So after moving to iPhone I keep getting this error message completely random on my phone. On my laptop (PC) it works and also on an Android phone so it is iPhone related. Starting to get very frustrating.
The issue is then all of a sudden gone after a afew monutes until next time I get it.
I use Duck DNS but since it is working on other devices at the same time I guess there is something else.
The message is from the iPhone, not HA.
The reason why you sometimes get the message and sometimes not is because there are usually multiple DNS servers registered and not all of them have the error.
It can be the DNS servers registered at the phone, it can be ones registered in your browser, if you use DNS-over-HTTPS, it can be the ones your adblocker is using to look sites up and it can be other programs and services in your chain that is also using DNS. The problem is that all these DNS registrations might not even be the same servers, so it can be quite a task to find the culprit.
I too get this error from time to time, it’s super annoying! I use the Home Assistant app and that’s where it comes up for me. I went several weeks with out the error coming up and then now all of a sudden it’s happening more frequently again. I’ve only noticed it when I’m connected to my home WiFi. If I toggle WiFi off and on on my iPhone it connects and works fine.
The issue is with your iPhone or your network setup/services.
It tells you that it can not lookup the server name, so DNS maybe.
It is not related to HA.
