A programmatic way to remove dead/orphaned entities
I have a lot of dead entities, orphaned entities that I would like to clean up. The UI is not helpful as it would take an unreasonable amount of time so I am looking for an programmatic way to clean it up. Anyone aware of a script where I can go and clean up all of these?
even with all the warnings, this integration is awesome.
I have come across the solution for this earlier in the stackoveflow form. Below is the link.
I guess it is the same. If its not kindly avoid the thread. I believe many are commenting with a thank you note, and when I went through the question felt like the same. I had the same issue (the one mentioned in the thread), even being employed with ai service providers, who juggles with the algorithms I wasn’t able to understand the topography of the command here. It was this thread which helped me find a solution.
