I have a Gocontrol Linear GC-TBZ48 Zwave thermostat. I’ve been debugging some of the more advanced features of the thermostat. One of the things this thermostat does is that there are some states that may get reported back via zwave configuration variables. For example, if someone on the thermostat control panel changes the run/hold mode from run to hold, configuration variable #39 will change from 1 to 0. The homeassistant is indeed receiving the configuration report from openzwave and updating the values in the zwave control panel, however I don’t know of any way of being able to use this in a template sensor. I would like to be able to template this value to use it in automations. HA can currently do the reverse,be able to set a zwave config parameter via a script, but not use a zwave config parameter as a input.
The closest thing I could find is the service zwave.print_config_parameter, but that prints it to a logfile. Curiously, the zwave attributes of a device include things like baud rate and the neighbor table. Perhaps the list of zwave configuration variables can be exposed as an attribute as an encoded string “1:255, 5:10” Where parameter 1 is 255 and parameter 5 is 10. I could at at least use regex_search in a template on that string to accomplish what I want.
