Sure they are mostly just the SVG code from MDI website.
icon_shutter:
styles:
custom_fields:
icon:
- width: 180%
- margin-left: -10%
- margin-top: -5%
custom_fields:
icon: >
if (variables.state === 'open') {
return `
<svg viewBox="0 0 50 50">
<path fill="#3182B7" d="M3 4H21V8H19V20H17V8H7V20H5V8H3V4M8" />
</svg>
} else {
return `
<path d="M3 4H21V8H19V20H17V8H7V20H5V8H3V4M8 9H16V11H8V9M8 12H16V14H8V12M8 15H16V17H8V15M8 18H16V20H8V18Z" fill="#9da0a2" />
</svg>
icon_home:
state_display: Auto
styles:
card:
- transition: all 0.3s ease-out
custom_fields:
icon:
- width: 72%
- margin-left: -1%
- fill: >
[[[ return variables.state_on ? '#c7983e' : '#9da0a2'; ]]]
custom_fields:
icon: >
let state = variables.state_on ? 'on' : null;
return `
<style>
@keyframes on {
from,
20%,
40%,
60%,
80%,
to {
animation-timing-function: cubic-bezier(0.215, 0.61, 0.355, 1);
0% {
transform: scale(0.3);
20% {
transform: scale(1.1);
40% {
transform: scale(0.9);
60% {
transform: scale(1.03);
80% {
transform: scale(0.97);
to {
transform: scale(1);
.on {
animation: on 1s;
transform-origin: center;
</style>
<path class="${state}" d="M42.2 28.3c0-.8-.2-1-.2-1L26 12.1s-.5-.4-1-.4-1 .3-1 .3L8.2 27.1c-.4.5-.4.9-.4.9v18.3c0 1.1.9 2 1.9 2h8.2a1.47 1.47 0 0 0 1.5-1.5v-14a1.47 1.47 0 0 1 1.5-1.5h8.4a1.47 1.47 0 0 1 1.5 1.5v14a1.47 1.47 0 0 0 1.5 1.5h8.2c1.1 0 2-.9 2-1.9 0-.2-.3-18.1-.3-18.1zM7.3 25l-1.6 1.5s-.3.3-.5.3-.5 0-.8-.2c-.2-.2-2-2.8-2-2.8s-.1-.4-.1-.7c.1-.3.2-.7.3-.8.4-.1 21.5-20.1 21.5-20.1s.4-.3.9-.3c.4 0 .8.1.9.2s.5.4.5.4l8.9 8.5V6s.1-.4.2-.7c.1-.2.3-.3.4-.3s.3-.1.3-.1h3s.3.1.4.3a1.08 1.08 0 0 1 .3.7v9.8l7.2 6.9s.2.3.3.4c.1.2.1.7.1.7 0 .1-.1.4-.2.5s-1.6 2.5-1.6 2.5-.1.3-.3.3c-.2.1-.4.1-.7 0-.2-.1-.5-.4-.5-.4L26.4 9.4s-.3-.3-.5-.4-.4-.2-.8-.2-.5.1-.8.1c-.1.1-.4.3-.7.5C23.3 9.8 7.3 25 7.3 25z"/>
</svg>
icon_washer:
styles:
custom_fields:
icon:
- width: 78%
- margin-left: -6%
custom_fields:
icon: >
let center = `
<path d="M31.8,23.1c3.8,3.8,3.8,9.8,0,13.6c-3.8,3.8-9.8,3.8-13.6,0L31.8,23.1"/>
<path fill="none" d="M25,15.4c-8,0-14.4,6.4-14.4,14.4S17,44.3,25,44.3s14.4-6.4,14.4-14.4S33,15.4,25,15.4z"/>
base = `
<path fill="#9da0a2" d="M10.6,1.1h28.7c2.6,0,4.8,2.1,4.8,4.8v38.4c0,2.6-2.1,4.8-4.8,4.8H10.6c-2.6,0-4.8-2.1-4.8-4.8V5.8C5.8,3.2,8,1.1,10.6,1.1 M13.1,5.8c-1.4,0-2.4,1.1-2.4,2.4c0,1.4,1.1,2.4,2.4,2.4s2.4-1.1,2.4-2.4S14.3,5.8,13.1,5.8 M20.2,5.8c-1.4,0-2.4,1.1-2.4,2.4 c0,1.4,1.1,2.4,2.4,2.4c1.4,0,2.4-1.1,2.4-2.4S21.5,5.8,20.2,5.8 M25,15.4c-8,0-14.4,6.4-14.4,14.4S17,44.3,25,44.3 s14.4-6.4,14.4-14.4S33,15.4,25,15.4z"/>
