I have searched and tested, the problem is browser, backdrop-filter. Try other browser. I use chrome, when I resize to “phone screen” then it blurs, otherwise not.
hey, can you share your config? thanks in advance!
hello, when i turn my tv off, im allways getting this error.
Anyone can help?
Thanks in advance
onthe base template i have:`
base:
template:
- settings
- tilt
- extra_styles
variables:
state_on: >
[[[ return ['on', 'home', 'cool', 'fan_only', 'playing', 'unlocked'].indexOf(!entity || entity.state) !== -1; ]]]
state: >
[[[ return !entity || entity.state; ]]]
entity_id: >
[[[ return !entity || entity.entity_id; ]]]
entity_picture: >
[[[ return !entity || entity.attributes.entity_picture; ]]]
timeout: >
[[[ return !entity || Date.now() - Date.parse(entity.last_changed); ]]]
is_youtube: >
let is_youtube = entity?.attributes?.app_id === 'com.google.ios.youtube',
sensor = this?._config?.triggers_update,
media_title = entity?.attributes?.media_title,
watching_title = states[sensor]?.attributes?.title;
if (is_youtube && media_title === watching_title) {
return true;
aspect_ratio: 1/1
show_state: true
show_icon: false
state_display: >
const stateDict = {
'on': variables.translate_on,
'off': variables.translate_off,
'cool': variables.translate_cool,
'fan_only': variables.translate_fan_only,
if (variables.state === true) return variables.translate_unknown;
return stateDict[variables.state];
tap_action:
ui_sound_tablet: |
let screensaver = states[variables.entity_tablet] === undefined ||
states[variables.entity_tablet].state;
if (variables.state === 'off' && screensaver === 'off') {
hass.callService('media_player', 'play_media', {
entity_id: variables.entity_browser_mod,
media_content_id: '/local/sound/on.m4a',
media_content_type: 'music'
if (variables.state_on && screensaver === 'off') {
media_content_id: '/local/sound/off.m4a',
card_bounce: |
// add animation
if (this.getElementsByTagName("style").length === 0) {
// phone condition
let mq = window.matchMedia('(max-width: 800px)').matches;
let style = document.createElement('style');
style.innerHTML = `
@keyframes card_bounce {
0% { transform: scale(1); }
10% { transform: scale(${ mq ? '0.92' : '0.94' }); }
25% { transform: scale(1); }
30% { transform: scale(${ mq ? '0.96' : '0.98' }); }
100% { transform: scale(1); }
this.appendChild(style);
// duration
let duration = 800;
// animate
this.style.animation = `card_bounce ${duration}ms cubic-bezier(0.22, 1, 0.36, 1)`;
// reset
window.setTimeout(() => { this.style.animation = "none"; }, duration + 100)
action: toggle
haptic: medium
double_tap_action:
haptic: success
hold_action:
action: block
styles:
grid:
- grid-template-areas: |
"icon circle"
"n n"
"s s"
- grid-template-columns: repeat(2, 1fr)
- grid-template-rows: auto repeat(2, min-content)
- gap: 1.3%
- align-items: start
- will-change: transform
name:
- justify-self: start
- line-height: 121%
state:
- line-height: 115%
card:
- border-radius: var(--button-card-border-radius)
- border-width: 0
- -webkit-tap-highlight-color: rgba(0,0,0,0)
- transition: none
- --mdc-ripple-color: >
return variables.state_on
? 'rgb(0, 0, 0)'
: '#97989c';
- color: >
? '#4b5254'
: '#97989c';
- background-color: >
? 'rgba(255, 255, 255, 0.85)'
: 'rgba(115, 115, 115, 0.25)';
and int the button:
` - type: custom:button-card
entity: media_player.lg_webos_smart_tv
state_display: >
if (variables.state === 'playing') {
return 'Playing';
if (variables.state === true) {
# double_tap_action: !include popup/sala_tv.yaml
template:
- base
- icon_tv`
Will you share your “gallery” function when no media played? Thx
sure. Install gallery_image over hacs.
