Yes i did. Because there conduits from the ceiling to the switches, and there’s a neutral wire in the ceiling, it’s very easy to connect a new neutral wire from ceiling to switch:
- Disable voltage on light, check it!
- Open switch
- Tape a normal string very tight(!) on one of the two switch wires
- pull the switch wire out of the ceiling
- Tape the new neutral wire onto the switch wire and the string
- pull the string out of your switch and the neutral wire and the switch wire will appear
Good luck!
