Yes, I started over again last month based on the last update of mattias. Suggest/advise you to do the same, since a lot changed (and became much better)
I tried to change to verticla-stack as matt did. But something wierd is happening.
The sidebar has no styles, the buttons appear not on the bottom and the cards from “wohnzimmer” are gone.
ui-lovelace.yaml
- type: vertical-stack
view_layout:
grid-area: sidebar
cards:
- type: custom:button-card
entity: sensor.template_sidebar
template: sidebar_template
- type: grid
cards:
- type: button
icon: mdi:lightning-bolt
tap_action: !include popup/sidebar_batterie.yaml
hold_action:
action: none
- type: button
icon: mdi:information-outline
tap_action: !include popup/sidebar_information.yaml
hold_action:
action: none
- type: button
icon: mdi:arrow-up-bold-circle-outline
tap_action: !include popup/sidebar_update.yaml
hold_action:
action: none
template.yaml
template:
# TEMPLATE #
- unique_id: sidebar
state: template
attributes:
time: >
{% set hours = now().strftime('%H') %}
{% set minutes = now().strftime('%M') %}
<span class="time">
{{ hours }}<span class="time-colon">:</span>{{ minutes }}
</span>
date: |
<font color='#6a7377'><b>
{%- if strptime(states('sensor.date'), '%Y-%m-%d').day != null %}
{%- set days = ['Montag', 'Dienstag', 'Mittwoch', 'Donnerstag', 'Freitag', 'Samstag', 'Sonntag'] %}
{%- set months = ['Januar', 'Februar', 'März', 'April', 'Mai', 'Juni',
'Juli', 'August', 'September', 'Oktober', 'November', 'Dezember'] %}
{{- days[now().weekday()] }}<br>
{{- strptime(states('sensor.date'), '%Y-%m-%d').day }} {{ months[now().month-1] }}
{%- endif -%}
</b></font>
greet: |
<b>
{% set time = now().hour %}
{% if time <= 1 %} Gute Nacht {{'\U0001F611'}}
{% elif time <= 3 %} Gute Nacht {{'\U0001F62A'}}
{% elif time <= 5 %} Gute Nacht {{'\U0001F634'}}
{% elif time <= 7 %} Guten Morgen {{'\U0001F4A9'}}
{% elif time <= 9 %} Guten Morgen {{'\u2615\uFE0F'}}
{% elif time <= 10 %} Guten Morgen {{'\U0001F642'}}
{% elif time <= 13 %} Guten Tag {{'\U0001F60A'}}
{% elif time <= 15 %} Guten Tag {{'\U0001F60E'}}
{% elif time <= 17 %} Guten Tag {{'\U0001F44B\U0001F3FB'}}
{% elif time <= 19 %} Guten Abend {{'\U0001F44B\U0001F3FB'}}
{% elif time <= 22 %} Guten Abend {{'\U0001F60C'}}
{% elif time <= 23 %} Guten Abend {{'\U0001F974'}}
{% else %} Guten Abend {{'\U0001F974'}}
{% endif %}
</b>
active: |
<b>
{% set lights = [
states.light.wohnzimmer_licht,
states.light.kueche_licht,
states.light.kueche_licht_speis,
states.light.kueche_licht_spuele,
states.light.schlafzimmer_licht,
states.light.wohnzimmer_licht_tv,
states.switch.garage_licht
{% set switches = [
states.switch.werkstatt_makitaladegeraet,
states.switch.kueche_licht,
states.media_player.wohnzimmer_tv
{% set lights_on = lights | selectattr('state','eq','on') | list %}
{% set lights_name = lights | selectattr('state','eq','on') | map(attribute='name') | join(', ') %}
{% set switches_on = switches | selectattr('state','eq','on') | list %}
{% set switches_name = switches | selectattr('state','eq','on') | map(attribute='name') | join(', ') %}
{% if (lights_on | length == 0) and (switches_on | length > 0) %}
{{ switches_name | regex_replace(',([^,]*)
button-card-templates.yaml
sidebar_template:
show_state: false
show_icon: false
tap_action:
action: none
if (entity) {
let attributes = '';
for (const [key, value] of Object.entries(entity.attributes)) {
value != false ? attributes += `<p>${value}</p>` : null;
return attributes;
extra_styles: |
#card {
padding: 0;
#container {
display: flex !important;
#name {
padding: 1.8vw 2.5vw 0 var(--custom-layout-card-padding);
white-space: normal;
text-align: left;
.time {
