A different take on designing a Lovelace UI
HI,
which font-family you use? here my grafik
yours looks better :slight_smile:
thy
I have added the fonts Mattias uses in his design. They are placed in www/fonts and it is the families of SF-Mono, SF-UI-Display and SF-UI-Text.
hmm i have the same config and fonts but looks different
Aah. That’s it. Wasn’t aware of that. Thanks
can someone please tell me how I do the red update notification, like the picture…image
Well, since today update, my custom css classes stoped working. Anyone with this problem?
#Markdown da sidebar
          - type: custom:hui-markdown-card
            class: relogio
            style:
              {top: 9%, left: 11.1%}
            content: >
              <span>{{ states('sensor.time') }}</span>
The syle file:
card-mod-card: |
  ha-card {
    background: none;
    box-shadow: none;
    border-radius: 0;
  .card-header {
    margin: -0.5em 0 1.1em 0.4em;
    font-family: SF Text;
    letter-spacing: 0.005em;
    font-size: 1.5em;
    *              TYPES              *
  ha-card.type-entities {
    background: none;
    padding: 0.3em 1.25em 0.4em 0.5em;
  ha-card.type-custom-stack-in-card {
    background: none;
  ha-card.type-history-graph {
    margin: 0.8em -1.9em -1.5em -0.8em;
  ha-card.type-custom-hui-markdown-card {
    font-family: SF Display;
    line-height: 2.05vw;
    letter-spacing: 0.06vw;
    color: rgba(255, 255, 255, 0.9);
    pointer-events: none;
    *             CLASSES             *
  ha-card.add_header {
    background: linear-gradient(180deg,
      var(--card-header) 0%,
      var(--card-header) 4.6em,
      var(--card-color) 4.6em,
      var(--card-color) 100%);
    border-radius: 1em;
  .sidebar{
    font-size: 1.3vw;
    font-weight: 300;
    opacity: 0.75;
    width: 15.5vw;
    color: red;
    height: 1px;
  .relogio{
    font-size: 5vw;
    font-weight: 200;
    letter-spacing: -0.05vw;
    color: red;
Nope. Check if the tablet theme in http://url:8123/profile is selected.
Don’t use it anymore but it’s a conditional image
Thanks for the post, great ideas, almost done with a minimal layout for a 7 inch tablet that goes on the wall
Only thing i haven’t been able to do is make the image of what is playing appear in the circle on top of the music card, where the icon normally would go. The image option is a hardcoded url that works if i put it in with quotes “”, but it changes with every image. I want to pass the attribute of the variable doing states.entity_id.attributes.media_url but i haven’t been able to make it work even tho i tried a bunch of variations of the code.
Hi guaro2k,
have you a code for your Temp and Humidity?
Looks great.
You can install the custom:mini-graph-card and just call it when you are calling the entity.
so, after “entities:” instead of calling - entity: entity.id just do - card: ‘custom:mini-graph-card’, see example bellow
padding helps to give a little more space for all the data, check the mini-graph-card add-on for other cool options, I haven’t tried all of them in this HomeKit implementation, I’ve found that not all addons options work
  - card: 'custom:mini-graph-card'
                noPadding: true
                cardOptions:
                  entities:
                    - sensor.rm4_humidity
                noPadding: true
                cardOptions:
                  entities:
                    - sensor.rm4_temperature
Has anyone configured speaker groups and synced volume under this design? I haven’t been able
im using this add-on and code:
 - type: 'custom:mini-media-player'
                sync_volume: true
                entity: media_player.living_room
                image: >-
                  {{ state(media_player.living_room.attributes.entity_picture)
                speaker_group:
                  platform: sonos
                  show_group_count: true
                  artwork: full-cover
                  sync_volume: true
                  expanded: false
                  entities:
                    - entity_id: media_player.Living_Room
                    - entity_id: media_player.Living_Room_2
                      sync_volume: true
Check my plex in ui-lovelace. It’s possible that you had the template working but your css was off. Try setting it as a background or something like that first.
styles:
  custom_fields:
    media_image: &plex_poster
      [background-position: center center, background-image:
      "[[[ return 'url(' + states[entity.entity_id].attributes.data[1].fanart + ')'; ]]]"]
Mattias, how to install it? I cant find any discription.
Verry nice work on the cover. I try to copie it but can’t get it to work :thinking:
Where did you place this? In the button card template or did you create a new one?
How did you place it in youre ui-lovelace.yaml?
Good evening,
I added your sidebar_active to me, so where should be shown which lights are still on. but unfortunately I only get the status unavailable …side active
state
Use the configuration as inspiration. It is not plug and play.
Yes i have found it. Thx!
Do you do this in the button card cause I don’t get it to work.
                  - type: custom:button-card
                    entities:
                      - card: "custom:mini-graph-card"
                        noPadding: true
                        cardOptions:
                          entities:
                            - sensor.tunex_b301_hum
                    style:
                      width: 10%
                    custom_fields:
                      icon_lamp: >
                        <ha-icon icon="mdi:thermometer"></ha-icon>
                    styles: *icon_lamp_styles
                    template: base
                    tap-action:
                      action: more-info
this looks nice, I haven’t had success getting mine to display like this, I think it because im using home kit card and it kind of works a little different than mattias implementation.
But all in all this post was exactly what I needed to create a minimalistic dashboard
