A different take on designing a Lovelace UI
With the new HA demanding that Configuring Command Line sensor using YAML be moved. Should we move the youtube_watching.yaml command line sensor also to our new command_line.yaml file?
Or just leave it there?
As far as I know, the new command line sensor template looks like this. So far it works fine for me…
Yes, that’s what I changed it to. Thanks
I have another question…
my plan is to change media player button icon depending on service used (Apple TV)
how can I achieve this using the original media template?
You can use a different svg path with a specific state condition, and return variable path… in your case I think it will be something like entity.attributes.source === ‘AppleTV’ or HDMI 2 and so on.
Did you manage to fix this for the newest version of the dashboard also?
Any fix for this white border that is visible on pops up?
I need some help with figuring out why my Desktop and Mobile have different graph formatting in the button cards.
This is what my desktop sees:
Screenshot 2023-12-04 230305
But this is what my phone sees:
This wasn’t always this way, the graph on the Mobile was consistent with the Desktop last year in an older version of Home Assistant. Here’s the code I used for the templates, and the ui-lovelace.yaml.
Base Template:
base2:
  template:
    - settings
    - tilt
    - extra_styles
  variables:
    state_on: >
      [[[ return ['on', 'home', 'cool', 'fan_only', 'playing', 'unlocked'].indexOf(!entity || entity.state) !== -1; ]]]
    state: >
      [[[ return !entity || entity.state; ]]]
    entity_id: >
      [[[ return !entity || entity.entity_id; ]]]
    entity_picture: >
      [[[ return !entity || entity.attributes.entity_picture; ]]]
    timeout: >
      [[[ return !entity || Date.now() - Date.parse(entity.last_changed); ]]]
  aspect_ratio: 1/1
  show_state: true
  show_icon: false
  state_display: >
    [[[ if (variables.state === true) return variables.translate_unknown; ]]]
  tap_action:
    ui_sound_tablet: |
        let screensaver = states[variables.entity_tablet] === undefined ||
            states[variables.entity_tablet].state;
        if (variables.state === 'off' && screensaver === 'off') {
            hass.callService('media_player', 'play_media', {
                entity_id: variables.entity_browser_mod,
                media_content_id: '/local/sound/on.m4a',
                media_content_type: 'music'
        if (variables.state_on && screensaver === 'off') {
                media_content_id: '/local/sound/off.m4a',
    card_bounce: |
        // duration
        let duration = 800;
        // animate
        this.style.animation = `card_bounce ${duration}ms cubic-bezier(0.22, 1, 0.36, 1)`;
        // reset
        window.setTimeout(() => { this.style.animation = "none"; }, duration + 100)
        // add animation
        if (this.getElementsByTagName("style").length === 0) {
            // phone condition
            let mq = window.matchMedia('(max-width: 800px)').matches;
            let style = document.createElement('style');
            style.innerHTML = `
                @keyframes card_bounce {
                    0%   { transform: scale(1);    }
                    10%  { transform: scale(${mq ? "0.92" : "0.94"}); }
                    25%  { transform: scale(1);    }
                    30%  { transform: scale(${mq ? "0.96" : "0.98"}); }
                    100% { transform: scale(1);    }
            this.appendChild(style);
    action: toggle
    haptic: medium
  double_tap_action:
    haptic: success
  hold_action:
    action: block
  styles:
    grid:
      - grid-template-areas: |
          "icon  circle"
          "n     n"
          "s     s"
      - grid-template-columns: repeat(2, 1fr)
      - grid-template-rows: auto repeat(2, min-content)
      - gap: 1.3%
      - align-items: start
      - will-change: transform
    name:
      - justify-self: start
      - line-height: 121%
    state:
      - line-height: 115%
    card:
      - border-radius: var(--button-card-border-radius)
      - border-width: 0
      - -webkit-tap-highlight-color: rgba(0,0,0,0)
      - transition: none
      - overflow: hidden # REQUIRED FOR CUSTOM TEMPLATES
      - --mdc-ripple-color: >
            return variables.state_on
                ? '#97989c'
                : 'rgb(0, 0, 0)';
      - color: >
                ? '#97989c'
                : '#4b5254';
      - background-color: >
                ? 'rgba(115, 115, 115, 0.25)'
                : 'rgba(255, 255, 255, 0.85)';
Temperature Template:
temperature:
  template:
    - base2
    - extra_styles
  show_name: true # Hides Card Name
  show_state: true # Hides Card state
  state_display: >
    [[[ return ' '; ]]]
  custom_fields:
    graph:
      card:
        type: "custom:mini-graph-card"
        height: 140
        hours_to_show: 24
        points_per_hour: 1
        line_width: 8
        font_size: 75
        decimals: 0
        show:
          icon: false
          state: false
          legend: false
          labels: false
          labels_secondary: false
          points: false
        color_thresholds:
          - value: 65
            color: "#276696"
          - value: 77
            color: "#228C22"
          - value: 79
            color: "#d35400"
          - value: 80
            color: "#c0392b"
        card_mod:
          style: |
            :host{
              --accent-color: #039be5;
              --ha-card-border-width: 0px;
  styles:
    custom_fields:
