Hi everyone,
I’ve been having some instability in my z-wave network so I decided I should try qt-openzwave to check if it improves my situation. Now I have a new issues but i’m not sure if it’s my networks fault or qt-openzwave bugs/limitations. In the past I had to add a few devices using ozwcp because if I did it through HA they wouldn’t get added. As I know there are a few devs around i thought i’d ask before submiting issues.
Migration process: Stop Z-wave network in HA. Remove native Z-Wave integration. Stop HA core. Create and start docker container for ozwdaemon. Start HA. Add HACS component. Download ozwd windows client into my desktop.
Most of my zwave devices don’t show up as Z-Wave Plus but I know for sure I added them securely in HA. For example the Qubino Light Dimmer and Fibaro FGS223. However I had a FGBS-222 that was disconnected and marked as dead and after starting it up and refreshing the node it’s now marked as Z-Wave +. It’s the only node where this happens. Tried the same procedure for the other ones but it doesn’t work.
I get Command class 0x32 not supported in OZW log and I don’t seen any power reports in HA. Is this a planned feature? Any rough roadmap?
The Fibaro FGS223 is a dual channel switch but I only get the first channel added to HA. Is this a qt-openzwave issue? How can I tell?
A battery powered Vision Garage door detector is missing alot of info and doesn’t get created in HA.This should be supported right? It only uses basic command class.
Cheers.
