0.96.4 appears to be working well here. We havenāt needed heat or cooling the past few days, so I still donāt know if the shading under the line in the history graph works, but I can manipulate the fan controls from HA.
I had a bit of a scare last night after I did the update. None of my thermostats were found. I didnāt have time to look at it before I had to leave.
This morning I saw an error in the log indicating a failure to log on to the Honeywell server. My ID and password worked fine from my laptop and phone, so I just rebooted HASS.IO. That was probably overkill, but it did the trick.
And to add to the Honeywell rant, Iāve been trying to get their tech support to tell me how to configure my thermostat for separate heating and cooling systems. From what Iām reading, it canāt be done. The stupid thing is going to run the cooling fan when it calls for heat.
My first answer (two days later) was to ask me which wires were connected, and what all my settings were. I gave a complete run-down of the connections, and reminded the tech that MY question was, what SHOULD the settings be for my installation?
I got a second answer (two more days later) saying my connections were correct, and again asking me to send all my configuration settings.
Now, understand, IF this is ever going to work, itās going to be one, or maybe two settings that need to be configured. Pushing little buttons on the thermostat to scroll through and write down every single option is a tedious project.
I used to do tech support. This guy or gal is just stalling. Sending me on a wild goose chase just to get me out of his/her hair. Hoping Iāll give up, or at least take long enough that some other tech has to answer the question. Been there, done that.
