Ability to add multiple modbus hubs
It would be nice if we could add more than one modbus tcp device by using modbus 2: modbus3: etc.
Can that not be done now?
I tried this:
modbus:
type: tcp
host: 10.100.5.183
port: 502
modbus 2:
type: tcp
host: 10.100.5.180
port: 502
And I dont get errors in the log, I just dont know how to specify which switches go to which modbus poller.
Eraser
Ok, I tested it. Tthe following seems not to work:
  - platform: modbus
    registers:
      - name: Host 1 Ch 5
        unit_of_measurement: °C
        register: 5
        count: 1
        register_type: input
        data_type: int
        scale: 0.0015259
        precision: 1
  - platform: modbus 2
    registers:
      - name: Host 2 Ch 5
        register: 5
        count: 1
        data_type: int
        scale: 0.0015259
        precision: 1
Check config shows:
- Platform not found: sensor.modbus 2
Any Idea?
yes, it would be nice. I have several modbus tcp and encapsulated rtu devices.
Is there support for encapsulated rtu?
Any chance that this gets implemented?
I tried the code above, it is possible to create “platform: modbus 2” without errors, but unable to attach a sensor to it: “Platform not found: sensor.modbus 2”
It will be great to add more than one tcp devices and be able to configure the relative switch/sensor components.
Has anyone made any progress on this? I desperately need a second modbus tcp device added. I tried creating a custom component platform and sensor called modbus2 with changes to the modbus.py. Original files were renamed modbus2.py and mentions to modbus were changed to modbus2, but I ran out of luck…
Alright, so I really needed a second ModBus device data. I decided the easiest route would be to run a separate instance of HA in Docker, have that read the ModBus values from my Sunny Boy, then publish MQTT messages with the values that I need.
Here is the configuration of the HA instance used to do the above:
homeassistant:
  name: Sunny Boy Sensors
  latitude: !secret home_latitude
  longitude: !secret home_longitude
  elevation: !secret home_elevation
  unit_system: metric
  time_zone: !secret home_time_zone
  customize: !include customize.yaml
  customize_glob: !include customize_global.yaml
config:
#frontend:
mqtt:
  broker: !secret mqtt_url
  port: !secret mqtt_port
modbus:
  type: tcp
  host: !secret sma_sb_ip
  port: !secret sma_sb_port
#http:
#conversation:
#history:
#recorder:
#logbook:
  - platform: modbus
    scan_interval: 15
    registers:
      - name: Modbus SB Daily Yield
        unit_of_measurement: kWh
        slave: 3
        register: 30517
        count: 4
        data_type: int
        scale: 0.001
        precision: 3
      - name: Modbus SB Total Yield
        slave: 3
        register: 30513
        count: 4
        data_type: int
        scale: 0.001
        precision: 3
      - name: Modbus SB PV Power
        unit_of_measurement: W
        slave: 3
        register: 30775
        count: 2
        data_type: uint
      - name: Modbus SB Grid Power
        slave: 3
        register: 30865
        count: 2
        data_type: uint
      - name: Modbus SB Grid Feed
        slave: 3
        register: 30867
        count: 2
        data_type: uint
    sensors:
      modbus_sb_pv_production:
        friendly_name: 'PV Output'
        value_template: >-
            {% if states('sensor.modbus_sb_pv_power')|float < 10000 %}
              {{ states('sensor.modbus_sb_pv_power') }}
            {% else %}
              0
            {% endif %}
        unit_of_measurement: "W"
      modbus_sb_total_power:
        friendly_name: 'Total consumption'
        value_template: '{{ (((states.sensor.modbus_sb_grid_power.state | float) +
          (states.sensor.modbus_sb_pv_production.state | float))) }}'
automation:
  - id: mqtt_publish_sb
    alias: "MQTT Publish Sunny Boy"
    - platform: state
      entity_id: "sensor.modbus_sb_grid_power"
    - service: mqtt.publish
      data_template:
        topic: "sma/sb"
        payload: '{"grid_feed":{{ states("sensor.modbus_sb_grid_feed") }}, "grid_consumption":{{ states("sensor.modbus_sb_grid_power") }}, "production":{{ states("sensor.modbus_sb_pv_production") }}, "daily_yield":{{ states("sensor.modbus_sb_daily_yield") }}, "total_yield":{{ states("sensor.modbus_sb_total_yield") }}}'
Here is the MQTT message:
{"grid_feed":0, "grid_consumption":1819, "production":0, "daily_yield":15.884, "total_yield":248.245}
Here are the MQTT sensors in my normal HA instance:
- platform: mqtt
  name: "MQTT SB Daily Yield"
  state_topic: "sma/sb"
  value_template: '{{ value_json["daily_yield"] }}'
  force_update: true
  retain: true
  unit_of_measurement: "kWh"
- platform: mqtt
  name: "MQTT SB Total Yield"
  value_template: '{{ value_json["total_yield"] }}'
  force_update: true
  retain: true
- platform: mqtt
  name: "MQTT SB Production"
  value_template: '{{ value_json["production"] }}'
  force_update: true
  retain: true
- platform: mqtt
  name: "MQTT SB Grid Feed"
  value_template: '{{ value_json["grid_feed"] }}'
  force_update: true
  retain: true
- platform: mqtt
  name: "MQTT SB Grid Consumption"
  value_template: '{{ value_json["grid_consumption"] }}'
  force_update: true
  retain: true
This works really well. The Docker container uses 32MB ram and does not use much processing. This may help someone else who is trying to do the same. Of course, this would not work to change the state of a coil or write data to ModBus, but it’s a working solution to read ModBus sensors on multiple hubs.
