I have a few entities that are really struggling with stats. I’ve tried to correct the underlying data in the mariadb database but each hour it generates a new stat that is way off the mark. I have 3 examples but the one I’ll focus on is my space heater total kwh:
It shows as using 44,744 kWh. This is a filter entity:
- platform: filter
name: "Office Space Heater [kWh]"
entity_id: sensor.office_space_heater_raw_kwh
filters:
- filter: outlier
window_size: 10
radius: 5.0
The underlying sensor, office_space_heater_raw_kwh likes to randomly provide a super high value but in this case, I don’t see any of those in the state table:
SELECT * FROM states where entity_id = "sensor.office_space_heater_raw_kwh" and state > 2;
Returns 0 rows. The same with
SELECT * FROM states where entity_id = "sensor.office_space_heater_kwh" and state > 2;
The sensor itself has a pretty normal value:
If I run the query:
SELECT s.* FROM statistics s, statistics_meta sm where s.metadata_id = sm.id and sm.statistic_id = "sensor.office_space_heater_kwh" order by start DESC;
I see the problem statistics:
If I update the two most recent so sum = state the graph is fixed for now but it’ll break again the next hour.
I’m seeing similar challenges with 2 other entities, both are total_increasing.
My questions are:
- How is sum calculated for a statistic?
- For a total_increasing entity, how does it determine the base value/last reset value?
- Any other recommendations for fixing this?
