Integrate two outdoor and three indoor cameras at first just as visualization and detection on HA and then, maybe, with a NVR;
Share files and multimedia between my other PCs and TVs;
Which installation is the best for my purpose?
How would the decision be influenced if I wanted to use the PC also for everyday use (internet browsing, Office…)?
It will run HA and Plex and it should be able to handle a few camera streams since you won’t be watching all of them continuously but I don’t know about an NVR since it has to run the recording software and stream all the cameras simultaneously.
I still run a Plex server on a PI 2 but without transcoding, I need to add. I used to and it would handle it in many cases but often struggle. Can’t remember now if Plex allows you to set some transcoding parameters. A PI 4 might be able to, with its 4 cores.
As for running HA, I used to run it on a PI 3b+. It was mostly fine but sometimes a little sluggish. I would just advise not to put your DB on the SD card (the SD will fail, eventually, and probably sooner than you think/hope). Many users have an SSD connected. I switched from a PI to an old laptop with an SSD, put it on the LAN (used WiFi with the PI) and use a Postgres DB. Now it’s nice and snappy.
I’m using a laptop with w10 & plex (24/7)
HA runs on hyper-V on the same machine.
Had a bit of a challenge running CC2531 usb, but solved it with a ser2tcp…
Hi everybody and thank you for your support on this task.
I am testing this configuration:
Ubuntu Desktop 20.04 as main OS and the following containers in Docker-Compose: HA Core/Mosquitto/Zigbee2mqtt/Plex/Caddy/DuckDNS/Portainer.
No cameras yet but everything else seems to be ok.
CPU is running 2% load, RAM is running 50/60% load.
I’m a bit worried about the power consumption (and expenses too)…