Hello, I am interested to this feature, because I have more modbus TCP devices and in hass I can get data only from one each time.
I think I figured it out!
Copy /srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/modbus.py
to “your_config”/custom_components
rename it modbus1.py
edit the file by changing DOMAIN = 'modbus1'
Now if you want a Modbus sensor
Copy /srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/sensor/modbus.py
to “your_config”/custom_components/sensor
edit the file by changing import homeassistant.components.modbus as modbus to
import custom_components.modbus1 as modbus
and then DEPENDENCIES = ['modbus1']
Note* I am running in a pvenv so I had to make homeassistant the owner of all the directories and files.
  • custom_components, modbus1.py, sensor, modbus1.py
configuration.yaml…
modbus:
  type: tcp
  host: 127.0.0.1
  port: 4000
modbus1:
  type: rtuovertcp
  host: 192.168.254.196
  port: 4598
  - platform: modbus
    registers:
      - name: S1
        unit_of_measurement: 'mA'
        slave: 2
        register: 309
        register_type: holding
        count: 1
        precision: 2
        scale: 0.01
        data_type: custom
        structure: ">h"
  - platform: modbus1
    scan_interval: 60
    registers:
      - name: S2
        unit_of_measurement: 'feet'
        slave: 1
        register: 1
        count: 2
        scale: 3.281
        precision: 2
        data_type: float
restart HA Done!
Will have to try that one asap. So much cleaner than the solution I had to come up with! Cheers for sharing…
Works for me.
Thank you for sharing your easy workaround.
@cgrueter @monkey-house
Just testing 1 slave 1 register per connection but so far so good. No real CPU or mem increase.
Let me know how things go for you guys…
I am really counting on multiple connections. I will try to look into full integration.
Will hopefully have a look tonight!
@PtP: have you made a pull request on the Home Assistant GitHub. For guys who’ve got experience writing components for Home Assistant, it’s probably easy to come up with a solution that alter the .py file based on the presence of a modus1 entity in the configuration.yaml. Maybe this can become an integral part of Home Assistant by v .73 or .74?
I have not yet but I plan on it!
That’d be great.
Could you also please publish the fully revised code for the modbus1.py custom_component + custom_component/sensor here for ease of upgrading?
It’s a pain to access files for docker containers even locally, let alone remotely… Sure it would make it easier for many users: just copy the modbus1.py files to their respective folders, upgrade configuration.yaml and you’re good to go!
OK, just got to test this as well. It works great. I can finally delete my second instance of Hass and run all in a single container. Thanks @PtP.
Here is the corrected custom_component modbus1.py:
Support for Modbus.
