A few bad stats for total_increasing
I have a few entities that are really struggling with stats. I’ve tried to correct the underlying data in the mariadb database but each hour it generates a new stat that is way off the mark. I have 3 examples but the one I’ll focus on is my space heater total kwh:
It shows as using 44,744 kWh. This is a filter entity:
  - platform: filter
    name: "Office Space Heater [kWh]"
    entity_id: sensor.office_space_heater_raw_kwh
    filters:
      - filter: outlier
        window_size: 10
        radius: 5.0
The underlying sensor, office_space_heater_raw_kwh likes to randomly provide a super high value but in this case, I don’t see any of those in the state table:
SELECT * FROM states where entity_id = "sensor.office_space_heater_raw_kwh" and state > 2;
Returns 0 rows. The same with
SELECT * FROM states where entity_id = "sensor.office_space_heater_kwh" and state > 2;
The sensor itself has a pretty normal value:
If I run the query:
SELECT s.* FROM statistics s, statistics_meta sm where s.metadata_id = sm.id and sm.statistic_id = "sensor.office_space_heater_kwh" order by start DESC;
I see the problem statistics:
If I update the two most recent so sum = state the graph is fixed for now but it’ll break again the next hour.
I’m seeing similar challenges with 2 other entities, both are total_increasing.
My questions are:
  1. How is sum calculated for a statistic?
  2. For a total_increasing entity, how does it determine the base value/last reset value?
  3. Any other recommendations for fixing this?
There is also a new tool for statistics that should allow you to correct errors without directly modifying the database.
Open your Home Assistant instance and show your statistics developer tools.
The tool didn’t work for me but I wasn’t updating the short-term stats when I was messing around in the database. I’ll try that!
I’ve also added some availability_template values to my entities so they don’t zero out every restart:
      gas_total:
        friendly_name: "Gas Total"
        device_class: gas
        unit_of_measurement: ft³
        value_template: "{{ states('sensor.ert_scm_45647446_consumption') }}"
        availability_template: "{{ states('sensor.ert_scm_45647446_consumption') | float(0) > 0.1 }}"
      gas_cost:
        friendly_name: 'Gas Cost'
        value_template: "{{ (states('sensor.png_gas_price_per_ft3')|float * (states('sensor.gas_total')|float - 411780))| round(2) }}"
        unit_of_measurement: 'USD'
        availability_template: "{{ states('sensor.gas_total') | float(0) > 0.1 and states('sensor.png_gas_price_per_ft3')|float(0)  > 0.00001 }}"