style = `
<style>
@keyframes rotate {
0% {
visibility: visible;
transform: rotate(0deg) translateZ(0);
100% {
transform: rotate(720deg) translateZ(0);
.start {
animation: rotate 2.8s ease-in;
transform-origin: center 60%;
fill: #5daeea;
visibility: hidden;
will-change: transform;
.on {
animation: rotate 1.8s linear infinite;
fill: #5daeea;
animation-delay: 2.8s;
visibility: hidden;
.end {
animation: rotate 2.8s;
fill: #9ca2a5;
animation-timing-function: cubic-bezier(0.61, 1, 0.88, 1);
.start_timeout {
fill: #5daeea;
visibility: hidden;
.end_timeout {
fill: #9ca2a5;
</style>
if (variables.state_on) {
return `${style}${base}<g class="start">${center}</g><g class="on">${center}</g></svg>`;
if (!variables.state_on) {
return `${style}${base}<g class="end">${center}</g></svg>`;
if (variables.state_on && variables.timeout > 2000) {
return `${style}${base}<g class="start_timeout">${center}</g></svg>`;
} else {
return `${style}${base}<g class="end_timeout">${center}</g></svg>`;
icon_dryer:
styles:
custom_fields:
icon:
- width: 78%
- margin-left: -6%
custom_fields:
icon: >
let center = `
<path d="M15.7,21.5h4.6c-0.6,3.3,0,5.2,1.4,6.7c2.6,2.5,3.8,5.8,3.1,10.1h-4.6c0.6-3.3,0-5.2-1.4-6.7 C16.2,28.9,15.1,25.7,15.7,21.5"/>
<path d="M25.3,21.5h4.6c-0.6,3.3,0,5.2,1.4,6.7c2.6,2.5,3.8,5.8,3.1,10.1h-4.6c0.6-3.3,0-5.2-1.4-6.7 C25.8,28.9,24.6,25.7,25.3,21.5z"/>
<path fill="none" d="M25,15.4c-8,0-14.4,6.4-14.4,14.4S17,44.3,25,44.3s14.4-6.4,14.4-14.4S33,15.4,25,15.4"/>
base = `
<path fill="#9da0a2" d="M10.6,1.1h28.7c2.6,0,4.8,2.1,4.8,4.8v38.4c0,2.6-2.1,4.8-4.8,4.8H10.6c-2.6,0-4.8-2.1-4.8-4.8V5.8C5.8,3.2,8,1.1,10.6,1.1 M13.1,5.8c-1.4,0-2.4,1.1-2.4,2.4c0,1.4,1.1,2.4,2.4,2.4s2.4-1.1,2.4-2.4S14.3,5.8,13.1,5.8 M20.2,5.8c-1.4,0-2.4,1.1-2.4,2.4 c0,1.4,1.1,2.4,2.4,2.4c1.4,0,2.4-1.1,2.4-2.4S21.5,5.8,20.2,5.8 M25,15.4c-8,0-14.4,6.4-14.4,14.4S17,44.3,25,44.3 s14.4-6.4,14.4-14.4S33,15.4,25,15.4"/>
style = `
<style>
@keyframes rotate {
0% {
100% {
.start {
fill: #5daeea;
visibility: hidden;
.on {
fill: #5daeea;
visibility: hidden;
.end {
fill: #9ca2a5;
.start_timeout {
fill: #5daeea;
visibility: hidden;
.end_timeout {
fill: #9ca2a5;
</style>
} else {
icon_stove:
styles:
custom_fields:
icon:
- width: 180%
- margin-left: -10%
