Here is what I am trying to do.
When a door is opened a verbal warning is given and alerts are sent to their respective destinations.
That bit is fine and set in a separate automation as below;
- id: '1541766423802'
alias: Study door alarm
- platform: state
entity_id: binary_sensor.study_single_door
to: 'on'
- service: notify.pushbullet
title: Alert
message: Someone has entered your study
- service: notify.mycroft
message: You are not john so you had best get out you have 10 seconds to comply.
- service: mqtt.publish
topic: 'homeassistant/tts/android_johns_phone_tts/tts'
payload: 'Someone has opened your study door'
topic: 'homeassistant/tts/android_nexus_9_tts/tts'
I’ve set a timer
timer:
siren:
duration: '00:03:00'
What I am trying to do is after that occurs and if my siren automation is turned on, get an 11 second delay before the siren (120DB) fires in that room. The siren works fine by the switch. (currently it is a sonoffS20 with a fan attached. No point in being deaf as well a daft).
So I have a second automation that is;
- id: '1551277334508'
alias: set siren
initial_state: 'off'
- platform: state
to: 'on'
condition: []
- service: script.start_siren
entity_id: start.siren
title: Alert
message: The alarm is sounding
payload: 'The alarm is sounding'
hide_entity: false
My script is;
start_siren:
alias: Start siren
sequence:
- delay: 00:00:11
- service: timer.start
entity_id: timer.siren
- service: switch.turn_on
entity_id: switch.coffee_machine_2
pause_siren:
alias: Pause siren
sequence:
- service: timer.pause
cancel_siren:
alias: Cancel siren
sequence:
- service: timer.cancel
- service: switch.turn_off
entity_id:
- switch.coffee_machine_2
finish_siren:
alias: Finish siren
sequence:
- service: timer.finish
entity_id:
But the script doesn’t fire even if I call it from the developer tools service tab?
The end result of what I am trying to achieve it to issue the 10 second warning and then if the door is not closed within that fire the siren for three minutes until it is.
There may be an addition to rinse and repeat if a motion sensor is triggered. Just in case they shut the door without leaving ( the sensor is done and trivial TBH).
If there is a better way of doing it I am all for the learning. I went the scripting route as I want to reuse it for several other doors. And an outside siren.
I did a similar one for the mancave where if I was away and the door was opened, the camera went into record and one second later 120DB fired in a ten foot by ten foot space.
Some of the footage was epic!
I don’t live in a bad neighborhood. I just have some extended family that are lets say, light fingered.
So if a good soul would help me understand first where I’ve messed up; and then and if, there is a better way of achieving the results that I am looking for then I am all ears. Pointers, examples, links to docs I missed all are welcome. I’d rather learn by example than expect another to do it for me!
John
