A really funny (but 100% true) story
(For the sake of “pics-or-it-didn’t-happen” proof I’ll add screenshots as I saw them during the chat sequence)
I had asked Gemini for a docker setup to connect my HA instance to Tailscale for remote access. At first it told me to setup the Tailscale addon:
I then informed it I use plain docker and not supervisor. Then it gave me a docker-compose config to use:
I then told it I use docker run not docker-compose. then it gave me a docker run config:
an eagle eye viewer (like me… :wink:) will notice that the -v entries are showing my username in the path.
For context here on my local HA debian macihine all of my docker configs are stored at the path “/home/finity/docker/…”.
At this point I suddenly wondered how Gemini knew what my directory path structure for my docker containers was. :thinking: I started running thru my head “have I told it that at some point in the past and it somehow remembered?”. :thinking: I didn’t remember doing that but maybe I had… interesting…but still slightly disturbing too. :grimacing:
So I asked it:
And it’s reply was so unexpected that it pretty much completely floored me…
:exploding_head: :exploding_head: :exploding_head:
It had…just by pure chance…used my own data that I had posted to the forums and which that data has spread so far on the web that the LLM model had trained on it as an example docker run command configuration and fed it back to me!!
I told it that I was that user:
The odds of that have to be fairly astronimical.
So for all of those times in the past (and probably in the future) that the mods and devs in HA have told me that since I’m not a contributor to HA that my opinions and posts aren’t worthwhile I say…
Gemini disagrees with you.
My contributions from my prolific posts on this forum over the last 9 years has literally been used by at least one AI model to teach people (including me) how to set up a working docker container totally unrelated to HA itself.
I have to say that feels pretty damn good.
:smile:
Brilliant - thanks for sharing.
You can now retire from human participation and hand over your forum credentials to an Gemini agent. :robot:
It will continue your work even after you bite the gras :seedling::headstone:
Thank’s @finity for 9 years of input - enjoy your retirement :wink:
Nice! Probably feels good to have contributed toward helping so many people.
I had a similar discussion with AI recently, when it started reference things on my own local machine, and started calling me by name, even though I wasn’t logged on to the site.
I asked how it knew all that, and It actually answered believably. Yes, I had posted some logs and other output which probably gave it some hints. Still, pretty creepy.
The browser search AI bots can also have access to the page you’re currently on when you enter the prompt. That was kind of weird at first, too. Now I go into a separate, private browser window if I want a response untarnished by what I’m already looking at.
One of them actually put up a request to give it access to all the tabs currently open in the browser. I guess I can see where that might be useful. I’m just not quite ready to go there yet.
Wasted some time recently trying to containerize my HA using AI, and problem is that AI relays on historical data which is not up to fast changing HA setup. For Tailscale I manually found guide on Tailscale - Home Assistant but again cant guarantee it is up to date.
Thanks but the info Gemini gave me ended up to be exactly correct.
I finished setting it up today and switched everything over to using Tailscale.