- margin-top: -5%
custom_fields:
icon: >
<path d="M6 14h2l3 3H9l-3-3M4 4h1V3a1 1 0 0 1 1-1h4a1 1 0 0 1 1 1v1h2V3a1 1 0 0 1 1-1h4a1 1 0 0 1 1 1v1h1a2 2 0 0 1 2 2v13a2 2 0 0 1-2 2v1h-3v-1H7v1H4v-1a2 2 0 0 1-2-2V6a2 2 0 0 1 2-2m14 3a1 1 0 0 1 1 1a1 1 0 0 1-1 1a1 1 0 0 1-1-1a1 1 0 0 1 1-1m-4 0a1 1 0 0 1 1 1a1 1 0 0 1-1 1a1 1 0 0 1-1-1a1 1 0 0 1 1-1m6-1H4v4h16V6M4 19h16v-7H4v7M6 7a1 1 0 0 1 1 1a1 1 0 0 1-1 1a1 1 0 0 1-1-1a1 1 0 0 1 1-1m7 7h2l3 3h-2l-3-3Z" fill="#9da0a2" />
<path class="${state} light-color" d="M6 14h2l3 3H9l-3-3M4 4h1V3a1 1 0 0 1 1-1h4a1 1 0 0 1 1 1v1h2V3a1 1 0 0 1 1-1h4a1 1 0 0 1 1 1v1h1a2 2 0 0 1 2 2v13a2 2 0 0 1-2 2v1h-3v-1H7v1H4v-1a2 2 0 0 1-2-2V6a2 2 0 0 1 2-2m14 3a1 1 0 0 1 1 1a1 1 0 0 1-1 1a1 1 0 0 1-1-1a1 1 0 0 1 1-1m-4 0a1 1 0 0 1 1 1a1 1 0 0 1-1 1a1 1 0 0 1-1-1a1 1 0 0 1 1-1m6-1H4v4h16V6M4 19h16v-7H4v7M6 7a1 1 0 0 1 1 1a1 1 0 0 1-1 1a1 1 0 0 1-1-1a1 1 0 0 1 1-1m7 7h2l3 3h-2l-3-3Z"/>
</svg>
icon_sprinkler:
styles:
custom_fields:
icon:
- width: 180%
- margin-left: -10%
- margin-top: -5%
custom_fields:
icon: >
<path d="M10 10h4v12h-4V10M7 9h2V7H7v2M4 8h2V6H4v2m0 3h2V9H4v2m-3 2h2v-2H1v2m0-6h2V5H1v2m0 3h2V8H1v2m17 1h2V9h-2v2m3-1h2V8h-2v2m0-5v2h2V5h-2m0 8h2v-2h-2v2m-6-4h2V7h-2v2m3-1h2V6h-2v2m-8-1h.33L11 9h2l.67-2H14V6h-4v1Z" fill="#9da0a2" />
<path class="${state} light-color" d="M10 10h4v12h-4V10M7 9h2V7H7v2M4 8h2V6H4v2m0 3h2V9H4v2m-3 2h2v-2H1v2m0-6h2V5H1v2m0 3h2V8H1v2m17 1h2V9h-2v2m3-1h2V8h-2v2m0-5v2h2V5h-2m0 8h2v-2h-2v2m-6-4h2V7h-2v2m3-1h2V6h-2v2m-8-1h.33L11 9h2l.67-2H14V6h-4v1Z"/>
</svg>
icon_sauna:
styles:
custom_fields:
icon:
- width: 160%
- margin-left: -10%
- margin-top: -5%
custom_fields:
icon: >
<path d="M20,12H4A2,2 0 0,0 2,14V22H4V20H20V22H22V14A2,2 0 0,0 20,12M7,17A1,1 0 0,1 6,18A1,1 0 0,1 5,17V15A1,1 0 0,1 6,14A1,1 0 0,1 7,15V17M11,17A1,1 0 0,1 10,18A1,1 0 0,1 9,17V15A1,1 0 0,1 10,14A1,1 0 0,1 11,15V17M15,17A1,1 0 0,1 14,18A1,1 0 0,1 13,17V15A1,1 0 0,1 14,14A1,1 0 0,1 15,15V17M19,17A1,1 0 0,1 18,18A1,1 0 0,1 17,17V15A1,1 0 0,1 18,14A1,1 0 0,1 19,15V17Z" fill="#9da0a2" />
