My Abode integration keeps going offline and will not reconnect until I restart HA. Not sure where to go. Started after 0.112 and still happening even faster in 0.113.1,
Getting the following in the logs.
020-07-25 16:16:34 WARNING (SocketIOThread) [abodepy.socketio] Captured exception during SocketIO event callback: Expecting value: line 1 column 1 (char 0)
2020-07-25 16:16:34 WARNING (SocketIOThread) [abodepy.socketio] SocketIO Server Ping Timeout
2020-07-25 16:16:34 WARNING (SocketIOThread) [lomond] disconnecting websocket
2020-07-25 16:16:34 WARNING (SocketIOThread) [abodepy.socketio] Captured exception during SocketIO event callback: Expecting value: line 1 column 1 (char 0)
File “/usr/src/homeassistant/homeassistant/core.py”, line 1276, in catch_exceptions
await coro_or_task
File “/usr/src/homeassistant/homeassistant/core.py”, line 1295, in _execute_service
await handler.func(service_call)
File “/usr/src/homeassistant/homeassistant/helpers/entity_component.py”, line 209, in handle_service
self._platforms.values(), func, call, required_features
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 454, in entity_service_call
future.result() # pop exception if have
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 595, in async_request_call
await coro
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 485, in _handle_entity_call
await result
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 621, in async_turn_on
await self.hass.async_add_executor_job(ft.partial(self.turn_on, **kwargs))
File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/usr/src/homeassistant/homeassistant/components/abode/switch.py”, line 36, in turn_on
self._device.switch_on()
File “/usr/local/lib/python3.7/site-packages/abodepy/devices/switch.py”, line 12, in switch_on
success = self.set_status(CONST.STATUS_ON_INT)
File “/usr/local/lib/python3.7/site-packages/abodepy/devices/init.py”, line 40, in set_status
method=“put”, url=url, data=status_data)
File “/usr/local/lib/python3.7/site-packages/abodepy/init.py”, line 432, in send_request
return self.send_request(method, url, headers, data, True)
File “/usr/local/lib/python3.7/site-packages/abodepy/init.py”, line 410, in send_request
self.login()
File “/usr/local/lib/python3.7/site-packages/abodepy/init.py”, line 136, in login
oauth_token_object = json.loads(oauth_token.text)
File “/usr/local/lib/python3.7/json/init.py”, line 348, in loads
return _default_decoder.decode(s)
File “/usr/local/lib/python3.7/json/decoder.py”, line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File “/usr/local/lib/python3.7/json/decoder.py”, line 355, in raw_decode
raise JSONDecodeError(“Expecting value”, s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
