A different take on designing a Lovelace UI
you missed class: sidebar and use custom:hui-markdown-card
- type: custom:hui-markdown-card
  class: sidebar
  style:
    {top: 9%, left: 11.1%}
  content: >
    <span>{{ states('sensor.time') }}</span>
card-mod class in themes.yaml
.sidebar {
  font-size: 1.5vw;
  font-weight: 300;
  opacity: 0.75;
  width: 15.5vw;
  height: 1px;
the clock is styled card-mod-card-yaml:
ha-markdown-element>p>span {
  font-family: SF Text;
  font-size: 5vw;
  font-weight: 200;
  margin-left: -0.3vw;
  letter-spacing: -0.05vw;
also add “markdown fix” in ui-lovelace.yaml
# markdown fix
- type: custom:hui-element
  card_type: markdown
  style: {opacity: 0}
  content: preload
profit
Another question @Mattias_Persson. I see you have changed some files in your browser mod custom component. Do you recommend to integrate them as well and could that be the reason for all my popups have lost the styling?
Great spotted. And great explanation. Thanks!
But still no luck, I have also changed the hui-markdown-card and both themes.yaml and markdown fix was already integrated.
title: Hjem
  - panel: true
    path: default_view
    cards:
      - type: picture-elements
        image: /local/background.png
        elements:
          # markdown fix
            card_type: markdown
            style: {opacity: 0}
            content: preload
          #                              * Sidebar *                               #
          - type: image
            image: local/sidebar.png
            tap_action:
              action: none
            hold_action:
              action: none
            style:
              {top: 49.24%, left: 10.6%, width: 21.5%, pointer-events: none, border-right: '1.5px solid rgba(58,69,73,0.2)'}
          #                  * Markdown *                 #
            class: sidebar
            style:
            content: >
Thanks in advance
Have you updated card-mod?
Yes, all should be fully updated.
Card-mod is 2.0.3
What exactly do you mean by this?
Is your themes.yaml actually included in configuration.yaml and have you selected the theme in the ha UI?
I was browsing your folders and spotted that there where changes in your browser_mod folder.
If I ex. look at services.yaml I have this:
command:
  description: Send a command to a browser
  fields:
    command:
      description: Command to send
      example: 'navigate'
    deviceID:
      description: List of receiving browsers
      example: '["99980b13-dabc9563", "office_computer"]'
And you have
You’re right, that was changed in the UI.
Then my main issue is the Person pop-up:
I tried to changed from yours a little, into this:
              action: call-service
              service: browser_mod.popup
              service_data:
                title: Martin
                deviceID: this
                style:
                    :host .content {
                      height: 675px;
                card:
                  type: custom:stack-in-card
                  cards:
                    - type: entities
                      state_color: true
                      show_header_toggle: false
                      entities:
                        - entity: person.martin
                          secondary_info: last-changed
                    - type: entities
                      entities:
                        - entity: sensor.viessmann
                          icon: mdi:calculator
                        - entity: sensor.hjem_map
                          icon: mdi:castle
                          card_type: glance
                          show_state: false
                          style:
                              ha-card {
                                background: none;
                                box-shadow: none;
                            "ha-card>div>div:nth-child(1)":
                                "state-badge":
                                    ha-icon {
                                      color: {{ '#3182b7' if is_state('device_tracker.martin', 'home') else '#FFFFFF20' }};
                            "ha-card>div>div:nth-child(3)":
                                "state-badge":
                                    ha-icon {
                                      color: {{ '#3182b7' if is_state('device_tracker.martins_iphone_2', 'home') else '#FFFFFF20' }};
                      card_type: map
                      class: map
                      entities: [device_tracker.martins_iphone_2]
                      default_zoom: 15
Can you spot my mistake?
browser mod is just updated in hacs, I have not changed anything in the integration.
I guess the person popup issue is related to stack-in-card 0.2.0, I downgraded to the previous version, until I have time to figure out what broke the styling
Very nice,
How do you did it with the rainforcast?
Downgraded as well. Didn’t fix it.
Unless you see something wrong, I’ll keep trying myself.
Thanks for your help :slight_smile:
I’ll be back again :wink:
Right now I’m still working on getting my Velux covers up and running and I want to integrate my Nilan ventilation and Wavin floor heating.
FYI above problem with the markdown is also fixed. Found a typo after changing to hui-markdown-card
hi @Mattias_Persson and thanks for the very nice theme and inspirations!
how can i build/style the popup “close” Button outside from the Popup-Item?
And with Name?
Thanks!
Just to prove a point I upgraded. Remember stack-in-card and do a hard refresh.
yes i check this.
here the “Close” buttons:
You are right. I was wrong. The hard refresh was needed…
Thought frontend HACS didn’t need that.
Thanks again Matthias! For your patience and help.
Hi Mattias,
Thanks for sharing this great design.
Does someone get the sliders to work on a iPad or iPhone?
I use google or alexa to turn on lights and so but sometime I use the iPad to dim.
Hi Matthias
Another question.
How would you make the Sonos and Apple TV icon appear when there’s a cover on the button card?
2020-12-29_17h15_05
Hi Mattias,
Great design.
I have a question,
How do you get Entities card and a Bar card in line?
I have try it in 2 different way’s, but get the same result.
The icon and the name of te entity of the bar card stands more to the left than the Entities card.
How can I fix this?
I think I did it that way because otherwise the icon covers too much
basically opacity is set to 1 or 0 depending on cover art