      graph: [bottom: 0%, left: 0%, width: 130%, position: absolute, margin: 0% 0% -14% -15.2%]
      icon:
        - width: 67%
        - fill: "#9da0a2"
icon_temp:
  styles:
    custom_fields:
      icon:
        - margin-top: 2%
  custom_fields:
    icon: >
      <svg viewBox="10 5 50 50">
        <style>@keyframes animate{0%{transform: scale(0.85);}20%{transform: scale(1.1);}40%{transform: scale(0.95);}60%{transform: scale(1.03);}80%{transform: scale(0.97);}100%{transform: scale(1);}}.animate{animation: animate 0.8s; transform-origin: center;}</style>
        <path fill="#9da0a2" d="M41.74 10.852v2h-7.75v-2zm-3.25 4.36h-4.5v2h4.5zm-4.5 6.36h7.75v-2h-7.75zm4.5 2.36h-4.5v2h4.5zm-4.5 6.36h7.75v-2h-7.75zM35.2 41.685A10.14 10.14 0 0 1 25.074 51.81a10.14 10.14 0 0 1-10.125-10.125c0-3.618 1.9-6.906 5-8.725V10.006c0-2.826 2.3-5.125 5.125-5.125s5.125 2.3 5.125 5.125V32.96c3.1 1.817 5 5.106 5 8.725zm-2 0c0-3.07-1.706-5.845-4.453-7.24l-.547-.278v-24.16a3.13 3.13 0 0 0-3.125-3.125 3.13 3.13 0 0 0-3.125 3.125v24.16l-.547.278a8.09 8.09 0 0 0-4.453 7.24c0 4.48 3.645 8.125 8.125 8.125s8.125-3.645 8.125-8.125zm-1.666 0a6.47 6.47 0 0 1-6.459 6.458 6.47 6.47 0 0 1-6.458-6.458 6.46 6.46 0 0 1 4.796-6.233l.37-.1v-22.23h2.583v22.23l.37.1a6.46 6.46 0 0 1 4.796 6.233zm-6.14-4.305c-.154-.684-.842-1.134-1.543-.974a5.31 5.31 0 0 0-4.158 5.207 1.29 1.29 0 0 0 2.58 0c0-1.277.902-2.41 2.147-2.7.692-.16 1.13-.85.974-1.543z"/>
      </svg>
ui-lovelace.yaml:
      #                    OUTSIDE                    #
      - type: grid
        title: Outside
        view_layout:
          grid-area: outside
        columns: 2
        cards:
          - type: custom:button-card
            entity: sensor.pirateweather_temperature
            tap_action: !include popup/lounge_temperature.yaml
            hold_action:
              action: none
            custom_fields:
              graph:
                card:
                  entities:
                    - entity: sensor.pirateweather_temperature
                    - entity: sensor.nightstate
                      color: gray
                      y_axis: secondary
                      show_line: false
                      show_points: false
                      show_legend: false
                      show_labels: false
            variables:
              state_on: >
                  if (entity) {
                      return entity.state
              circle_input: >
                  if (entity) {
                      return Math.round(entity.state).toString()
              circle_input_unit: '°F'
            template:
              - temperature
              - icon_temp
              - circle
I love your design for Lovelace and I’m using the fork from @Laffer but I’m stuck with the template sensors. They are all unavailable. What should I do to get them to work?
@MGiesing ; I’d suggest that you copy individual templates and verify by using the Developer Tools (Template) tester.
Open the yaml: “\config\include\template.yaml”
Start by copying all of the code under “state:” for each sensor, and test them. I’m sure there are cases where entities that are exclusive to my environment are used.
I’m currently on 2023.7.3 and everything works atm.
Did you share this config somewhere?
@Krivatri
hi,
how did you setup this?
I have a Dream machine Pro and AP from unifi and want to be able to set it up like you or @VietNgoc
Hello everyone,
After setting up my dashboard according to Mattia’s template, I started to try out some things in my normal dashboard with the classic Home Assistant cards.
My problem now is that Mattias’ theme also makes the standard Home Assistant cards transparent.
Is there a way to use 2 separate themes?
Yes, you can have as many as you want. For the main one, give it a name like ‘hass theme’, which you set via profile menu affects the whole frontend from HA, you will have a main list of things for HA elements, for example you set there the colors for sidebar, primary color, secondary etc.
But in the main theme, you will have to set card-mod-more-info-yaml: which affects the appearance of the dialog, popup… .
# MAIN INTERFACE COLORS
  primary-color: "rgba(0, 0, 0, 1)"
  dark-primary-color: "rgba(0, 0, 0, 1)"
  light-primary-color: "rgba(0, 0, 0, 1)"
  accent-color: "rgba(0, 255, 0, 1)"
# SIDEBAR MENU
  sidebar-text-color: "rgba(255, 255, 0, 1)"
  sidebar-background-color: "rgba(100, 255, 100, 1)"
  sidebar-icon-color: "rgba(0, 255, 255, 1)"
  sidebar-selected-icon-color: "rgba(255, 255, 255, 1)"
  sidebar-selected-text-color: "rgba(255, 255, 255, 1)"
  sidebar-selected-background-color: "rgba(0, 0, 0, 1)"
in lovelace.yaml by Matt you leave the theme: tablet set for views
type: custom:grid-layout
icon: mdi:home-circle
theme: tablet
path: summary
layout:
  default:
Did someone manage to get a second circle with a different entity value in the button below the normal circle on the right top?
Scherm­afbeelding 2023-12-07 om 14.52.52
i try to get 1 circle with the set temperature of my AC and a circle below with the current temperature of the room.
Just a suggestion, it would have been great to add simple pagination dots beneath the slider within the Media for better UX. I understand you’re not obligated to fulfill requests, of course, but that slider is excellent for maintaining the existing grid structure, and I need to use it in many places. I thought it would be nice if there were dots. I tried to do it myself, but I’m new and struggled a bit :slight_smile:
