A little help with statistics sensor
Hi all
I just updated HA to 2021.12.7 version
I have the following sensor which I don’t understand how I should update correctly according to the new demands (state_characteristic:)
  • the sensor.wind_speed is an anemometer which shows the wind speed every 10 seconds.
  - platform: statistics
    entity_id: sensor.wind_speed
    name: wind speed ss 90 m4
    sampling_size: 90
    max_age:
      minutes: 4
I thought that the following should do but it doesn’t calculate the values as before.
    state_characteristic: value_max
    sampling_size: 90
    max_age:
      minutes: 4
Can someone help-explain please?
edit: I think I have to add
state_characteristic: mean
but if someone could confirm it would help.
nothing from the above works as before. I don’t know what I should change
Shouldn’t the name be surrounded by quotes?
Before I can say mean or value_max need to know, do you want 4 minute mean or max wind speed?
if mean, then yes state characteristic should be mean.
Hi and Happy New Year.
To be honest I think that the mean is what i need. Do you know what the below sensor calculates? (mean?)
Regarding the quotes I am not sure. I have it withoutt quotes and it doesn’t produce any problem.
    sampling_size: 90
    max_age:
      minutes: 4
[/quote]
It should calculate the mean based on 4 minutes of data or 90 data points whichever is smaller.
From here:
The statistics sensor updates with every source sensor update. The value of the sensor represents one statistical characteristic, with mean being the default. The time period and/or number of recent state that should be considered is an important factor here. Check the configuration section below for options.
state_characteristic string (Optional, default: mean / count)
The characteristic that should be used as the state of the statistics sensor (see table above). Beware that this parameter will become mandatory in a future version. Include in your configuration. If currently omitted, the default characteristic for a sensor source sensor is “mean”, for a binary_sensor “count”.
If it is going to become mandatory it is a good idea to explicitly name it.
I think that mean is working fine now. It need more time to calculate the values correct. Thanks!
