A pi based control console I originally built for an ISY hub and which now supports HA as well
I originally wanted a touch screen controller for our home automation that my wife could use to turn things on/off from bedside. My home used Insteon switches controlled from an ISY-994 controller so I built a Raspberry Pi based console that was a real hit with her (and super convenient). Recently, at our seasonal home I installed z-wave switches and wanted to adapt the console for use there. So this console now can control multiple, mixed hubs from ISY and Home Assistant. While I am sure there are other projects like this on the HA side I figured I’d make it available here in case anyone found it interesting now that it supports HA.
It runs on a pi using one of a variety of touchscreens (Adafruit 2.8, 3.5, 7in, and some Chinese clones). All the source is Python (originally 2.7 but now 3.5 hence a few hacks until all my existing users move to 3) and is on github. As a part of this overall effort I also built some 3D printed cases for the console and a mechanism for mounting a 2.8 inch touchscreen with a Pi) into a single gang wall box. I have the software (and the cases) in use across 2 homes and there are a number of folks who are ISY users who are running it in their places.
Here are some photos of it on various touchscreens: https://1drv.ms/f/s!AmUpYkWiYac50CsL_zXQu3shWTMI
Here is the link to the code (including installation scripts): https://github.com/kevinkahn/softconsole
There is a long discussion thread on the ISY forums that has a history of its use and support at topic: 18026-soft-keypadlinc-like-console-from-raspberry-pi/
T the 3D case for a 3.5 inch table console and a 2.8 inch wall mount are both on Thingiverse:
Table: thing:1652666
Wall: thing:1617848
The directory with the pictures also has links to the discussion and the Thingiverse items that I couldn’t put in this post due to forum limitations on new posters.
Hope this turns out of use to someone.
Those power supplies like you use in the wall mount are dangerous used like that. They need fusing and a varistor. See discussion here:
https://forum.mysensors.org/topic/1607/safe-in-wall-ac-to-dc-transformers
Thanks for the pointer. Looks like the supply has some protections but could use some external additions - should be easy to add as they don’t look to occupy much space. FWIW the one unit I have in place has had no heating issues in its 2 year+ tenure but would be good to beef it up.
