I’d like to automate the physical switching of those switches for all three states. Is there some kind of motor and/or other means to achieve that? There’s all-in-all 16 of that switches and mostly relevant are five of them (which in my use cases one of them has to switch to “OFF” whereas others have to be switched to “ON”…
You are prob looking to use a 16ch ESP based relay board and wire the physical switches into the common port of each one with the normally open and closed going to/from the device they control.
Funny enough: This could be a viable solution for me!
one above and one below.
challenge would be to “know/remember” the state of the switches and especially to time the motor to push for automatic in the middle.
sounds like a fun project! Perhaps a bit over-engineered, but fun nevertheless!
