Problem seems to be solved.
Looks like the ext. board ‘X850’ was not compatible with mSATA SSD disk used.
I.e. tryied with disk ‘32GB SSD/mSATA Lite-ON LMT-32L3M-HP’ (1st picture).
Or maybe the letters ‘HP’ on the description says that this disk/firmware can work with ‘HP’ laptops only. Checked with 2 disks, so one of above (or both) is true…
When switched to other type of ‘mSATA’ disk (2nd picture) - the installation was successful…
Conclusion: please do no use this type of disk >> LMT-32L3M-HP <<.
After few days of working looks like the system is stable.
So now I have ‘hassio’ on ‘SSD’, no bugs/problems observed.
Updates are also installing without any problems.
I can suggest this solution…
The only problem I noticed - I can not use ‘USB camera’ plugged-in in my ‘RPI’.
The problem is - when camera is plugged on other USB port the ‘RPI’ is not booting at all (from SSD). Looks like it is some conflict…
I did not looked so deeply in this issue - simply disconnected my camera.
Is that any solution allowing to work the ‘USB camera’ an boot the ‘RPI’ with camera installed…???
