I have problems with the tracker not constantly updating the GPS data even though the settings are correct.
I first tried uninstalling the home assistant companion application. then I reinstalled it and reconfigured it and the tracker worked fine.
then the battery died so the phone turned off.
I turned it back on and it hasn’t worked properly since then.
I went to look in the log for duplicate positions sent, etc.
and I saw that while before it gave a lot of gps data sent. after restarting the smartphone it started giving a lot of lines of duplicate locations, not accurate.
What do you think it could be? a problem with my smartphone? or other? Has anyone had the same thing happen? have you solved it?
