A safe extern communication without duckdns?
Is there an other method beside duckdns to have external login on HA?
I do now have duckdns running, but then TTS is not working because of SSL.
Or is there a possibility to run TTS when base_url is https://mydns.duckdns.org:8123?
Because now or TTS is not functioning (base_url is ending with :8123) and duckdns is
or TTS is running (base_url without :8123 at the end) and duckdns remote login is not working
Not necessary anymore.
I did get it working, by adding a specific url_base at TTS
HI, i have the same problem. i have duckdns installed but no luck with base_url.
Did you use an IP or duckdns url?
thanks
I do use a duckdns url without :8123 as base_url for tts. But I didn’t fix my problem if Duckdns is down.
Ok did you set it in config.yalm at http: or tts: options? With or without https://?
http:
base_url: https://myname.duckdns.org:8123
tts:
Thanks fo the replay, but it didnt work for me:(.
thanks any way