For more details about this component, please refer to the documentation at
https://home-assistant.io/components/modbus/
import logging
import threading
import voluptuous as vol
import homeassistant.helpers.config_validation as cv
from homeassistant.const import (
    EVENT_HOMEASSISTANT_START, EVENT_HOMEASSISTANT_STOP,
    CONF_HOST, CONF_METHOD, CONF_PORT, CONF_TYPE, CONF_TIMEOUT, ATTR_STATE)
DOMAIN = 'modbus1'
REQUIREMENTS = ['pymodbus==1.3.1']
# Type of network
CONF_BAUDRATE = 'baudrate'
CONF_BYTESIZE = 'bytesize'
CONF_STOPBITS = 'stopbits'
CONF_PARITY = 'parity'
SERIAL_SCHEMA = {
    vol.Required(CONF_BAUDRATE): cv.positive_int,
    vol.Required(CONF_BYTESIZE): vol.Any(5, 6, 7, 8),
    vol.Required(CONF_METHOD): vol.Any('rtu', 'ascii'),
    vol.Required(CONF_PORT): cv.string,
    vol.Required(CONF_PARITY): vol.Any('E', 'O', 'N'),
    vol.Required(CONF_STOPBITS): vol.Any(1, 2),
    vol.Required(CONF_TYPE): 'serial',
    vol.Optional(CONF_TIMEOUT, default=3): cv.socket_timeout,
ETHERNET_SCHEMA = {
    vol.Required(CONF_HOST): cv.string,
    vol.Required(CONF_PORT): cv.positive_int,
    vol.Required(CONF_TYPE): vol.Any('tcp', 'udp', 'rtuovertcp'),
CONFIG_SCHEMA = vol.Schema({
    DOMAIN: vol.Any(SERIAL_SCHEMA, ETHERNET_SCHEMA)
}, extra=vol.ALLOW_EXTRA)
_LOGGER = logging.getLogger(__name__)
SERVICE_WRITE_REGISTER = 'write_register'
SERVICE_WRITE_COIL = 'write_coil'
ATTR_ADDRESS = 'address'
ATTR_UNIT = 'unit'
ATTR_VALUE = 'value'
SERVICE_WRITE_REGISTER_SCHEMA = vol.Schema({
    vol.Required(ATTR_UNIT): cv.positive_int,
    vol.Required(ATTR_ADDRESS): cv.positive_int,
    vol.Required(ATTR_VALUE): vol.All(cv.ensure_list, [cv.positive_int])
SERVICE_WRITE_COIL_SCHEMA = vol.Schema({
    vol.Required(ATTR_STATE): cv.boolean
HUB = None
def setup(hass, config):
    """Set up Modbus component."""
    # Modbus connection type
    client_type = config[DOMAIN][CONF_TYPE]
    # Connect to Modbus network
    # pylint: disable=import-error
    if client_type == 'serial':
        from pymodbus.client.sync import ModbusSerialClient as ModbusClient
        client = ModbusClient(method=config[DOMAIN][CONF_METHOD],
                              port=config[DOMAIN][CONF_PORT],
                              baudrate=config[DOMAIN][CONF_BAUDRATE],
                              stopbits=config[DOMAIN][CONF_STOPBITS],
                              bytesize=config[DOMAIN][CONF_BYTESIZE],
                              parity=config[DOMAIN][CONF_PARITY],
                              timeout=config[DOMAIN][CONF_TIMEOUT])
    elif client_type == 'rtuovertcp':
        from pymodbus.client.sync import ModbusTcpClient as ModbusClient
        from pymodbus.transaction import ModbusRtuFramer as ModbusFramer
        client = ModbusClient(host=config[DOMAIN][CONF_HOST],
                              framer=ModbusFramer,
    elif client_type == 'tcp':
    elif client_type == 'udp':
        from pymodbus.client.sync import ModbusUdpClient as ModbusClient
    else:
        return False
    global HUB
    HUB = ModbusHub(client)
    def stop_modbus(event):
        """Stop Modbus service."""
        HUB.close()
    def start_modbus(event):
        """Start Modbus service."""
        HUB.connect()
        hass.bus.listen_once(EVENT_HOMEASSISTANT_STOP, stop_modbus)
        # Register services for modbus
        hass.services.register(
            DOMAIN, SERVICE_WRITE_REGISTER, write_register,
            schema=SERVICE_WRITE_REGISTER_SCHEMA)
            DOMAIN, SERVICE_WRITE_COIL, write_coil,
            schema=SERVICE_WRITE_COIL_SCHEMA)
    def write_register(service):
        """Write modbus registers."""
        unit = int(float(service.data.get(ATTR_UNIT)))
        address = int(float(service.data.get(ATTR_ADDRESS)))
        value = service.data.get(ATTR_VALUE)
        if isinstance(value, list):
            HUB.write_registers(
                unit,
                address,
                [int(float(i)) for i in value])
        else:
            HUB.write_register(
                unit,
                address,
                int(float(value)))
    def write_coil(service):
        """Write modbus coil."""
