That’s strange. I copied your template select into Dev Tools and it said that the variable is missing.
Anyway, I then created a new select entity based on your code, which is working properly.
check if your friendly name is set correctly for entities
Okay… I found it… turns out I had misspelled one of my media players… check both at the top and the bottom of the conditional_media template that all your media players are listed correctly.
and as @VietNgoc said that their frendly names are set correctly
Also thanks for the suggestions
Late reply, but i did this the other day by using card_mod to add a temperature monitor (that still needs more styling). This way the card pushed to the bottom isn’t kicked out of the flow.
More info: To align something to the other end of a flex flow you can use margin auto (which direction depends on your flex directon (usually margin-top or margin-left for bottom or right align))
We also need to wrap the vertical-stack in a mod-card since it doesn’t support card_mod inherently, which means we also want to set the height of the newly created object.
# SIDEBAR #
- type: custom:mod-card
view_layout:
grid-area: sidebar
card:
type: vertical-stack
cards:
- type: custom:button-card
entity: sensor.template_sidebar
template: sidebar
- type: custom:mini-graph-card
show:
fill: false
color_thresholds:
- value: 2
color: "#ff9800"
- value: 0
color: "#ffffff"
- value: -2
color: "#639dd1"
entities:
- sensor.utomhus_temperature
card_mod:
style: |
ha-card {
border: none;
border-radius: 0px;
card_mod:
style:
ha-card {
height: 100%;
hui-vertical-stack-card$: |
#root > mini-graph-card {
margin-top: auto;
Would someone be able to clarify what changes are required in order to change the colour gradient of a light bulb icon, based upon the brightness % value of the bulb? Instead of the original Blue colour that Mattias used for the light state on colour, I changed it to a yellow colour within the theme:
state-icon-active-color: "#f0b81d" #changed from #3182b7
state-active-color: "#f0b81d" #changed from #3182b7
and I also changed the following:
button-card-light-color-temp: hsl(44, 88%, 53%) #changed from hsl(204, 58%, 40%)
When my light is on at 100% brightness, the bulb icon shows correctly as yellow.
As I dim the bulb down to say 10% brightness, the icon colour changes to a Brown colour. I want this to remain yellow, but just a lighter/paler yellow, which is why I picked the new hsl values above.
The SVG icon I am using in one example case is the ‘icon_recessed’ kindly provided by someone earlier in this thread. In the on state, it uses:
fill="var(--button-card-light-color-no-temperature)
which I don’t have in my theme, so I added one:
button-card-light-color-no-temp: hsl(44, 88%, 53%)
however, after adding this, the fill colour of the icon remains fully yellow regardless of state or brightness.
I can see in extra_styles.yaml that the first section relates to lights, so it looks like this is where I need to perhaps change something, but I’m a bit lost as to what.
extra_styles:
extra_styles: >
if (entity) {
if (entity.entity_id.split('.')[0] === 'light' && variables.state_on) {
// theme variable and conditions
let style = getComputedStyle(document.body),
theme_var = style.getPropertyValue('--button-card-light-color-temp'),
is_hsl = theme_var.startsWith('hsl('),
is_color_temp = entity.attributes.color_mode === 'color_temp';
if (is_hsl && is_color_temp && entity.attributes.brightness) {
// calculate lightness in hsl
let regex_pattern = /(\d+)(?!.*\d)/g,
brightness = entity.attributes.brightness / 2.54,
lightness = parseFloat(theme_var.match(regex_pattern)[0]),
min = lightness - 10,
max = lightness + 10,
calc_lightness = brightness * (max - min) / 100 + min;
var light_color = theme_var.replace(regex_pattern, calc_lightness);
else {
var light_color = 'var(--button-card-light-color)';
return `
* LIGHT *
svg {
--light-color: ${
variables.state_on && entity.attributes.brightness
? light_color
: variables.state_on && !entity.attributes.brightness
? 'var(--state-icon-active-color);'
: 'var(--state-icon-color);' }
.light-color {
fill: var(--light-color);
transition: all 0.25s ease-out;
/* magnification */
:host {
--card-portrait: 1.4;
--card-phone: 2.271;
${this._config.template.includes('light') ? `
Developer tools in my browser shows that the var button-card-light-color
is being applied, which is coming from ‘extra_styles.yaml’. I’m just a bit lost with all the different light colour styles.
Good evening, good people!
I have tried a lot of different things and haven’t managed to succeed. Is there anyone here who can tell me how to magically change the grid title when swiping on a swipe card, similar to the Media grid? I’ve tried copying conditional_media without success, there must be a trigger somewhere, I think. But I can’t figure out where.