ui-lovelace.yaml
# MEDIA #
- type: grid
title: Medien
view_layout:
grid-area: media
columns: 1
cards:
- type: custom:swipe-card
parameters:
touchStartPreventDefault: false
roundLengths: true
speed: 550
spaceBetween: 40
threshold: 5
autoHeight: false
initialSlide: 0
centeredSlides: true
slidesPerView: auto
# effect: cube loop: false
preventClicksPropagation: true
preventClicks: true
pagination:
type: bullets
cards:
- type: horizontal-stack
cards:
- type: conditional
conditions:
- entity: select.conditional_media
state: gallery
card:
type: custom:gallery-card
entities:
- sensor.gallery_images
menu_alignment: hidden
slideshow_timer: 5
card_mod:
style: |
ha-card {
border-radius: calc(var(--custom-button-card-border-radius) / 2); /* card - rounded corners */
aspect-ratio: 1/1; /* card - square */
figure {
margin: 0px !important; /* remove card margins to line up with rest of dashboard */
figcaption {
display: none; /* hide image caption */
img {
object-fit: cover !important; /* fill the whole card */
aspect-ratio: 1/1; /* needed for object-fit */
.btn {
top: 50% !important; /* center buttons */
.modal-content {
aspect-ratio: unset; /* undo image aspect-ratio when clicked */
- type: conditional
conditions:
state: TV
card:
entity: media_player.tv_wohnzimmer_2
template: [conditional_media, progress_bar]
configuration.yaml
- platform: files
folder: /config/www/img
filter: '**/*.jpg'
sort: date
recursive: True
tv_media.yaml
template:
- select:
- name: conditional_media
state: >
{% set recently_added = 'gallery' %}
{% set recently_added_backup = 'Recently Added (Offline)' %}
{% set paused_timeout_minutes = 15 %}
{% set media_players = [
states.media_player.tv_wohnzimmer_2,
states.media_player.tv_schlafzimmer_2,
states.media_player.vardagsrum,
states.media_player.lea,
states.sensor.ps5_101_activity,
states.media_player.wohnzimmer_oben,
states.media_player.schlafzimmer,
states.media_player.buro,
states.media_player.maja,
states.media_player.kuche,
states.media_player.fernseher_maja_2 ] %}
{% macro media(state) %}
{% set state = media_players | selectattr('state','eq',state) | list %}
{% set last_changed = recently_added if state | length == 0 else state | map(attribute='last_changed') | list | max %}
{{ state | selectattr('last_changed','eq', last_changed) | map(attribute='name') | list | join }}
{% endmacro %}
{% set recently_added = recently_added_backup if is_state('sensor.recently_added_offline','Active') else recently_added %}
{% set playing = media_players | selectattr('state','eq','playing') | list %}
{% set timeout_playing = False if on | length == 0 else
(as_timestamp(now()) - as_timestamp(on | map(attribute='last_changed') | list | max)) < paused_timeout_minutes * 60 %}
{% set paused = media_players | selectattr('state','eq','paused') | list %}
{% set timeout_paused = False if paused | length == 0 else
(as_timestamp(now()) - as_timestamp(paused | map(attribute='last_changed') | list | max)) < paused_timeout_minutes * 60 %}
{% if playing %}
{{ media('playing') if timeout_playing else media('paused') if timeout_paused else media('playing') }}
{% elif paused %}
{{ media('paused') if timeout_paused else recently_added }}
{% else %}
{{ recently_added }}
{% endif %}
options: >
{% set recently_added = ['gallery'] %}
{% set recently_added_backup = ['Recently Added (Offline)'] %}
{{ recently_added + recently_added_backup + media_players | map(attribute='name') | list }}
select_option:
service: select.select_option
entity_id: select.conditional_media
option: >
{{ option }}
I hope that I don´t forget something
How do you get that green glow around the buttons?
Its just some box-shadow styling, based on state, that I added to the button card template that I use for those particular button cards:
card:
- border-width: 0
- transition: none
? 'rgb(0, 0, 0)'
: '#97989c';
- color: >
? '#4b5254'
: '#97989c';
- box-shadow: >
? '0px 0px 10px 3px red'
: '0px 0px 10px 3px green';
This is great!
