My dev-environment is ubuntu16.04, mosquitto version is 1.4.14.
I coded a demo which can publish a mqtt message when I click the button.
When I started hass first then started mosquitto, terminal showed me that “ERROR: Address already in use”, and couldn’t get the message which is published by my demo.
When I started mosquitto first then started hass, hass showed me the “mqtt.binary_sensor” component in configuration.yaml could not be set up ( invalid config ), and I do get the message which is published by my demo by mosquitto.
But I did succeed last year: a python file in raspberry pi which could publish current temperature by mqtt, then I add a “mqtt.binary_sensor” component in configuration.yaml and started mosquitto in ubuntu machine, and I did see hass can get the temperature data.
So my question is:
Does hass have a build-in mqtt client? I found port 1883 is used whatever start hass or mosquitto.
How could I use mqtt in hass? I did add mqtt in configuration but it didn’t work.
If you add only mqtt: in your configuration, the internal mqtt broker get’s started in hass.
You have to provide the broker parameter to use an external brocker.
Maybe my expression is not clear. This is my mqtt config in configuration.yaml and I don’t have a
mqtt: config.So should I add a broker parameter (a machine which start mosquitto ) in this config?
Maybe my expression is not clear. This is my mqtt config in configuration.yaml and I don’t have a mqtt: config. What should I modify if I do not want to use the build-in server?
I modified configuration.yaml as your advice and hass did get the message I sent. It said “no match payload” but I did define payload_on and payload_off and I did return “true” and “false” to hass. Where is wrong?
Did you use double quote for your true, false in configuration.yml? The binary_sensor/mqtt is pretty straightforward, the only problem I can think about is your self._payload_on (loaded from configuration.yml) was parsed as boolean instead of string, or maybe the different is between true and True?
if self._template is not None:
payload = self._template.async_render_with_possible_json_value(
payload)
if payload == self._payload_on:
self._state = True
elif payload == self._payload_off:
self._state = False
else: # Payload is not for this entity
_LOGGER.warning('No matching payload found'
' for entity: %s with state_topic: %s',
self._name, self._state_topic)
return