<path class="${state} light-color" d="M7.95,3L6.53,5.19L7.95,7.4H7.94L5.95,10.5L4.22,9.6L5.64,7.39L4.22,5.19L6.22,2.09L7.95,3M13.95,2.89L12.53,5.1L13.95,7.3L13.94,7.31L11.95,10.4L10.22,9.5L11.64,7.3L10.22,5.1L12.22,2L13.95,2.89M20,2.89L18.56,5.1L20,7.3V7.31L18,10.4L16.25,9.5L17.67,7.3L16.25,5.1L18.25,2L20,2.89M2,22V14A2,2 0 0,1 4,12H20A2,2 0 0,1 22,14V22H20V20H4V22H2M6,14A1,1 0 0,0 5,15V17A1,1 0 0,0 6,18A1,1 0 0,0 7,17V15A1,1 0 0,0 6,14M10,14A1,1 0 0,0 9,15V17A1,1 0 0,0 10,18A1,1 0 0,0 11,17V15A1,1 0 0,0 10,14M14,14A1,1 0 0,0 13,15V17A1,1 0 0,0 14,18A1,1 0 0,0 15,17V15A1,1 0 0,0 14,14M18,14A1,1 0 0,0 17,15V17A1,1 0 0,0 18,18A1,1 0 0,0 19,17V15A1,1 0 0,0 18,14Z"/>
</svg>
icon_hottub:
styles:
custom_fields:
icon:
- width: 160%
- margin-left: -10%
- margin-top: -5%
custom_fields:
icon: >
<path d="M7,4A2,2 0 0,1 9,6A2,2 0 0,1 7,8A2,2 0 0,1 5,6A2,2 0 0,1 7,4M11.15,12H22V20A2,2 0 0,1 20,22H4A2,2 0 0,1 2,20V12H5V11.25C5,10 6,9 7.25,9H7.28C7.62,9 7.95,9.09 8.24,9.23C8.5,9.35 8.74,9.5 8.93,9.73L10.33,11.28C10.56,11.54 10.84,11.78 11.15,12M7,20V14H5V20H7M11,20V14H9V20H11M15,20V14H13V20H15M19,20V14H17V20H19M18.65,5.86C19.68,6.86 20.16,8.21 19.95,9.57L19.89,10H18L18.09,9.41C18.24,8.62 18,7.83 17.42,7.21L17.35,7.15C16.32,6.14 15.85,4.79 16.05,3.43L16.11,3H18L17.91,3.59C17.76,4.38 18,5.17 18.58,5.79L18.65,5.86M14.65,5.86C15.68,6.86 16.16,8.21 15.95,9.57L15.89,10H14L14.09,9.41C14.24,8.62 14,7.83 13.42,7.21L13.35,7.15C12.32,6.14 11.85,4.79 12.05,3.43L12.11,3H14L13.91,3.59C13.76,4.38 14,5.17 14.58,5.79L14.65,5.86Z" fill="#9da0a2" />
<path class="${state} light-color" d="M7,4A2,2 0 0,1 9,6A2,2 0 0,1 7,8A2,2 0 0,1 5,6A2,2 0 0,1 7,4M11.15,12H22V20A2,2 0 0,1 20,22H4A2,2 0 0,1 2,20V12H5V11.25C5,10 6,9 7.25,9H7.28C7.62,9 7.95,9.09 8.24,9.23C8.5,9.35 8.74,9.5 8.93,9.73L10.33,11.28C10.56,11.54 10.84,11.78 11.15,12M7,20V14H5V20H7M11,20V14H9V20H11M15,20V14H13V20H15M19,20V14H17V20H19M18.65,5.86C19.68,6.86 20.16,8.21 19.95,9.57L19.89,10H18L18.09,9.41C18.24,8.62 18,7.83 17.42,7.21L17.35,7.15C16.32,6.14 15.85,4.79 16.05,3.43L16.11,3H18L17.91,3.59C17.76,4.38 18,5.17 18.58,5.79L18.65,5.86M14.65,5.86C15.68,6.86 16.16,8.21 15.95,9.57L15.89,10H14L14.09,9.41C14.24,8.62 14,7.83 13.42,7.21L13.35,7.15C12.32,6.14 11.85,4.79 12.05,3.43L12.11,3H14L13.91,3.59C13.76,4.38 14,5.17 14.58,5.79L14.65,5.86Z"/>
</svg>
icon_pool:
styles:
custom_fields:
icon:
- width: 160%
- margin-left: -10%
- margin-top: -5%
custom_fields:
icon: >
