@Mattias_Persson, I don’t understand why I have an “unknow” value for sensor.igor_last_changed when I did create an mqtt entry in the sensor.yaml.
Serais-tu me dire où est le bug ?
Did you do everything in this commit?
Looks like a yaml parsing warning. Look in home-assistant.log or post the yaml of the button that gives you the error
I looked in logs but there isn’t any record regarding the vacuum.
The code I’ve used is the same like in your config:
- type: custom:button-card
entity: vacuum.roborock_s7
icon: mdi:play-pause
tap_action:
action: call-service
service: >
return entity.state === 'docked' || entity.state === 'paused'
? 'vacuum.start'
: 'vacuum.pause';
service_data: >
[[[ return entity.entity_id; ]]]
template: icon_only
Thank you a lot @Mattias_Persson
And let me to send all my appreciation about your amazing work!
Question regarding grid. How can i get the button placed all the way down and stay fixed? three buttons placed in a grid.
I have set the grid up like below.
layout:
#default
grid-gap: var(–custom-layout-card-padding)
grid-template-columns: 0.7fr 0.1fr 3fr
grid-template-rows: 7.6fr 0.1fr
grid-template-areas: |
“sidebar sidebarline stateswitch”
“footer sidebarline stateswitch”
Buttons are placed in “footer”.
If i change the grid-template-rows to a higher value than 7.6 fr the scroller comes up on the right. the button also seem to follow if a card is placed lower than the buttons.
I am trying to archieve a fixed sidebar where i have stateswitch i can change the main view that is also in a layout grid.
Thanks Mattias.
It works for me but not for my wife. I think the sensor will cool down when she leaves the house.
Hi
Is can someone just explain how to get the fonts to work? I’ve done evertyhing but i still get the standard Homeassistant font… this is frustrating…
- I’ve added the font.css in /local
- i’ve added all the fonts in /local/fonts
still i there is no change in fonts, please help
I tried following this but I don’t get the styling for the buttons to work, and the sidebar button seems to be on the top rather than the bottom.
Oops, seems I missed that step, Thank you so much!
Yes, this has been done. But there is still no changes…
pm me your fonts
Sure, Ive sent you all fonts
Just to make sure, you’ve placed font.css
and fonts
folder in www
and NOT in a folder called local
Yes, i just did that. Placed Font.css and fonts folder in www …
You done some great work, @Mattias_Persson - I’m trying to recreate and make it my own. It is hard, but I got all the main things working, I think
Thanks for the inspiration.
