I wanted a remote tongue jack switch, so I cut a small hole in the side of the trailer. Cut right through the solar wire. Energized the -12V trailer frame with +46 volts. All 12V devices that did not have a physical off switch were immediately fried. Inverter, radio, lighting system, refrigerator, bathroom fan—all fried.
I rebuilt everything and made it better using a Raspberry Pi running Home Assistant, a bunch of ESP32 microcontrollers, and various discrete electronic components. The main interface is an iPad mounted where the old lighting control was, along with some other conveniently mounted switches.
- Auto water pump activation and shutdown: Walk into the bathroom, pump turns on. Leave the bathroom, pump turns off.
- Lighting: All lights are now dimmers, including exterior lights (because I could).
- Thermostatically controlled exhaust fan: Very handy for controlling the indoor temperature when the trailer is sitting idle.
- Security: All doors, including bay doors, have contact sensors connected to an alarm system.
- Environment: Indoor, outdoor, and bay area temperature sensors.
- Energy monitoring: The energy features tell me the state of the solar, battery, 12V, and 120V circuits. Battery time remaining for both discharge and recharge is very handy.
- Tank level sensors: Propane and water tanks. I reused the step-ladder sensors on the water tanks. I can read exact voltages and finesse the data any way I want, and they still don’t work very well.
- Internet connection: If connected to the internet, I have weather info and remote operation of the entire system. I can be remotely alerted by the alarm system.
- Trailer level indicators: There are gauges that show me the side-to-side and front-to-back level of the trailer. It also tells me how much I need to raise or lower the tongue or wheels to get it perfectly level.
- Automatic awning retraction: There is multi stage awning retraction depending on the wind speed and gust. Rain is also incorporated. The amount it retracts depends on the severity of the wind speed, gusts, and rain intensity.
