I can’t work out where I’m going wrong here, hoping for some help. I can’t get my Arlo base station to change mode, I have the following in the config file:
This pulls all the cameras, base station, etc., so I can see them in my list of entities. Now I try to make an automation with the action below, but it will not change in the Arlo app when I check:
- id: '1698498970803'
description: ''
trigger: []
condition: []
- service: alarm_control_panel.aarlo_set_mode
entity_id: alarm_control_panel.aarlo_rosewood_way
mode: home
mode: single
I’ve tried both mapped modes, but neither work. FYI, I am manually triggering the automation right now, just for testing…
I can not also change modes, after changing to the “new experience” on the Arlo app and all the fta problems that I was able to get help on and work through. Wish this worked again
I jump in this discussion because I’m totally lost with Aarlo. I guess it’s partly due on my lack of experience in HA. Indeed, I just left domoticz to implement HA, but I realize every time I try to add something that the philosophy are totally different. Any way…
Firstly, I simply wanted to use HA to change the mode of surveillance. But I can’t even understand how to achieve this.
I’ve got Aarlo installed and connected to my arlo account. I can see live streaming on a card.
Then, to test it, I just wanted to manually change the state with a button on my dashboard :
automation:
-alias: Arlo armed quand personne a la maison
-platform: state
entity_id: alarm_control_panel.alarmo
to: 'triggered'
entity_id: alarm_control_panel.aarlo_location_roquettes
mode: armed
But, it doesn’t make the trick, and here is my error message :
2023-11-12 16:17:12.980 WARNING (MainThread) [homeassistant.util.async_] Detected blocking call to putrequest inside the event loop by custom integration 'aarlo' at custom_components/aarlo/pyaarlo/backend.py, line 167: r = self._session.put(, please create a bug report at https://github.com/twrecked/hass-aarlo/issues
2023-11-12 16:17:12.980 WARNING (MainThread) [pyaarlo] request-error=RuntimeError
2023-11-12 16:17:12.981 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [139741300094656] 'NoneType' object has no attribute 'get'