        unit = service.data.get(ATTR_UNIT)
        address = service.data.get(ATTR_ADDRESS)
        state = service.data.get(ATTR_STATE)
        HUB.write_coil(unit, address, state)
    hass.bus.listen_once(EVENT_HOMEASSISTANT_START, start_modbus)
    return True
class ModbusHub(object):
    """Thread safe wrapper class for pymodbus."""
    def __init__(self, modbus_client):
        """Initialize the modbus hub."""
        self._client = modbus_client
        self._lock = threading.Lock()
    def close(self):
        """Disconnect client."""
        with self._lock:
            self._client.close()
    def connect(self):
        """Connect client."""
        with self._lock:
            self._client.connect()
    def read_coils(self, unit, address, count):
        """Read coils."""
        with self._lock:
            kwargs = {'unit': unit} if unit else {}
            return self._client.read_coils(
                address,
                count,
                **kwargs)
    def read_input_registers(self, unit, address, count):
        """Read input registers."""
        with self._lock:
            return self._client.read_input_registers(
                address,
                count,
                **kwargs)
    def read_holding_registers(self, unit, address, count):
        """Read holding registers."""
        with self._lock:
            return self._client.read_holding_registers(
                address,
                count,
                **kwargs)
    def write_coil(self, unit, address, value):
        """Write coil."""
        with self._lock:
            self._client.write_coil(
                address,
                value,
                **kwargs)
    def write_register(self, unit, address, value):
        """Write register."""
        with self._lock:
            self._client.write_register(
                address,
                value,
                **kwargs)
    def write_registers(self, unit, address, values):
        """Write registers."""
        with self._lock:
            self._client.write_registers(
                address,
                values,
                **kwargs)
And the custom_component/sensor modbus1.py:
Support for Modbus Register sensors.
For more details about this platform, please refer to the documentation at
https://home-assistant.io/components/sensor.modbus/
import logging
import struct
    CONF_NAME, CONF_OFFSET, CONF_UNIT_OF_MEASUREMENT, CONF_SLAVE,
    CONF_STRUCTURE)
from homeassistant.helpers.entity import Entity
from homeassistant.helpers import config_validation as cv
from homeassistant.components.sensor import PLATFORM_SCHEMA
CONF_COUNT = 'count'
CONF_REVERSE_ORDER = 'reverse_order'
CONF_PRECISION = 'precision'
CONF_REGISTER = 'register'
CONF_REGISTERS = 'registers'
CONF_SCALE = 'scale'
CONF_DATA_TYPE = 'data_type'
CONF_REGISTER_TYPE = 'register_type'
REGISTER_TYPE_HOLDING = 'holding'
REGISTER_TYPE_INPUT = 'input'
DATA_TYPE_INT = 'int'
DATA_TYPE_UINT = 'uint'
DATA_TYPE_FLOAT = 'float'
DATA_TYPE_CUSTOM = 'custom'
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend({
    vol.Required(CONF_REGISTERS): [{
        vol.Required(CONF_NAME): cv.string,
        vol.Required(CONF_REGISTER): cv.positive_int,
        vol.Optional(CONF_REGISTER_TYPE, default=REGISTER_TYPE_HOLDING):
            vol.In([REGISTER_TYPE_HOLDING, REGISTER_TYPE_INPUT]),
        vol.Optional(CONF_COUNT, default=1): cv.positive_int,
        vol.Optional(CONF_REVERSE_ORDER, default=False): cv.boolean,
        vol.Optional(CONF_OFFSET, default=0): vol.Coerce(float),
        vol.Optional(CONF_PRECISION, default=0): cv.positive_int,
        vol.Optional(CONF_SCALE, default=1): vol.Coerce(float),
        vol.Optional(CONF_SLAVE): cv.positive_int,
        vol.Optional(CONF_DATA_TYPE, default=DATA_TYPE_INT):
            vol.In([DATA_TYPE_INT, DATA_TYPE_UINT, DATA_TYPE_FLOAT,
                    DATA_TYPE_CUSTOM]),
        vol.Optional(CONF_STRUCTURE): cv.string,
        vol.Optional(CONF_UNIT_OF_MEASUREMENT): cv.string
def setup_platform(hass, config, add_devices, discovery_info=None):
    """Set up the Modbus sensors."""
