Currently, we have the ability to change your default view and manually specify which groups and components show up on the default view. This is handy, but once you manually define your starting view new components stop automatically showing up, obviously because you didn’t specify that it should be there.
I think it would be useful if we could define which groups we want to exclude from the default view and have everything else continue to work as is. For example, on of the first groups I created was my RaspPi card. Next thing I did was create a new tab for my “device information”. Now I have two raspi panels, one on default and one on my device information tab. Ideally, I could modify the group config so that it would not show up on the default view unless I manually specifed it in a default view config.
TL;DR - Override default tab view with default_view: no
pi:
entities:
- sensor.cpu
- sensor.cpu_use
- sensor.disk_use_
default_view: no
If I do the following, the panel disappears all together and the sensors I had grouped into Pi get dumped on the screen. I’d like it to appear in Devices tab, but not home, without having to manually select all of the tiles that appear in default view.
I’m struggling to do this as well… It does not appear there is a way to hide things from the Home tab (default view) without manually defining what you want to see on that view… I wish it was easier to move something to a tab (view) and have it not show up on the Home tab anymore…
Especially in the beginning.
I am still a noob regarding the Home Assistant universe and i created some groups to organise and work with some other automation.
Those groups are now shown, but i would not mind if they would not be seen, as i need them just to work with them in the background.
Home tab which shows literally everything - which is far too messy.
Home tab which only shows what I specify EXACTLY. Which is pointless because I can do that with another named tab anyway. And has a big disadvantage in that any new items don’t show up in the Home tab.
What I really want is a Home tab which only shows me items that I haven’t specified elsewhere and/or specifically excluded.
It was rejected with the point “you can override default view”. The problem with this is the logic that DPB61 expressed above.
I’m running into this where I’m new and need “auto discovery” to show me new things but I have media players popping on it from the roku, tv and plex. I don’t care about those for a “home status” so want to put them on a Tab. If I move to tab as a group they are still on home. If I hide in customization they go away from the tab… If I static set what I want to see on home I loose “new discovery”. Maybe allow for a home/default-view that you can make static but allow for a “group” that is the auto-discovery items that haven’t been “managed”.
