About the Home Assistant Companion for Apple category
Discussion of the official Home Assistant Companion for iOS, iPadOS, macOS and watchOS
To begin, thank for the good application!
I have 2 questions about the home assistant companion :
  • Why my application is in Chinese language ( impossible to find the language parameters to fix it )
  • I don’t understand because when I am in my house, the device display I not in my house ( the configuration is more tough with the Chinese version :wink: ) however it’s works well when I’m outside…
Thank you for your help
Since the official update of the app I can no longer log in.
Any ideas?
image|230x500
The mobile_app component is not loaded. What does it mean? Everything worked fine until the update
Hi, check here:
Please add default_config: or mobile_app to your configuration.yaml file. Please take a look here
I’ve tried it on my hold iPhone 5s and it work great…thank you
hi!
*The HA app (macOS version) launches automatically whenever my MacBook wakes up, and there is no way to close it, including ‘preference - general - launch app on login’ (in HA app) and ‘system settings - general - login items’ (in macOS)
This app absolutely needs to come to Apple tvOS. If it also supports older versions, it will give obsolete Apple TVs a new lease on life…
