Here is the code, I had to redo everything as if hassio removed it all
I didn’t have time to retest it, but this should be in a format for hassio and you can dump into your configuration file.
scenegen.py
#!/usr/bin/python3
import requests
import argparse
import configparser
import sys
light_color_types = ["xy_color", "rgb_color", "color_temp", "color_name"]
def error(message):
sys.stderr.write("error: %s\n" % message)
sys.exit(1)
def get_states(url, key):
if key != None:
headers = {'x-ha-access': key}
else:
headers = {}
apiurl = url + "/api/states"
r = requests.get(apiurl, headers=headers)
if r.status_code != 200:
error("Error calling Home Assistant: {}, {}".format(r.status_code, r.reason))
return r.json()
def output_attrs(state, args):
parts = state["entity_id"].split(".")
type = parts[0]
name = parts[1]
light_attrs = ["transition", "profile", "brightness", "flash"]
if type == "light" and "light" in args.types:
print (" {}:".format(state["entity_id"]))
print (" state: {}".format(state["state"]))
for attr in light_attrs:
if attr in state["attributes"]:
print(" {}: {}".format(attr, round(float(state["attributes"][attr]))))
for color_type in light_color_types:
if color_type in state["attributes"] and args.colortype == color_type:
print(" {}: {}".format(color_type, state["attributes"][color_type]))
if type == "switch" and "switch" in args.types:
def main():
# Get command line args
parser = argparse.ArgumentParser()
parser.add_argument("url", help="url for Home Assistant instance")
parser.add_argument("-k", "--key", help="API Key of Home Assistant instance")
parser.add_argument("-s", "--scenename", help="Name of scene to generate", default = "My New Scene")
parser.add_argument("-m", "--mapfile", help="Name of mapfile to enable device filtering")
parser.add_argument("-f", "--filter", help="Comma separated list of device collections as defined in mapfile")
parser.add_argument("-c", "--colortype", help="color type to use", default = "color_temp", choices = light_color_types)
parser.add_argument("-t", "--types", help="list of device types to include", default = "light,switch")
args = parser.parse_args()
devices = {}
if args.mapfile:
config = configparser.ConfigParser()
config.read_file(open(args.mapfile))
for section in config.sections():
devices[section] = {}
for option in config.options(section):
devices[section][option] = config.get(section, option)
filters = []
if args.filter:
if args.mapfile:
filters = args.filter.split(",")
else:
error("Must specify a mapfile if using filters")
try:
states = get_states(args.url, args.key)
print(" - name: {}".format(args.scenename))
print(" entities:")
for state in states:
if args.mapfile:
if args.filter:
for filter in filters:
if filter in devices and state["entity_id"] in devices[filter]:
else:
for section in devices:
if state["entity_id"] in devices[section]:
else:
except:
raise
if __name__ == "__main__":
main()
