Abfallkalender in Home Assistent
Hello, my name is Volker. i come from Germany and i use a translator program, i hope that the program translates my text understandable.
I would like to add the waste calendar in my homeassitent, I followed a tutorial in this video.
The eintagen of the parameters in the file editor has worked so far, then the author of the video talked about that he outsources sensors in another yaml file, from then on the errors started with me, actually I have the Prejekt yesterday already abandoned, but I am very energetic, above all I know that runs and I would like to get it to run, unfortunately I have no idea of programming, so I would be grateful if you take me as an absolute beginner and I would be happy if I could complete the project with your help.
I entered the following lines with the file editor into the configuration.yaml,
waste_collection_schedule:
sources:
- name: Abfallkalender
args:
file: “Abfallkalender.ics”
customize:
- type: Graue Tonne
alias: rest
icon: mdi:trash-can
- type: Braune Tonne
alias: bio
icon: mdi:trash-can
- type: Gelbe Tonne
alias: gelb
icon: mdi:trash-can
- type: Blaue Tonne
alias: papier
icon: mdi:trash-can
fetch_time: “04:00”
day_switch_time: “10:00”
then came the point with the sensors, can’t I just write the parameters under the previous parameters ??
I tried, but when checking the configuration came an error message
The parameters of the sensors looks like this
  • platform: waste_collection_schedule
    details_format: “upcomming”
    value_template: ‘{{ value.daysTo}}’
    types:
    • rest
    types:
    • bio
    types:
    • gelb
    types:
    • papier
I would like to thank you in advance for your help
Hi…
Can you tell us, what exactly the error message is? Otherwise it would be a bit difficult to answer :slight_smile:
Not meant mean, but could you wrap the code in code tags? It would be easier to read, like so:
  - platform: waste_collection_schedule
    types:
      - rest
    types:
      - bio
And if noone can answer here, try this thread.
Ok, sorry. If I write all the parameters one below the other that it then looks like this, this message comes up when checking the configuration
  sources:
      args:
        file: "Abfallkalender.ics"
      customize:
        - type: Graue Tonne
          alias: rest
          icon: mdi:trash-can
          alias: bio
          icon: mdi:trash-can
        - type: Gelbe Tonne
          alias: gelb
          icon: mdi:trash-can
        - type: Blaue Tonne
          alias: papier
          icon: mdi:trash-can
  fetch_time: "04:00"
  day_switch_time: "10:00"
    details_format: "upcomming"
    value_template: '{{ value.daysTo}}'
    types:
     - rest
    types:
      - bio
    types:
      - gelb
    types:
      - papier
Typo ?
What does that mean ?
it needs to be :
details_format: “upcoming”
In the video tutorial the author also talked about separating the Configuration.yaml
He created an extra yaml file for the sensors, I did that too, and titled sensor.yaml and put in the configuration for the sensors
in the Configuration.yaml should be the entry
sensor: !include sensor.yaml
should be written
should be written
I have also done, but then comes this error message when checking the configuration
Invalid config for [sensor]: required key not provided @ data[‘platform’]. Got None. (See /config/configuration.yaml, line 46).
and line 46 of configuration.yaml is empty
Post both your configuration.yaml and sensor.yaml. Format them correct according to point 11:
Maybe also a like to that video tutorial might be helpful :slight_smile:
When using a separate file, like sensor.yaml, then there is no line like sensor:
configuration.yaml:
sensor: !include sensors.yaml
and sensors.yaml:
  types:
    - bio
it is still written wrong. Change upcomming to upcoming !!!
  details_format: "upcoming"
  types:
    - bio
Yeah, sorry, just copy&paste :frowning:
Ofcourse it’s “upcoming”. I just wanted to clarify that the word “sensor:” has to be ommited when splitting the config like that.
Here is the link to the video tutorial
Hi guys, I tried for a long time yesterday and tried again and again, nis I finally almost made it, but unfortunately the waste calendar does not show the remaining days until the corresponding garbage will be collected.
Previously also noticed during the setup of the sensors that no state is displayed with the sensors. In the video tutorial is also something that apparently there can be problems with the ics file, you should import them into a calendar and then export again, I have done everything. Is there no other way, for example, the Apple calendar, or a Abodoment of a calendar, which is always updated to embed?
Here is my configuration, with which it runs well except for the small error
  sources:
    - name: ics
      args:
        file: "/www/abfall.ics"
      customize:
        - type: Graue Tonne
          alias: rest
          icon: mdi:trash-can
          alias: bio
          icon: mdi:trash-can
        - type: Gelbe Tonne
          alias: gelb
          icon: mdi:recycle
        - type: Blaue Tonne
          alias: papier
          icon: mdi:trash-can
  fetch_time: "04:00"
    add_days_to: false
    types:
      - rest
    types:
      - bio
    types:
      - gelb
    types:
      - papier
Try changing “add_days_to” to true instead of false, and probably add it on all sensors…
That’s what mine look like:
  value_template: '{{value.daysTo}}'
  date_template: '{{value.date.strftime("%d.%m.%Y")}}'
  add_days_to: True
  count: 2
  types:
    - "PapiermĂźll"
  add_days_to: True
  count: 2
  types:
    - "Gelber Sack"
Report back if that changes anything.
This is how mine looks, maybe this helps.
homeassistant:
  customize:
    sensor.waste_collection_waste:
      friendly_name: RestmĂźll
      icon: 'mdi:trash-can'
    details_format: upcoming
    value_template:  >-
      {% if value.daysTo == 0 %}
      HEUTE
      {% elif value.daysTo == 1 %}
      MORGEN
      {% else %}
      in {{value.daysTo}} Tagen
      {% endif %}
    types:
      - Restmuelltonne
I still got help from another side, runs meanwhile without problems, thank you anyway
And the solution was? :slight_smile:
That were so many points, I have turned to the creator of the garbage calendar, or in the Discord, it’s like a chat, I could give him access to my screen, we then went through point by point, until it was in the end still at a wrongly set / lay