font-family: SF Text;
font-size: var(--sidebar-time-font-size);
font-weight: 200;
line-height: var(--sidebar-time-line-height);
letter-spacing: -0.05vw;
margin-left: -0.3vw;
color: rgba(255, 255, 255, 0.8);
.time-colon {
position: relative;
top: -.09em;
p {
font-family: SF Display;
font-size: var(--sidebar-font-size);
line-height: var(--sidebar-line-height);
font-weight: 300;
letter-spacing: 0.06vw;
color: #6a7377;
p > b {
/* portrait */
@media screen and (max-width: 1200px) {
.time {
font-size: calc(var(--sidebar-time-font-size) * 1.4 );
line-height: calc(var(--sidebar-time-line-height) * 1.4 );
p {
font-size: calc(var(--sidebar-font-size) * 1.4 );
line-height: calc(var(--sidebar-line-height) * 1.4 );
/* phone */
@media screen and (max-width: 800px) {
.time {
font-size: calc(var(--sidebar-time-font-size) * 2.6 );
p {
font-size: calc(var(--sidebar-font-size) * 2.6 );
line-height: calc(var(--sidebar-line-height) * 2.6 );
letter-spacing: 0.16vw;
#name {
padding: 0 0 0 1vw;
In ui-lovelace.yaml somewhere between line 3 and 45 the theme describes the grid layout it uses for several screen sizes
You should change the grid-template-columns, grid-template-rows and grid-template-areas to accommodate your situation.
I have tried a few things here as well, but can’t seem to find the correct configuration that we need
@Mattias_Persson could you maybe shine some light on this?
@JacobPantuso @Tismo
There is no one size fits all for this dashboard, Mattais pretty much provides his config, which is made of a framework (the themes.yaml an the button-card-templates.yaml) and an example for the ui-lovelace.yaml as well as all accompanying sensors/templates you could use.
But it’s up to you to make this fitting for your situation.
There is no video to set this up because there is no one size fits all approach, you don’t have the same sensors, same devices, same needs as I would have.
And even if that were the case you would still need to change/edit/fix a lot of things so it would be better to just try and work from the provided code, understand the code, and be able to actually make the necessary changes yourself and contribute to the project.
So as for global steps… There are multiple ways to go about it but the way that worked for me was:
- Backup my complete Home Assisstant setup, everything as a snapshot but also config backups
- Then you have two options:
- Start fresh (throw everything you have away and start with Mattias’ setup)
- Edit your own config to incorporate all of Mattias’ edits
- Change your used theme to the “tablet” theme (thats the name of the theme)
- Check all the errors you get in lovelace and start fixing them one by one, but most importantly: Try to understand the code structure
The code structure:
- themes.yaml (the tablet theme) pretty much contains all the general CSS code, in other words: how thing look, which colors they have, the font used, the sizes and so on
- button-card-templates.yaml contains the sidebar and the buttons that are used on the dashboard, as the name implies these are templates, as such they describe how a button is layed out, how the buttons look, how they react, but importantly: they do not contain (in most cases) the sensors themselves
- lovelace-ui.yaml contains the sensors and layout of the dahboard
So if we look at lovelace-ui.yaml it shows a button for a lamp, this button uses a template from the button-card-templates which contains the information on which icon is used, what the text is etc, and the themes.yaml contains information on the style of this button, which color it is, which font etc
@Se7enair
Did you replace the themes.yaml with the updated version?