I have a twin ev charger, and want to use an image for each connector with different image on each chargepoint depending on state somewhat like this:
Yeah the images are a little rough right now, but that is fixable. My challenge is how do I set the size so it scales with the button itself depending on dasboard? Here is my code:
entity: sensor.laddbox
show_icon: false
show_entity_picture: true
show_name: false
template:
- base_charge
styles:
grid:
- grid-template-areas: '"mainCharger twinCharger"'
width: 100%
height: 100px
margin-right: 5px
custom_fields:
mainCharger: |
const mainAttributes = states['sensor.laddbox'].attributes['mainCharger'];
console.log('Main Charger Attributes:', mainAttributes);
const mainStatus = mainAttributes ? mainAttributes['connector'] : null;
console.log('Main Charger Connector Status:', mainStatus);
return '<img height="100px" src="/local/laddbox_' + (mainStatus === 'CONNECTED' ? 'green' : 'off') + '.png">';
twinCharger: |
const twinAttributes = states['sensor.laddbox'].attributes['twinCharger'];
console.log('Twin Charger Attributes:', twinAttributes);
const twinStatus = twinAttributes ? twinAttributes['connector'] : null;
console.log('Twin Charger Connector Status:', twinStatus);
return '<img height="100px" src="/local/laddbox_' + (twinStatus === 'CONNECTED' ? 'green' : 'red') + '.png">';
i have a very strange problem, my cards are not showing or they disapear when i set the entity to a LIGHT.
when i add to the same code a binary sensor or all other than a light. the card comes back.
the light entity is working, i can switch the light over devices.
show_state: false
entity: light.color_temperature_light_29
template:
- light1
- icon_shade
light1:
template:
- base
- circle
- loader
double_tap_action:
action: fire-dom-event
browser_mod:
service: browser_mod.popup
title: >
return !entity || entity.attributes.friendly_name;
card_mod:
style:
#popup header
content:
type: entities
card_mod:
style: |
#states {
padding-top: 0.5em;
entities: >
if (entity) {
let lights = [],
id = Boolean(entity.attributes.entity_id)
? [entity.entity_id].concat(entity.attributes.entity_id)
: [entity.entity_id];
for (let i = 0; i < id.length; i++) {
lights.push({
"type": "custom:mushroom-light-card",
"entity": id[i],
"fill_container": false,
"primary_info": "name",
"secondary_info": "state",
"icon_type": "icon",
"show_brightness_control": true,
"use_light_color": true,
"show_color_temp_control": true,
"show_color_control": true,
"collapsible_controls": true
return lights;
variables:
circle_input: >
if (entity) {
// if light group get brightness from child to remove bounce
let child = entity.attributes.entity_id,
brightness = child && states[child[0]].attributes.brightness
? Math.round(states[child[0]].attributes.brightness / 2.54)
: Math.round(entity.attributes.brightness / 2.54);
return brightness === 0 && entity.state !== 'off'
? 1
: brightness
circle_input_unit: '%'
min_color_temp_kelvin: 2702
max_color_temp_kelvin: 6535
min_mireds: 153
max_mireds: 370
supported_color_modes:
- color_temp
color_mode: null
brightness: null
color_temp_kelvin: null
color_temp: null
hs_color: null
rgb_color: null
xy_color: null
is_deconz_group: false
friendly_name: Kellerlicht
supported_features: 40
and var(--button-card-light-color-no-temperatue)
are part of custom:button-card and reflects the colors being provided by a bulb (e.g. pink), see here.
Is there a brightness value when you turn on the lamp?
now i set the lamp manuall to 57%
and there is a value
min_mireds: 153
max_mireds: 370
- color_temp
color_mode: color_temp
brightness: 145
color_temp: 370
hs_color:
- 28.391
- 65.659
rgb_color:
- 255
- 166
- 87
xy_color:
- 0.526
- 0.387
and then the card works again, but why is he doing this ?
when i then turn off the lamp the card is not visible again
Check your extra_styles.yaml. Most probably it’s not updated according to Matt’s latest one.
For me it fixed the issue.
I tried youre extra template to show the " imac " icon.
the code that i used:
# macbook CIRCLE
macbook:
custom_fields:
macbook: >
return (states[variables.macbook].state == 'on')
? '<ha-icon icon="cil:laptop-mac" style="width:100%;display:flex; color:var(--state-icon-active-color);"></ha-icon>'
: null;
styles:
custom_fields:
macbook:
- position: absolute
- height: auto
- border-radius: 50%
- right: 1%
- padding: 5%
- margin: -10%
- top: 30%
- width: 15%
- transition: top 250ms ease-out
# - background: >
# return variables.state_on
# ? 'rgba(255, 255, 255, 0.4)'
# : '#3082b787';
Then on the card:
entity: light.lampen_inloopkast
variables:
motion: binary_sensor.motion_sensor_inloopkast_occupancy
macbook: binary_senor.imac
triggers_update: binary_sensor.motion_sensor_inloopkast_occupancy
double_tap_action:
action: more-info
template:
- light
- icon_spot
- motion
- macbook
for some reason i get i error on the card.
the macbook template i stored in a extra_circle.yaml file under button_card_templates
Two questions
(Red) How can I align the date, day and event to the left no matter what I do I can only make the time align left.
(Yellow) I think it was up a while ago but I haven’t managed to fix it. But what is that causes the white borders around the cards and graphs?
How did you do the buttons in the upper row?
has anyone the same experience since update hass to 2023 11.1? The swipe-card got transparent. (the first card is fix and the swiped cards are transparent)
Am I alone with this problem? So it seem not to be a common behaviour …?
Edit: The Problem only exists on my hass - docker container setup. Running hass on a VM everything woorks fine……
binary_senSor
@pedolsky thanks. What about for non-colour bulbs, that just have a brightness attribute - how can i create the desired gradient of yellow based on the brightness %, so that instead of a gradient of yellow (at 100%) down to brown (at 10%), I achieve yellow down to a pale yellow - as if there is a scale of opacity being applied to the yellow. I thought this is what the hsl values i posted would be used for, in accordance with the brightness % attribute of the bulb?
Oh typo, Will try this evening again.
The rest are of the config is oké? It’s no problem to have more variables?