<path d="M19 6C17.9 6 17 6.9 17 8V14.8C16.4 15.4 16 16.2 16 17C16 18.7 17.3 20 19 20S22 18.7 22 17C22 16.1 21.6 15.3 21 14.8V8C21 6.9 20.1 6 19 6M19 7C19.5 7 20 7.4 20 8V9H18V8C18 7.4 18.5 7 19 7M15 20.3C14.1 20.7 13.2 21 12.3 21C10.1 21 7.9 19 5.6 19C4.4 19 3.2 19.3 1.9 19.7V17.7C3.2 17.3 4.4 17 5.7 17C7.9 17 10.1 19 12.4 19C13.3 19 14.2 18.7 15.1 18.3V20.3M12.3 17C13.2 17 14.1 16.7 15 16.3V14.3C14.3 14.6 13.7 14.8 13 15V5C13 4.4 13.4 4 14 4H16.8C16.4 2.8 15.3 2 14 2C12.3 2 11 3.3 11 5V6H6V5C6 4.4 6.4 4 7 4H9.8C9.4 2.8 8.3 2 7 2C5.3 2 4 3.3 4 5V13.2C3.3 13.3 2.7 13.5 2 13.8V15.8C3.2 15.3 4.4 15 5.7 15C7.9 15 10.1 17 12.3 17M6 8H11V10H6V8M6 12H11V14.8C9.3 14.3 7.7 13.2 6 13V12Z" fill="#9da0a2" />
<path class="${state} light-color" d="M19 6C17.9 6 17 6.9 17 8V14.8C16.4 15.4 16 16.2 16 17C16 18.7 17.3 20 19 20S22 18.7 22 17C22 16.1 21.6 15.3 21 14.8V8C21 6.9 20.1 6 19 6M19 7C19.5 7 20 7.4 20 8V9H18V8C18 7.4 18.5 7 19 7M15 20.3C14.1 20.7 13.2 21 12.3 21C10.1 21 7.9 19 5.6 19C4.4 19 3.2 19.3 1.9 19.7V17.7C3.2 17.3 4.4 17 5.7 17C7.9 17 10.1 19 12.4 19C13.3 19 14.2 18.7 15.1 18.3V20.3M12.3 17C13.2 17 14.1 16.7 15 16.3V14.3C14.3 14.6 13.7 14.8 13 15V5C13 4.4 13.4 4 14 4H16.8C16.4 2.8 15.3 2 14 2C12.3 2 11 3.3 11 5V6H6V5C6 4.4 6.4 4 7 4H9.8C9.4 2.8 8.3 2 7 2C5.3 2 4 3.3 4 5V13.2C3.3 13.3 2.7 13.5 2 13.8V15.8C3.2 15.3 4.4 15 5.7 15C7.9 15 10.1 17 12.3 17M6 8H11V10H6V8M6 12H11V14.8C9.3 14.3 7.7 13.2 6 13V12Z"/>
icon_temp:
styles:
custom_fields:
icon:
- margin-top: 2%
custom_fields:
icon: >
<svg viewBox="10 5 50 50">
<style>@keyframes animate{0%{transform: scale(0.85);}20%{transform: scale(1.1);}40%{transform: scale(0.95);}60%{transform: scale(1.03);}80%{transform: scale(0.97);}100%{transform: scale(1);}}.animate{animation: animate 0.8s; transform-origin: center;}</style>
<path fill="#9da0a2" d="M41.74 10.852v2h-7.75v-2zm-3.25 4.36h-4.5v2h4.5zm-4.5 6.36h7.75v-2h-7.75zm4.5 2.36h-4.5v2h4.5zm-4.5 6.36h7.75v-2h-7.75zM35.2 41.685A10.14 10.14 0 0 1 25.074 51.81a10.14 10.14 0 0 1-10.125-10.125c0-3.618 1.9-6.906 5-8.725V10.006c0-2.826 2.3-5.125 5.125-5.125s5.125 2.3 5.125 5.125V32.96c3.1 1.817 5 5.106 5 8.725zm-2 0c0-3.07-1.706-5.845-4.453-7.24l-.547-.278v-24.16a3.13 3.13 0 0 0-3.125-3.125 3.13 3.13 0 0 0-3.125 3.125v24.16l-.547.278a8.09 8.09 0 0 0-4.453 7.24c0 4.48 3.645 8.125 8.125 8.125s8.125-3.645 8.125-8.125zm-1.666 0a6.47 6.47 0 0 1-6.459 6.458 6.47 6.47 0 0 1-6.458-6.458 6.46 6.46 0 0 1 4.796-6.233l.37-.1v-22.23h2.583v22.23l.37.1a6.46 6.46 0 0 1 4.796 6.233zm-6.14-4.305c-.154-.684-.842-1.134-1.543-.974a5.31 5.31 0 0 0-4.158 5.207 1.29 1.29 0 0 0 2.58 0c0-1.277.902-2.41 2.147-2.7.692-.16 1.13-.85.974-1.543z"/>
</svg>
