fspatt
(FrankS61)
August 30, 2024, 5:59am
1
Periodic failure and not just one device. If I VPN into my network, no problems. Same when I’m locally connected. Doesn’t always happen, seems random.
Running HA Yellow. I am running reverse proxy with NGINX (3.10.01) with DuckDNS (1.18.0)
Core2024.8.3
Supervisor2024.08.0
Operating System13.1
Frontend20240809.0
Not sure what the issue is and where to begin looking.
WallyR
(Wally)
August 30, 2024, 8:23am
2
That is an Apple iOS error.
The iOS can’t find the domain name and it is not even getting to the HA part of the system.
You need to look into your DNS servers on the device and maybe contact your ISP.
O2 have been seen blocking duckDNS domains at one point.
fspatt
(FrankS61)
August 30, 2024, 8:30am
3
Thank you @WallyR . This only happens on the LTE/5G networks so I think it might be hard to investigate that way.
But again, doesn’t happen all the time. It’s just sort of periodic. Maybe switching to a better DDNS?
Suggestions?
sabouarthur
(Arthur Saboundjian)
August 30, 2024, 9:07am
4
Just switch your WIFI/LTE OFF and switch it On.
I have time to time this one as well
fspatt
(FrankS61)
August 30, 2024, 9:17am
5
Yes, thank you. I do this. Just wondering if I can “solve” it or it just is what it is.
francisp
(Francis)
August 30, 2024, 9:45am
6
Not free (you need a paid domain name), but cloudflare DNS is rock solid
WallyR
(Wally)
August 30, 2024, 2:42pm
7
It depends on your ISP’s setup.
If there DNS servers are just bad or they use it for blocking, what they see as malicious domains, then you might be able configure your own on the device.
If your ISP use DPI (Deep Packet Inspection), then your might be able to use dns-over-https, if it is available. Otherwise your best bet is to switch ISP.
fspatt
(FrankS61)
August 31, 2024, 6:09am
8
Thanks again. Can’t really switch ISP but I’m thinking of switching DDNS providers.
WallyR
(Wally)
August 31, 2024, 8:21am
9
That might help too.
It seems it is especially duckDNS that gets hit with this issue.
I guess because they are so big a player in that field.
plh4
(Daniel)
September 10, 2024, 9:53pm
10
Have the same problem since I switched to DuckDNS. Before I used Netgear DynDNS, but DuckDNS seemed to be good solution, especially with SSL.
It only happens randomly, but via mobile and Wifi. After a few minutes all working again. Telekom/T-Mobile Germany.
Is there no othere workaround? Didnt have the problem on my mac (yet), just on iPhone.
fspatt
(FrankS61)
September 12, 2024, 7:56am
11
Hi - I only have it usually on mobile, never on Wifi. I too use Telekom.
plh4
(Daniel)
September 12, 2024, 8:18am
12
I now switched to Cloudflare… hoping it will work more stable.
migue
(Miguel)
October 23, 2024, 5:21am
13
I have the same problem, and only periodically. I also use an iPhone and have only tried from duckdns.
Have you solved the problem yet?
fspatt
(FrankS61)
October 29, 2024, 2:35pm
14
I never have solved it. Never switched. Still investigating DNS / TLD options.