Unfortunately, I’m unable to make it work in several grids at the same time; only the first one is showing the values.
E.g., below an example of my dashboard where I have one grid per room and I’d like to have the temperature and humidity in each title. However, only the first one shows. Is this expected or is there any way to make it work like this?
The goal is to eliminate those 4 cards and avoid having to swipe whenever I need to turn on a light using the wallpanel
I adapt the code template from VietNgoc to the following:
Font Size and Icon Size can adapt to your needs.
Now you can show on all grifs: Temperature, Humidity, Position of a thermostat valve (or your lux sensor) and motion.
For example:
tempsensor: sensor.buero2_temperature
humidsensor: sensor.buero_position
positionSensor: sensor.buero_position
motionSensor: binary_sensor.bewegungsmelder_treppe
fontSize: 0.8rem
motionIconSize: 15px
when there is no sensor defined then nothing will be shown. I hope that works.
change_grid_title:
state_display: >
function findFirstH1Above(element) {
let currentElement = element;
while (currentElement) {
if (currentElement.shadowRoot) {
const shadowH1 = currentElement.shadowRoot.querySelector('h1');
if (shadowH1) return shadowH1;
const lightH1 = currentElement.querySelector('h1');
if (lightH1) return lightH1;
currentElement = currentElement.getRootNode().host;
if (!currentElement) break;
return null;
let parentElement = this.getRootNode().host;
let headerTitle = findFirstH1Above(parentElement);
if (headerTitle && !headerTitle.dataset.processed) {
const tempSensor = parseFloat(states[variables.tempsensor]?.state);
const humidSensor = parseFloat(states[variables.humidsensor]?.state);
const positionSensor = parseFloat(states[variables.positionSensor]?.state);
const motionState = states[variables.motionSensor]?.state;
const motionIcon = motionState === 'on' ? 'mdi:motion-sensor' : 'mdi:motion-sensor-off';
const fontSize = variables.fontSize || '14px';
const motionIconSize = variables.motionIconSize || '20px';
let currentTitle = headerTitle.innerText;
headerTitle.style.display = 'flex';
headerTitle.style.width = '100%';
headerTitle.style.justifyContent = 'space-between';
headerTitle.style.alignItems = 'center';
headerTitle.style.paddingInline = 'inherit';
const formattedTemp = !isNaN(tempSensor) ?
(tempSensor % 1 === 0 ? tempSensor.toFixed(0) : tempSensor.toFixed(1)).replace('.', ',') + '°C' : '';
const formattedHumid = !isNaN(humidSensor) ? humidSensor.toFixed(0) + '%' : '';
const formattedPosition = !isNaN(positionSensor) ? positionSensor.toFixed(0) + '%' : '';
let sensorValues = [];
if (formattedTemp) sensorValues.push(formattedTemp);
if (formattedHumid) sensorValues.push(formattedHumid);
if (formattedPosition) sensorValues.push(formattedPosition);
const sensorDisplay = sensorValues.join(' / ');
const motionIconHTML = states[variables.motionSensor]
? `<ha-icon icon="${motionIcon}" style="margin-left: 5px; --mdc-icon-size: ${motionIconSize};"></ha-icon>`
headerTitle.innerHTML = `
<div>${currentTitle}</div>
<div style="font-size: ${fontSize}; display: flex; align-items: center;">
${sensorDisplay}
${motionIconHTML}
</div>
headerTitle.dataset.processed = true;
best, Michael
I have an issue with padding value of the grid header and I don´t find where I can change it without installing car-mod. For faster page visivility on older tablets I would like to use it without card-mod:
The green marked padding are should be smaller.
Thanks,
Michael
I think there is no other way to interfere with css without card-mod. Because this is a default lovelace grid card from HA, not custom
thanks for your answer. that’s a pity. Is there any chance to change the source code of lovelace or whereever these .card-header element comes from. Even under the risk that I need to do it again after any update.
Does anyone have an idea how to scale the sidebar relative to the right side? Now the sidebar is too big and that is at the expense of the rest of the display.
