Hi, yesterday i integrated the Roborock vacuum cleaner but after integration i am receiving a lot of warning in the home-assistant.log . I couldn’t find solution in the forum so what can be the problem ?
I have roborock s5 which do not have camera.
2023-03-07 12:04:03.663 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for camera.berta_map exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2023-03-07 12:09:03.665 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for camera.berta_map exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2023-03-07 12:14:03.666 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for camera.berta_map exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2023-03-07 12:19:03.666 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for camera.berta_map exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2023-03-07 12:24:03.667 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for camera.berta_map exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2023-03-07 12:29:03.667 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for camera.berta_map exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2023-03-07 12:34:03.668 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for camera.berta_map exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2023-03-07 12:39:03.671 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for camera.berta_map exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
