.65748 24.4404V23.8312C2.65748 23.7897 2.68961 23.7576 2.72844 23.7576H2.72978Z"/>
          gradient = `
            <linearGradient id="aircon_paint0_linear_1_2" x1="22.9118" y1="35.1798" x2="22.9118" y2="32.2111" gradientUnits="userSpaceOnUse">
              <stop stop-color="#CCCCCC"/>
              <stop offset="1" stop-color="#585858"/>
            </linearGradient>
            <linearGradient id="aircon_paint1_linear_1_2" x1="22.8125" y1="32.9688" x2="22.8125" y2="34.5938" gradientUnits="userSpaceOnUse">
              <stop stop-color="#4D4D4D"/>
              <stop offset="1" stop-color="#848484"/>
            </linearGradient>
            <linearGradient id="aircon_paint2_linear_1_2" x1="25.375" y1="14.625" x2="25.9375" y2="60.75" gradientUnits="userSpaceOnUse">
              <stop offset="1" stop-color="#2C2C2C"/>
            </linearGradient>
        if (variables.state !== 'off') {
          return `
            <svg viewBox="0 0 50 50"> ${gradient}
              ${path}
              <path id="bottom-flap" d="M3.38065 31.8435H40.2322C40.2647 31.8435 40.2908 31.8697 40.2908 31.9022C40.3213 32.714 40.6142 33.7062 40.7243 34.4498L2.88846 34.4536C2.969 33.7186 3.32197 32.7133 3.32197 31.9022C3.32197 31.8697 3.34814 31.8435 3.38065 31.8435V31.8435Z" fill="url(#aircon_paint0_linear_1_2)"/>
              <path id="flow-control" d="M4.01023 31.2383H39.6673C39.6988 31.2383 39.7241 31.265 39.7241 31.2982C39.7756 33.3753 40.037 33.1396 40.1436 33.8985L3.534 33.9025C3.61192 33.1523 3.88716 33.4851 3.95346 31.2982C3.95346 31.265 3.97878 31.2383 4.01023 31.2383L4.01023 31.2383Z" fill="url(#aircon_paint1_linear_1_2)"/>
              ${style}
            </svg>
        if (variables.state === 'off') {
          return `
            <svg viewBox="0 0 50 50"> ${style}
              <path fill="#9da0a2" id="aircon-unit" d="M1.21287 15.9548C0.98527 15.9548 0.801849 16.1382 0.801849 16.3658V31.8749C0.801849 32.1025 0.98527 32.2859 1.21287 32.2859H42.9177V32.5189C42.9177 32.6006 43.0462 32.6648 43.2055 32.6648H46.0787C46.062 32.7554 46.0539 32.8473 46.0546 32.9393V33.6502C46.0546 33.8685 46.0907 34.0452 46.1362 34.0452H47.3961C47.4416 34.0452 47.4778 33.8685 47.4778 33.6502V32.9393C47.4784 32.8473 47.4703 32.7554 47.4537 32.6648H47.6491C47.8085 32.6648 47.937 32.6006 47.937 32.5189V32.2859H48.7872C49.0148 32.2859 49.1982 32.1025 49.1982 31.8749V16.3658C49.1982 16.1382 49.0148 15.9548 48.7872 15.9548H1.21287ZM2.72978 23.7576H47.3613C47.4001 23.7576 47.4322 23.7897 47.4322 23.8312V24.4404C47.4322 24.4819 47.4001 24.5167 47.3613 24.5167H2.72844C2.68961 24.5167 2.65748 24.4819 2.65748 24.4404V23.8312C2.65748 23.7897 2.68961 23.7576 2.72844 23.7576H2.72978Z"/>
            </svg>
        } else {
          return `
            </svg>
Screenshot 2023-11-02 at 9.38.29 PM
Anyone have any idea why the card shows different when I used template “light” the first one is just base and icon and second is light and icon
Hello all,
since today I noticed an erro on my swipe card (based on Matthias template)
My code has a minor difference since I do not have a title for the card:
in media.yaml
  state_display: >
      let swipeCard = this.getRootNode().host,
          gridTitle = swipeCard.getRootNode().querySelector("h1");
      swipeCard.swiper.on("slideChange", () => {
          if (swipeCard.swiper.realIndex === 0) {
              gridTitle.textContent = "Media";
The error I see is:
any idea why this is happening? Has anyone else seen t?
Davide
After the last updates, I lost my light cards. Anyone know how to fix this?