Also your mini graphs are “floating” in the buttons, might want to check my setup
ui-lovelace.yaml
entity: sensor.lumi_lumi_weather_temperature
custom_fields:
graph:
card:
entities:
- sensor.lumi_lumi_weather_temperature
template:
- temperature
- icon_temp
button-card-templates:
temperature:
template:
- base
show_state: false
custom_fields:
circle: >
const temperature = Math.round(entity.state);
return `<svg viewBox="0 0 50 50"><circle cx="25" cy="25" r="20.5" stroke="#313638" stroke-width="1.5" fill="#FFFFFF08" style="
transform: rotate(-90deg); transform-origin: 50% 50%;" />
<text x="50%" y="54%" fill="#8d8e90" font-size="14" text-anchor="middle" alignment-baseline="middle" dominant-baseline="middle" dominant-baseline="middle">${temperature}°</text></svg>`; } ]]]
graph:
card:
type: "custom:mini-graph-card"
line_color: "#3182b7"
line_width: 4
font_size: 75
show:
icon: false
state: false
legend: false
labels: false
styles:
name: [top: 57%, left: 0%, width: 100%, position: absolute]
custom_fields:
graph: [bottom: 0%, left: 0%, width: 100%, position: absolute]
circle:
- display: initial
- width: 90%
- letter-spacing: 0.03vw
- margin: -6% -6% 0 0
- justify-self: end
- opacity: 1
icon:
- width: 67%
- fill: "#9da0a2"
Forgot to reload themes
It working now
I adopt your code for the mini-graph. Is looking better when on mobile!
The last thing now is the window which is not correct resizing when on another device. Will looking for a nicer icon.
Somebody know a nice icon for windows?
hi there, i successfully implemented matt’s beauty of Dashboard
i decided to implement some custom:swipe-card’s for single buttons. Somehow im running into problems on mobile. If i open the App for the first time the sizing is not working (pic 2). After switching to another Dashboard and going back it looks like it should.(pic 1)
Also i am trying to change the icon of one of the bottom sidebar buttons depending on the state (if automation is on or off). I copied the change color for update from theme and could change the color but i cant get the icon to change. Any ideas?
Thanks in advance !
Greetings
Hy Mathias
I started to develop my lovelace with a menu in the sidebar.
I have a yam file for each lovelace panel and one sidebar.yaml file for the menu which is called by each file.
Now, I would like to change the item menu style according to the current dashboard. Do you have any idea for a condition on the current lovelace ? Or maybe my way is not the best and I need to change the grid and have a conditional card like you mentioned it ?
Thanks for your help
hi @Mattias_Persson So that the weather card takes up more space in height. Do I have to put together a grid and customize it?
The weather card is not designed with a square layout in mind. Can you conceptualize how you would fill that space without stretching the card?
You could make your own with button card [example]
or add the weather card to the sidebar
Use the icon:
config variable instead (not custom field). if you must use <ha-icon>
you can add a css variable
custom_fields:
icon: |
<ha-icon icon="hue:play-bar" style="color:var(--button-card-light-color);"></ha-icon>
You can use this template by @Mariusthvdb for current view as a condition in sidebar yaml
[[[ return window.location.pathname.split('lovelace/')[1]; ]]]
I’m using this layout
swipe-card
→ horizontal-stack → conditional
→ grid
some people tried (which I didn’t test)
swipe-card
→ grid
→ grid
which cut off the bottom part and the reason I added height: 100%
working example
- type: grid
title: Media
view_layout:
grid-area: media
columns: 1
cards:
- type: custom:swipe-card
start_card: 1
parameters:
roundLengths: true
effect: coverflow
speed: 650
spaceBetween: 20
threshold: 7
coverflowEffect:
rotate: 80
depth: 300
cards:
- type: grid
columns: 2
cards:
entity: media_player.vardagsrum
template:
- media
- icon_apple_tv
entity: media_player.sovrum
template:
- media
- icon_apple_tv
entity: media_player.spotify
template:
- media
- icon_spotify
entity: media_player.kok
template:
- media
- icon_nest_mini
- type: grid
columns: 2
cards:
template:
- media
- icon_apple_tv
template:
- media
- icon_apple_tv
template:
- media
- icon_spotify
template:
- media
- icon_nest_mini
There’s this basic guide at least. You’re welcome to make a video
Have you tried putting custom:thermostat-dark-card
by itself and not inside custom:button-card
I bet my templates are messing with your bottom right icons. Can you post how you’ve set those up?
Yeah, and to add to that I don’t think that markdown is inherently bad but styling it is a nightmare.
The nice thing about button card is that if one doesn’t want to convert all jinja templates to javascript, incorporating existing template sensors works fine too.
