A water sensor in our water well
Hi there,
My text is translated from Dutch to English by chatGPT, excuses me for my bad English.
My question:
Does anyone have a good approach: we have a water well in the garden that is about 8 meters deep. A PVC pipe with a diameter of 65 millimeters extends above ground level.
I would like to lower a float with a sensor into the PVC pipe so that I can read the water level in my water well within Home Assistant.
Are there floats with sensors for this? For example, like an old-fashioned sensor in a fuel tank. Or would I need to build a sensor myself?
How can I ensure the signal is picked up above ground (from 6 meters underground)? For example, by placing a Zigbee mesh light at the top of the pipe?
I would love to hear all your creative ideas and hopefully solutions.
Have a nice day!
don’t know if it applies to your case but ultrasonic sensor and esphome can be a solution if you like to do it yourself.
Thank you. Smart, the same sensor that measures depth under a ship.
yes like that :slight_smile:
And…i found this
Ik heb dit zojuist gevonden op AliExpress:
€60,69 | Ultrasone Vloeistofniveausensor Watertank Vloeistofdieptemeter Monitor Automatische Pomp Watertoevoeging Niveaumeter
https://a.aliexpress.com/_EyA6xeo
Now i have some directions to think.
Another approach is a pressure sensor. I use that for my hot tub.
Something like this: https://nl.aliexpress.com/item/1005004979445473.html?src=google
I have it connected to a 0-10V smart Zwave device, but it can go with a lot of different formats.
In my case, it showed to be very reliable, and that matters the most for me :wink:
Also interesting, and you think that this is accurate enough?
0,5 % FS. That is 4cm on the 8m version.
Indeed, that right. Its nearly nothing.
Oh kan ook in het Nederlands aan jou zie ik.
