Hi all,
I’m new on this HA world and need help regarding aarlo integration.
I was able to set aarlo integration and the standard arm / disarm panel works, but in my Arlo app there are 2 camera connected to the hub and 3 camera connected to the wifi. So the 2 camera connected to the hub when I use the arm button on HA will be armed but the other 3 camera no. So my request is how I can arm / disarm all camera? Can anyone help me? Thanks
Hi @QuakeGio83,
could you specify the type of the cameras?
It may depend on the compatibility. If the cameras are supported by the aarlo integration, it is a matter of the correct config. If you can’t find them check the debug logs:
https://github.com/twrecked/hass-aarlo#configuration-camera
Hope this helps.
Hi
The camera are the arlo essential spotlight
Today i also update to latest aarlo version but the battery drain still happened
Thanks in advance