    sensors = []
    data_types = {DATA_TYPE_INT: {1: 'h', 2: 'i', 4: 'q'}}
    data_types[DATA_TYPE_UINT] = {1: 'H', 2: 'I', 4: 'Q'}
    data_types[DATA_TYPE_FLOAT] = {1: 'e', 2: 'f', 4: 'd'}
    for register in config.get(CONF_REGISTERS):
        structure = '>i'
        if register.get(CONF_DATA_TYPE) != DATA_TYPE_CUSTOM:
            try:
                structure = '>{}'.format(data_types[
                    register.get(CONF_DATA_TYPE)][register.get(CONF_COUNT)])
            except KeyError:
                _LOGGER.error("Unable to detect data type for %s sensor, "
                              "try a custom type.", register.get(CONF_NAME))
                continue
        else:
            structure = register.get(CONF_STRUCTURE)
        try:
            size = struct.calcsize(structure)
        except struct.error as err:
            _LOGGER.error(
                "Error in sensor %s structure: %s",
                register.get(CONF_NAME), err)
            continue
        if register.get(CONF_COUNT) * 2 != size:
            _LOGGER.error(
                "Structure size (%d bytes) mismatch registers count "
                "(%d words)", size, register.get(CONF_COUNT))
            continue
        sensors.append(ModbusRegisterSensor(
            register.get(CONF_SLAVE),
            register.get(CONF_REGISTER),
            register.get(CONF_REGISTER_TYPE),
            register.get(CONF_UNIT_OF_MEASUREMENT),
            register.get(CONF_COUNT),
            register.get(CONF_REVERSE_ORDER),
            register.get(CONF_SCALE),
            register.get(CONF_OFFSET),
            structure,
            register.get(CONF_PRECISION)))
    if not sensors:
        return False
    add_devices(sensors)
class ModbusRegisterSensor(Entity):
    """Modbus register sensor."""
    def __init__(self, name, slave, register, register_type,
                 unit_of_measurement, count, reverse_order, scale, offset,
                 structure, precision):
        """Initialize the modbus register sensor."""
        self._name = name
        self._slave = int(slave) if slave else None
        self._register = int(register)
        self._register_type = register_type
        self._unit_of_measurement = unit_of_measurement
        self._count = int(count)
        self._reverse_order = reverse_order
        self._scale = scale
        self._offset = offset
        self._precision = precision
        self._structure = structure
        self._value = None
    @property
    def state(self):
        """Return the state of the sensor."""
        return self._value
    @property
    def name(self):
        """Return the name of the sensor."""
        return self._name
    @property
    def unit_of_measurement(self):
        """Return the unit of measurement."""
        return self._unit_of_measurement
    def update(self):
        """Update the state of the sensor."""
        if self._register_type == REGISTER_TYPE_INPUT:
            result = modbus.HUB.read_input_registers(
                self._slave,
                self._register,
                self._count)
        else:
            result = modbus.HUB.read_holding_registers(
                self._slave,
                self._register,
                self._count)
        val = 0
        try:
            registers = result.registers
            if self._reverse_order:
                registers.reverse()
        except AttributeError:
            _LOGGER.error("No response from modbus slave %s, register %s",
                          self._slave, self._register)
            return
        byte_string = b''.join(
            [x.to_bytes(2, byteorder='big') for x in registers]
        val = struct.unpack(self._structure, byte_string)[0]
        self._value = format(
            self._scale * val + self._offset, '.{}f'.format(self._precision))
Let us know when you post on GitHub so we can support the fixed implementation of multiple modbus or to update the Home Assistant documentation, if we can only add a modbus1.py!
Hi, I just stumbled on this thread when I was trying to implement my second modbus hub. I have already configured modbus tcp but now I was planning to add another one, for modbus rtu. I am running hassio so don’t think I have access to those modbus.py files that you refer to… Does anyone know if it is possible to add both modbus tcp and rtu on hassio…? Thanks in advance.
There is no reason why you could not do this on hass.io. You just need to find out the paths to the custom_components folder (should be in your config folder)…
Yes, you are right, it works perfectly now. There was no “custom_components” folder but I just created one inside of the config folder. And then created a “sensor” folder inside that.
Then just copy the 2 modbus1.py files inside those two folders and now it works fine. Thanks everyone for this.
